New Version: 2018.01.24 1.4.0.13333
02-06-2018, 07:57 PM
Post: #41
RE: New Version: 2018.01.24 1.4.0.13333
Just replace font file in emulator. Ģ and ģ Works. Thank You. Thank You.
02-06-2018, 08:21 PM
Post: #42
Another desire. Please. There is not capital letter Ē (U+0112) in font file. I do not understand why. There is small letter ē (U+0113). Would You add Ē? Unless it's too complicated.
02-06-2018, 08:31 PM (This post was last modified: 02-06-2018 10:38 PM by Carlos295pz.)
Post: #43
I I would like "programa" to be corrected with "pragma" (Spanish language), is the only language that has this problem, I sent an mail for betas.
[STRINGFROMID(2443)]
[Image: 26169130628_4af47daedd_o.png]
Viga C | TD | FB
02-06-2018, 08:33 PM
Post: #44
Aha, the new HP Prime Pro app (13333) arrived on Android / Google Play Store. Looks nicer than before and works well with all the programs/apps I have installed on it. Thanks a lot!
Now I am going to explore some more of the new features. Big Grin
02-06-2018, 10:29 PM
Post: #45
(02-06-2018 08:21 PM)Voldemar Wrote:  Another desire. Please. There is not capital letter Ē (U+0112) in font file. I do not understand why. There is small letter ē (U+0113). Would You add Ē? Unless it's too complicated.
Nope, just a matter of copying two references to the E character and the macron accent character.
Not sure why that isn't there either. Maybe at some point I accidentally deleted it, or it was never there in the original font for some reason...
Anyway, download again from the link and it should be good.
TW
02-06-2018, 11:03 PM
Post: #46
Just downloaded. Perfect. Now I can write in my native language on Prime emulator. Many thanks.
I have this keyboard layout and now all letters from my keyboard are in Prime emulator.
Thank You, Tim.
02-07-2018, 12:18 PM
Post: #47
It seems that Connectivity Kit does not sync with an attached calculator. If I modify a progrom in the calculators/Programs folder the changes do not appear in the physical calculator.
02-07-2018, 03:06 PM
Post: #48
(02-07-2018 12:18 PM)leprechaun Wrote:  It seems that Connectivity Kit does not sync with an attached calculator. If I modify a progrom in the calculators/Programs folder the changes do not appear in the physical calculator.
For me, it's not automatic. I have to click the CK save icon for the program to show up on the calc.
Tom L
Cui bono?
02-07-2018, 03:31 PM
Post: #49
Anybody else having problems updating a hardware unit?, mine does not appear in CK, I tried several cables and USB ports no Go.
02-07-2018, 05:06 PM
Post: #50
(02-07-2018 03:31 PM)jefierro Wrote:  Anybody else having problems updating a hardware unit?, mine does not appear in CK, I tried several cables and USB ports no Go.
How old is the hardware unit firmware? What version is on it?
Are you using a mac?
TW
02-07-2018, 06:28 PM (This post was last modified: 02-07-2018 06:29 PM by jefierro.)
Post: #51
Thanks Tim.
Using a Dell Workstation with win10, windows is reports a device called HP Prime, and the unit is charging.
https://www.dropbox.com/s/v6uimtxd0ryfd2...e.jpg?dl=0
[Image: myprime.jpg?dl=0]
02-07-2018, 07:15 PM
Post: #52
That is quite strange...
I'm assuming the connkit was installed as well?
TW
02-07-2018, 09:41 PM (This post was last modified: 02-07-2018 09:45 PM by jefierro.)
Post: #53
(02-07-2018 07:15 PM)Tim Wessman Wrote:  That is quite strange...
yup! this is what happen:
  1. Open prime simulator on PC for small operation, it asked for update.
  2. Mini-jump of joy, immediately installed.
  3. Experienced the new 3dgraph app, mid blown, I need this on my hand now!, opened CK asked for update, installed.
  4. Plug the real Prime to USB, and nada. CK reports no prime connected, tried a virtual one it showed but no real one.
  5. Rebooted still nada.
Thanks Tim.
02-07-2018, 09:57 PM
Post: #54
Thanks Tim.
I got it to work, partially, I reseteed the calc, rebooted the computer and it worked, I finally got it updated, but now after the update it wont show on CK again.
02-08-2018, 09:19 PM
Post: #55
As a software dev, I know how stressful it is to receive tons of bug reports, so I MUST BE the one who does this:
OS: macOS
Steps:
- Launch the beta connectivity kit
- Click update
- Done
- Connect the Prime
- Click update
- Done again
Everything is fine Big Grin
Thank you guys!
Software Failure: Guru Meditation
Antonio
IU2KIY
02-08-2018, 09:28 PM
Post: #56
(02-01-2018 02:49 PM)Carlos295pz Wrote:  Correct the memory of insufficient memory DIMGROB would polish the firmware
APP TECLAS DEDICADAS dont work Sad
Leo
02-08-2018, 10:54 PM
Post: #57
I’ve just upgraded from Beta 3 to 13333, and Racer and Baker’s Game are both now broken. Possibly DIMGROB related as I’m seeing insufficient memory errors?
02-09-2018, 01:42 AM
Post: #58
Yeah, just hold on a bit...
TW
02-09-2018, 06:33 AM
Post: #59
Quote:Anybody else having problems updating a hardware unit?, mine does not appear in CK, I tried several cables and USB ports no Go.
I had the same thing happen. No physical calculator did show up. I tried a really short cable and then things were fine. Some phones come with short cables.
cheers
02-09-2018, 07:28 AM (This post was last modified: 02-09-2018 07:30 AM by jebem.)
Post: #60
cheers
Yes, indeed. And some cables are only good to charge devices because:
1. They miss the data wires.
2. They are not compliant to the usb 2/3 full specification and are too long presenting higher interwire capacity than acceptable.
Also I had issues when using passive usb expanders in the past, so i only use active powered usb ports to connect my Prime.
