Generating a Polynomial Given Its Roots - Printable Version
+--- Forum: HP-41C Software Library (/forum-11.html)
+--- Thread: Generating a Polynomial Given Its Roots (/thread-11966.html)
Generating a Polynomial Given Its Roots - Eddie W. Shore - 12-17-2018 02:50 AM
Generate the coefficients of a polynomial (up to the order 4) with the roots a_0, a_1, a_2, and a_3. The resulting polynomial is:
p(x) = (x - a_0) * (x - a_1) * (x - a_2) * (x - a_3) * (x - a_4)
p(x) = r_4 * x^4 + r_5 * x^3 + r_6 * x^2 + r_7 * x + r_8
The default is a polynomial where the lead coefficient is positive. If you want a polynomial where the lead coefficient is negative, multiply every coefficient by -1.
Instructions
Store the four roots in registers R00, R01, R02, and R03 respectively. Run POLY4. Coefficients are shown briefly as they are calculated. They are can be recalled by the registers in decreasing order of x: R04, R05, R06, R07, and R08.
DM 41L and HP 41C Program: POLY4
01  LBL^T POLY4
02 1
03 STO 04
04 PSE
05 RCL 00
06 CHS
07 RCL 01
08 -
09 RCL 02
10 -
11 RCL 03
12 -
13 STO 05
14 PSE
15 RCL 01
16 RCL 02
17 +
18 RCL 03
19 +
20 RCL 00
21 *
22 RCL 02
23 RCL 03
24 +
25 RCL 01
26 *
27 +
28 RCL 02
29 RCL 03
30 *
31 +
32 STO 06
33 PSE
34 RCL 01
35 RCL 02
36 *
37 RCL 01
38 RCL 03
39 *
40 +
41 RCL 02
42 RCL 03
43 *
44 +
45 RCL 00
46 *
47 CHS
48 RCL 01
49 RCL 02
50 *
51 RCL 03
52 *
53 -
54 STO 07
55 PSE
56 RCL 00
57 RCL 01
58 *
59 RCL 02
60 *
61 RCL 03
62 *
63 STO 08
64 RTN
Example
Roots x = -3, x = 3, x= 4, and x= 6
Coefficients:
R04 = 1
R05 = -10
R06 = 15
R07 = 90
R08 = -216
Polynomial: p(x) = x^4 - 10 * x^3 + 15 * x^2 + 90 * x - 216
Blog post: https://edspi31415.blogspot.com/2018/12/dm-41l-and-hp-41c-generating-polynomial.html
RE: Generating a Polynomial Given Its Roots - Namir - 12-22-2018 11:44 PM
Your post and code is very interesting!! I am working on a version that will build polynomials up to order of 19. I have tested the code using Excel VBA. Next is coding the program for HP-41CX. I may also write a version for HP-71B.
Namir
RE: Generating a Polynomial Given Its Roots - Thomas Klemm - 12-23-2018 08:15 AM
If you really only want to do that up to order 4 you can use:
LBL "POLY4"
CHS   ENTER↑   X<> 00   ST+ 00
RCL Y   *   X<> 01   ST+ 01
RCL Y   *   X<> 02   ST+ 02
RCL Y   *   X<> 03   ST+ 03
END
Example:
CLRG
-3 XEQ "POLY4"
3 R/S
4 R/S
6 R/S
The coefficients of the polynomial can then be found in the registers:
R 00:  -10.0000
R 01:   15.0000
R 02:   90.0000
R 03: -216.0000
But we can do better than loop unrolling and use for the general case:
01 LBL "POLY"
02 CHS
03 ENTER↑
04 GTO 01
05 LBL 00
06 RCL Y
07 *
08 LBL 01
09 X<> IND Z
10 ST+ IND Z
11 ISG Z
12 GTO 00
13 RDN
14 RDN
15 FRC
16 1 E-3
17 +
18 END
Example:
CLRG
CLST
-3 XEQ "POLY"
3 R/S
4 R/S
6 R/S
The coefficients of the polynomial can again be found in the registers:
R 00:  -10.0000
R 01:   15.0000
R 02:   90.0000
R 03: -216.0000
In both cases the leading coefficient is always 1.
RE: Generating a Polynomial Given Its Roots - Namir - 12-23-2018 02:11 PM
Here is my version of the HP-41C program that can handle up to 19 roots.
The code basically implements repeatedly multiplying a polynomial with a simple 1st degree polynomial. The initial form of the polynomial is also a simple first degree polynomial. As you enter more roots, the degree of the polynomial increases.
Pseudo-Code
A(1) = 1
A(2) = -first root
Do
  B = input("Enter root?")
  IF B = 0 Then Exit Loop
  B = -B
  For I=2 to N+1
    C(I) = A(I) + B * A(I-1)
  Next I
  C(N+2) = A(N+1)*B
  N = N + 1
  For I = 1 To N + 1
    A(I) = C(I)
  Next I
Loop
Display array A(1) to A(N+1)
Memory Map
R00 = I loop control variable
R01 = A(1)
R02 = A(2)
R20 = A(20)
R21 = C(1)
R22 = C(2)
R40 = C(20)
R41 = N
R42 = B
R43 = index I
HP-41C Listing
01 LBL "POLY"
02 LBL A
03 1
04 STO 41
05 STO 01
06 STO 21
07 FIRST ROOT?
08 PROMPT
09 CHS
10 STO 02
11 STO 22
12 LBL 00    # Main loop
13 ROOT? 0=END
14 PROMPT
15 X=0?
16 GTO 01    # go to display results
17 CHS
18 STO 42    # store minus root
19 XEQ 09
20 ISG 00    # store value for loop conttrol variable
21 STO X    # a virtual NOP
22 LBL 02    # stert inner loop
23 RCL 00
24 INT
25 STO 43    # store index I
26 1
27 -
28 RCL IND X    # Get A(I-1)
29 RCL 42        # Get B
30 *
31 RCL IND 43    # Get A(I)
32 +
33 RCL 00
34 INT
35 20
36 +
37 X<>Y
38 STO IND Y    # Store in C(I)
39 ISG 00
40 GTO 02    # End of loop
41 RCL 41
42 1
43 +
44 RCL IND X
45 RCL 42
46 *
47 RCL 41
48 2
49 +
50 X<>Y
51 STO IND Y
52 XEQ 09
53 LBL 03    # Loop for A(I) = C(I)
54 RCL 00
55 INT
56 STO 43
57 20
58 +
59 RCL IND X
60 STO IND 43
61 ISG 00
62 GTO 03
63 1
64 STO+ 41    # N = N + 1 increment polynomial order
65 GTO 00
66 LBL 01
67 XEQ 09
68 LBL 04
69 RCL 00
70 INT
71 RCL IND X
72 R/S
73 ISG 00
74 GTO 04
75 END
76 PROMPT
77 RTN
78 LBL 09    # set up loop control variable
79 RCL 41
80 1
81 +
82 1.00E+03
83 /
84 1
85 +
86 STO 00
87 RTN
Run the program by executing XEQ "POLY" (you can instead press the key [A] when you are inside the program POLY):
1) The first prompt will ask you for the first root. Enter a root.
2) Subsequent prompts will ask you for additional roots OR to enter 0 when you are done.
3) The program displays the coefficients of the polynomial starting with the coefficient of the highest term. Press [R/S] to view the next coefficient of the sequentially lower term. When you have viewed all of the coefficients, the program displays END.
Inspect the value in register 41 to view the degree of the resulting polynomial.
Enjoy!
RE: Generating a Polynomial Given Its Roots - Thomas Klemm - 12-23-2018 03:19 PM
Here's the program adapted for the HP-11C:
001-42,21,11    LBL A
002-      16    CHS
003-      36    ENTER
004-    22 1    GTO 1
005-42,21, 0    LBL 0
006-      34    x<>y
007-      20    ×
008-   43 36    LSTx
009-      34    x<>y
010-42,21, 1    LBL 1
011-   42 23    x<> (i)
012-44,40,24    STO+ (i)
013-    42 6    ISG
014-    22 0    GTO 0
015-   45 25    RCL I
016-   42 44    FRAC
017-      26    EEX
018-       3    3
019-      16    CHS
020-      40    +
021-   44 25    STO I
022-   43 32    RTN
Example:
CLEAR REG
CLx
STO I
-3 A
3 R/S
4 R/S
6 R/S
The coefficients of the polynomial can be found in the registers:
R 0:  -10.0000
R 1:   15.0000
R 2:   90.0000
R 3: -216.0000
Here as well the leading coefficient is always 1.
RE: Generating a Polynomial Given Its Roots - Eddie W. Shore - 12-23-2018 07:41 PM
(12-22-2018 11:44 PM)Namir Wrote:  Your post and code is very interesting!! I am working on a version that will build polynomials up to order of 19. I have tested the code using Excel VBA. Next is coding the program for HP-41CX. I may also write a version for HP-71B.
Namir
Thank you! I love your work.
RE: Generating a Polynomial Given Its Roots - Namir - 12-23-2018 09:12 PM
You have a fantastic web site too!!!
Namir
RE: Generating a Polynomial Given Its Roots - Namir - 12-23-2018 09:57 PM
I added pseudo-code to my original post.
Namir
RE: Generating a Polynomial Given Its Roots - Namir - 12-26-2018 12:09 AM
As I promised, here is the HP-71B version of the program. The DATA statement contain the number of roots, followed by the list of roots. This data can appear on one or more DATA statements. Run the program to view the coefficients along with their associated power of X:
10 REM POLY COEFFS FROM ROOTS
20 DIM A(101),C(101)
25 REM DATA NUMBER_OF_ROOTS
30 DATA 3
35 REM DATA STMT HAS LIST OF ROOTS
40 DATA 1,2,3
50 READ M, B
60 A(1) = 1@ C(1) = 1
70 A(2) = -B@ C(2) = -B
80 N = 1
90 FOR K=2 TO M
100 READ B @ B=-B
110 FOR I = 2 TO N + 1
120 C(I) = A(I) + B * A(I - 1)
130 NEXT I
140 C(N + 2) = A(N + 1) * B
150 N = N + 1
160 FOR I = 1 TO N + 1
170 A(I) = C(I)
180 NEXT I
190 NEXT K
195 M = N
200 FOR I=1 TO N
210 DISP A(I);"* X^";M @ WAIT 3
215 M = M - 1
220 NEXT I
230 DISP A(N+1)
240 END
RE: Generating a Polynomial Given Its Roots - Thomas Klemm - 12-27-2018 10:35 PM
(12-26-2018 12:09 AM)Namir Wrote:  As I promised, here is the HP-71B version of the program.
I was a bit surprised that the HP-71B is missing the PCOEF command of the HP-48G:
[-3 3 4 6]
PCOEF
[ 1 -10 15 90 -216 ]
Quote: The DATA statement contain the number of roots, followed by the list of roots.
So we have to modify the program for every new set of data?
That's not very practical.
RE: Generating a Polynomial Given Its Roots - Namir - 12-28-2018 07:20 AM
[-3 3 4 6]
PCOEF
The DATA statements provide the input. It's easier to change one or two numbers, add a number (then RUN the program) than to enter the whol list of roots again.
Namir
