Sum of roll of N dice - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Sum of roll of N dice (/thread-10650.html) |
RE: Sum of roll of N dice - brickviking - 05-11-2018 09:52 AM You guys can have your probability-based solutions. I do have a perfectly working version of the program from the DUP 6. SWAP post that I've extended for n-sided dice. Dies. Dice... eh, whatever: Code:
Now I'm trying to get the later version (OVER 1 PICK3) working in the same way, but I seem to be doing something wrong. I'll get back to this thread once I've worked out where in the dingoes I'm going wrong with my program. And yes, I'm aware of the limitations of RAND and Y^X expressed earlier in the thread. On a related note, I'm now trying to figure out how to jack up the speed of the kermit interface up to 38400. All I seem to get currently is 9600 with no way to change it. Using "set speed 38400" merely results in "?SET SPEED fails, speed is 9600". I haven't seen any obvious way to get the calculator to change this either. (Post 217) RE: Sum of roll of N dice - Allen - 05-11-2018 12:19 PM (05-11-2018 09:52 AM)brickviking Wrote: You guys can have your probability-based solutions. I do have a perfectly working version of the program from the DUP 6. SWAP post that I've extended for n-sided dice. Dies. Dice... eh, whatever: Your generalized solution (and the base-6 idea from Jim Horn) (05-02-2018 07:01 AM)Jim Horn Wrote: If you roll N six sided dice and put them next to each other and write down the values they show *minus 1* each, you'll get an N digit integer in base 6. All such 6^N integers are equally likely for fair dice. So, just find a random number from 0 to (6^N)-1, convert to base 6, add the sum of its digits plus N (to correct the "subtract 1 from each digit") and there you go: the sum of the six rolled dice with only one random number generation. are beautifully elegant- maybe the best there is! In my own problem solving I do struggle with knowing when is "good enough" and when to keep looking for a more elegant algorithm. Sometimes I learn new and equally cool things when I continue a little further down a path, even if I have a working solution in hand. We are all explorers, and serendipity is waiting just around the corner. RE: Sum of roll of N dice - Thomas Klemm - 06-23-2018 09:36 PM (05-02-2018 07:01 AM)Jim Horn Wrote: So, just find a random number from 0 to (6^N)-1, convert to base 6, add the sum of its digits plus N (to correct the "subtract 1 from each digit") and there you go: the sum of the six rolled dice with only one random number generation. We don't really need to convert to base 6 if we only want the sum of the digits. Here's a small program for the HP-42S: Code: 6 The program works similar to the Base Conversion but instead of multiplying the digits by powers of 10 they are just added. Let's assume we want to calculate the digits of the number 13710 = 3456. So we divide 137 consecutively by 6 and get 22 and then 3. This allows to represent the digits as: Code: 5 = 137 - 6 · 22 Code: 5 + 4 + 3 = 137 - 5 · 22 - 5 · 3 = 137 - 5(22 + 3) = 12 RE: Sum of roll of N dice - rprosperi - 06-23-2018 10:33 PM Thomas! Welcome back to MoHPC! It has been a (very!) long time since you've been around; I wanted to say you have been missed. I'm really glad to see you're back. RE: Sum of roll of N dice - ttw - 06-24-2018 01:08 AM I have used a fairly fast method for rolling 5 or 6 dice. For 5 dices, I build a random number generator with modulus M=6 ^5*2^24. I used a Lehmer type. So after finding a good A (I don't have a numerical A here; the idea is that A/M as continued fraction should have small partial quotients), I just compute X=X*A+1 Mod M. Then dividing X by 2^24, I get a number uniformly distributed between 0 and 7775; convert to base 6 (or work the base 6 stuff into the computation). One gets a uniform distribution over five 6s. That's the roll. This works if one has a good big-integer package. |
