(41C) Friedewald Formula for LDL-cholesterol - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-41C Software Library (/forum-11.html) +--- Thread: (41C) Friedewald Formula for LDL-cholesterol (/thread-12546.html) |
(41C) Friedewald Formula for LDL-cholesterol - Gene - 03-03-2019 06:51 PM From user Dinamarco Uses the Friedewald Formula for LDL-cholesterol. The limitation: Triglycerides > 400 mg/dL and Nephrotic Syndrome . The units used: mg/dL. Code: 01 LBL "LDL CHOLEST" RE: (41C) Friedewald Formula for LDL-cholesterol - Dieter - 03-05-2019 07:16 PM (03-03-2019 06:51 PM)Gene Wrote: The limitation: Triglycerides > 400 mg/dL and Nephrotic Syndrome . I am by no means an expert on this topic, but as far as I can see these conditions must not apply. So the limitations are: triglycerides < 400 mg/dl and no Nephrotic Syndrome. (03-03-2019 06:51 PM)Gene Wrote: 01 LBL "LDL CHOLEST" HP-41 labels cannot not be longer than seven characters. So there is no way to enter this line. I tried an improved version of this program which addresses some problems of the one above. For instance the text prompts are too long so that they scroll through the display. Which is almost as annoying as the two beeps (yes, I think I said that before ;-)). And there is no warning if the triglycerides value is not below 400 mg/dl. Here is how I would do it: Code: 01 LBL "LDL" Example: (don't know if the values make sense, but anyway....) Code: XEQ "LDL" But now... what about a complete cholesterol solver? Enter any three of the total, HDL and LDL cholesterol and the triglycerides values and have the fourth one calculated. Should be easy to do. ;-) Dieter Friedewald Formula for LDL-cholesterol - Dinamarco - 03-05-2019 08:05 PM Dear colleagues The posted program is something really simple. What should be understood: In the public health of poor countries, such as Brazil, and several others, the system does not allow to obtain the complete lipid profile, so we have to request the minimum possible and perform accounts. It turns out that Friedwald's Formula is not something well-known or sometimes remembered ... The written routine is intended to remind health professionals and make everyday work easier. Thanks Best Regards. RE: (41C) Friedewald Formula for LDL-cholesterol - Dinamarco - 01-18-2020 01:34 AM Using the program, is possible to determine the Castelli Index I & II. Friedewald Formula for LDL-cholesterol - NEW EQUATION - Dinamarco - 03-21-2020 12:57 AM Hi... A brand new paper/research published on JAMA Cardiology (doi:10.1001/jamacardio.2020.0013) - A New Equation for Calculation of Low-Density Lipoprotein Cholesterol in Patients with normolipidemia and/or Hypertriglyceridemia. Very interesting. I made a program for it and add the Castelli I, II & III. Hope some one help me with new improvements. Best Regards. |
