how to pronounce numbers - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: how to pronounce numbers (/thread-10959.html) |
RE: how to pronounce numbers - Zaphod - 06-24-2018 10:49 AM (06-24-2018 01:08 AM)Wes Loewer Wrote: Pronunciation is important. See, I would say that number as just fifteen hundred , not one thousand, five hundred RE: how to pronounce numbers - Gerson W. Barbosa - 06-24-2018 06:36 PM 126.544: One hundred and twenty-six, point five double four /... 'n' twenny siks.../ I am right, am I not? (Or should I say "Aren't I?" :-) Well, that's how I was taught fourty years ago or so. BTW, has anyone here also written a program to fill checks (or cheques), but in English? I am interested in the full numbers routine. Who still fills checks these days? That was equivalent to about US$ 100.00 by mid February '86. I think at least twice that amount was required to buy a new HP-42S then. Perhaps even more. One ought literally to be a millionaire to buy HP here :-) Back in the day I had an Olivetti electrical printer which a third-party interface would turn into a parallel line printer for a fraction of the price of a dot-matrix printer. Those were the days! Code:
RE: how to pronounce numbers - Zaphod - 06-24-2018 07:09 PM Cheques are so 20th century RE: how to pronounce numbers - BartDB - 06-24-2018 07:53 PM (06-23-2018 10:48 AM)Don Shepherd Wrote: When numbers are spoken, how should they be pronounced? Why not just "one two six point five four four" ? (06-23-2018 07:43 PM)ttw Wrote: Eleven thousand eleven hundred and one. I would say 12101 Code: Eleven thousand: 11000 RE: how to pronounce numbers - ttw - 06-24-2018 11:20 PM I thought I wrote eleven thousand, eleven hundred and eleven. Oh well. RE: how to pronounce numbers - DavidM - 06-25-2018 03:27 AM (06-24-2018 06:36 PM)Gerson W. Barbosa Wrote: BTW, has anyone here also written a program to fill checks (or cheques), but in English? This is a messy-and-dirty RPL transcription of a routine I once used to create the text of the "body amount" of a check-printing application. I didn't bother including the cents part of the routine, as it merely generated "and xx/100" (xx being the two digits after the radix mark). Apologies in advance for this -- I haven't spent any time trying to optimize it or make it more RPL-friendly. It's ugly, but I believe this is a faithful rendition of the original algorithm. Although not needed for checks, it does handle zero, negative numbers, and larger amounts than would normally be used on a check (x<1E45). The original also capitalized the first letter, which I didn't bother to include in this transcription. Code: \<< RE: how to pronounce numbers - cyrille de brébisson - 06-25-2018 05:20 AM Hello, 126.544 Cent vintgt-quatre virgule cinq cent quarante-quatre En french, we do not "remove" higher numerals multipliers like americans do: 199 is NEVER pronounced as one nintynine, but always one hundred and ninty nine. We do use "hundreds" with multipliers in the 11 to 19 range, but prety much only for dates: 1974 = dix-neuf cent soixante-quatorze (19*100 60+14, literraly). Where there is conciderable wiggle room is in the decimal place where the fractional part is "most often" said as a full integer number. Unless it is very large. Then you are free to group the digits by 2, 3, or even more to make it easier for the listener. With the issue of how to deal with leading 0s... And I leave you with one of the most wonderfull numbers of the French language: 98 = Quatre-vingt-dix-huit or: For Twenty and ten eight! How wonderful! Cyrille RE: how to pronounce numbers - Paul Dale - 06-25-2018 06:47 AM I've been tempted to mention the interesting French approach to the seventies, eighties and nineties. I've resisted until now. English, of course, has the crazy teens: eleven, twelve, thirteen, ... nineteen plus several other schemes: four score and seven years ago. Then there is the disagreement about the higher powers of ten: is a billion 109 or 1012? We should next move onto digit grouping (comma, dot, space and probably several other symbols). From Wikipedia: 67,89,000,00,00,000 is interesting. Pauli RE: how to pronounce numbers - rncgray - 06-25-2018 07:42 AM Another interesting question is how the various representations of numbers help (or hinder) the doing of mathematics... RE: how to pronounce numbers - StephenG1CMZ - 06-25-2018 10:03 AM When pronouncing a sequence of digits, I usually pronunce 0 as "oh" - and in the case of telephone numbers and the like, leading zeros are pronounced, whereas in some cases they might be silent. But on a few recent telephone calls to call centres, for example to give bank account numbers, I have noticed this can cause confusion, and I have to say" Zero" (or "Nought") instead to the human staff, who give the impression they are typing in the letter "O" into a numeric field, and are puzzled that it is not working. 5&9: Also, note that. In English "five" and "nine" can be confused over a noisy radio channel, so coastguards and the like may pronunce these "fife" and "niner" to emphasise the difference. RE: how to pronounce numbers - grsbanks - 06-25-2018 10:34 AM (06-25-2018 05:20 AM)cyrille de brébisson Wrote: 126.544 Plus deux (06-25-2018 05:20 AM)cyrille de brébisson Wrote: And I leave you with one of the most wonderfull numbers of the French language: Only in French French. The French-speaking Swiss or Belgians would say nonante-huit RE: how to pronounce numbers - Dieter - 06-25-2018 11:04 AM (06-23-2018 07:35 PM)Thomas Okken Wrote: I've also heard "Drei Viertel Zwei," meaning a quarter to two, or three quarters of the way to two (from one), but that doesn't seem to be very common. It is very common in certain regions of the German speaking countries. Take a look at the map on this website. There even is a counterpart like "viertel zwei", meaning a quarter past one. In a way this also has its logic: a quarter of the hour between one and two has passed. Just as half an hour in "halb zwei". (06-23-2018 07:35 PM)Thomas Okken Wrote: "Viertel vor Zwei" is what I would use. Yes, that's standard German. At least in one half of the country. ;-) Dieter RE: how to pronounce numbers - Gerson W. Barbosa - 06-25-2018 12:34 PM (06-25-2018 03:27 AM)DavidM Wrote: This is a messy-and-dirty RPL transcription of a routine I once used to create the text of the "body amount" of a check-printing application. I didn't bother including the cents part of the routine, as it merely generated "and xx/100" (xx being the two digits after the radix mark). No, not at all! That's much better than I would get by trying to translate my old unstructered BASIC code from Portuguese into English and then to RPL. Thank you very much! 3333333333 --> three billion three hundred thirty-three million three hundred thirty-three thousand three hundred thirty-three Also, that matches my understanding of "billion". Thanks again, Gerson. RE: how to pronounce numbers - grsbanks - 06-25-2018 12:55 PM (06-25-2018 12:34 PM)Gerson W. Barbosa Wrote: Also, that matches my understanding of "billion". Another difference between British English and everyone else's English. Or at least it used to be. One billion used to be understood as \(1000000^2\), one trillion as \(1000000^3\), one quadrillion as \(1000000^4\) etc. So, 3333333333 would have been "three thousand three hundred and thirty-three million three hundred and thirty-three thousand three hundred and thirty-three." The "three billion three hundred and thirty-three million […]" number would have been written: 3000333333333. Thankfully, this is more and more seldom the case and we're falling in line with the rest of the world so that there are fewer cases of misunderstanding. RE: how to pronounce numbers - DavidM - 06-25-2018 01:22 PM (06-25-2018 12:55 PM)grsbanks Wrote: One billion used to be understood as \(1000000^2\), one trillion as \(1000000^3\), one quadrillion as \(1000000^4\) etc. So, 3333333333 would have been "three thousand three hundred and thirty-three million three hundred and thirty-three thousand three hundred and thirty-three." I'm reminded of Ira Gershwin's lyrics to "Let's Call the Whole Thing Off"... which of course can't be fully appreciated in written form, since it's the differences in pronunciation which give the song its character. Perhaps we should just all adopt Roman Numerals as the standard and be done with it. RE: how to pronounce numbers - rprosperi - 06-25-2018 01:25 PM (06-25-2018 05:20 AM)cyrille de brébisson Wrote: And I leave you with one of the most wonderfull numbers of the French language: Isn't Twenty and ten eight = 100, not 98? RE: how to pronounce numbers - Gerson W. Barbosa - 06-25-2018 02:03 PM (06-25-2018 01:25 PM)rprosperi Wrote:(06-25-2018 05:20 AM)cyrille de brébisson Wrote: And I leave you with one of the most wonderfull numbers of the French language: Cyrille meant Four Twenty and ten eight, that is, 4*20 + 18 = 98. Just a typo (‘for’ for ‘four’). Moi, je préfère quatre-vingt-dix-sept :-) RE: how to pronounce numbers - StephenG1CMZ - 06-25-2018 02:10 PM (06-25-2018 01:22 PM)DavidM Wrote:(06-25-2018 12:55 PM)grsbanks Wrote: One billion used to be understood as \(1000000^2\), one trillion as \(1000000^3\), one quadrillion as \(1000000^4\) etc. So, 3333333333 would have been "three thousand three hundred and thirty-three million three hundred and thirty-three thousand three hundred and thirty-three." Unfortunately, Roman Numerals might not be as standard as you might imagine. In modern Roman, IV is taken to mean 4 (i.e. if a smaller digit preceeds a larger, subtract). But in older Roman, IV sometimes simply meant 6, just like VI, whilst 4 would be IIII. RE: how to pronounce numbers - 3298 - 06-25-2018 03:30 PM This thread reminds me of a Code Golf contest I participated in a few years ago. (The results are still online, by the way.) The challenge included writing numbers using letters, in English language. In the private messages between the guy who posted the challenge and me there was some disagreement over the letters used to represent 40. He said "forty", my program produced "fourty" (which I perceived as correct) as a side effect of my optimizations (in code golf the size of a program determines its score; this particular optimization used the same list of strings for -teen and -ty). As I'm typing this post, my spellchecker is marking my version as wrong (and it marks itself too - oh the irony), but as I'm not the only contestant who put the u in there (e.g. the Java entry that isn't mine explicitly contains the string "fourty" which could have been altered without side-effects other than an improved score), I guess this isn't as easy as the spellchecker makes it appear. In school I was taught "fourty" too, but this is not an English-speaking country, so that alone doesn't mean a lot. Regional differences again or what ...? Could a native speaker please enlighten me? (Okay, that was about spelling instead of pronunciation, but close enough.) RE: how to pronounce numbers - grsbanks - 06-25-2018 03:33 PM (06-25-2018 03:30 PM)3298 Wrote: Could a native speaker please enlighten me? 40 = forty as far as I'm concerned. https://writingexplained.org/forty-or-fourty-difference |
