41 Electric Circuits - Reloaded
06-19-2014, 03:46 PM (This post was last modified: 06-20-2014 08:39 AM by Ángel Martin.)
Like me, you may have also missed the excellent article in the old forum by Guillermo Castarés with programs to solve electric circuits:
http://www.hpmuseum.org/software/41/41elcirc.htm
The approached he followed was remarkable in two aspects – first it had a precise usage of the PVT routine from the Math Pac using complex matrices; which wasn’t documented at all in the flimsy manual that was provided with that module.
More interesting was his idea of using ASCII files to define the circuit topology: type, elements, values, etc. This approach allows a very effective use of the system capabilities, without the need to re-enter all data each time allowing quick what-if scenarios for component value changes.
Not to mention that you could build up a library of circuits in X-memory very nicely. For example, these are the files for the Math Pac and the Advantage Pac manuals (Remember student “AC Dimmer”?), listed with their respective solutions.
MPAC        ACDIM
I4        0    I2
0V1 34 0    1    0V1 5 0
0R1 1        2    0Z1 10
1R2 1        3    1Z2 0 200
0R2 1        4    0Z2 0 -30
2R3 1        5    END
0R3 1
3R4 1        I1 = 0.0372 + 0.1311
0R4 2        I2 = 0.0437 + 0.1543
END
I1 = 21
I2 = 8
I3 = 3
I4 = 1
I’ve taken the opportunity to update the program, replacing the PVT call with the much faster MSYS in the Advantage Pac (or in the SandMatrix, of course); an splendid example of the MCODE advantages.
And to round up the task a new data-entry program is also provided, which builds the ASCII file from the scratch in an interactive way just entering the information in the prompts.
The new data-entry program “EEE” is completely independent, and its end result is an ASCII file to use as input for “EEA”, the circuit solver program.
Raw files are attached if you want to take them for a spin. Note that they use functions form the AMC_OSX module for a more convenient UI – but you can replace them with those in the CCD with the same names.
1    LBL "EEE"
2    "NAME? "
3    PMTA
4    15
5    SF 25
6    CLFL
7    FC?C 25
8    CRFLAS
9    ,
10    SEEKPTA
11    "TYPE? VI"
12    PMTK
13    CF 02
14    E
15    X#Y?
16    SF 02
17    "V"
18    FS? 02
19    "I"
20    CLA
21    XTOA
22    APPREC
23    "#NODE"
24    FS? 02
25    "#LOOP"
26    "|-S=?"
27    PROMPT
28    STO 02
29    CLA
30    ARCLI
31    APPCHR
32    "ELMNTS=?"
33    PROMPT
34    E3/3+
35    STO 00
36    LBL 00
37    CF 00
38    CLA
39    RCL 00
40    ARCLI
41    "|-: "
42    FC? 02
43    "|-I"
44    FS? 02
45    "|-V"
46    "|-RGLCXBYZY"
47    PMTK
48    XEQ IND X
49    STO 01
50    LBL 12
51    "FROM^TO=?"
52    PROMPT
53    X=Y?
54    GTO 12
55    RCL 02
56    X<Y?
57    GTO 12
58    X<> Z
59    RCL 02
60    X<Y?
61    GTO 12
62    RDN
63    XEQ 10
64    0
65    "VALUE=?"
66    FS? 00
67    "IM^RE=?"
68    PROMPT
69    XEQ 11
70    FS? 00
71    XEQ 11
72    ISG 00
73    GTO 00
74    "END"
75    APPREC
76    RTN
77    LBL 01
78    SF 00
79    86
80    FC? 02
81    73
82    RTN
83    LBL 02
84    82
85    RTN
86    LBL 03
87    71
88    RTN
89    LBL 04
90    76
91    RTN
92    LBL 05
93    67
94    RTN
95    LBL 06
96    88
97    RTN
98    LBL 07
99    66
100    RTN
101    LBL 08
102    SF 00
103    90
104    RTN
105    LBL 09
106    SF 00
107    89
108    RTN
109    LBL 10
110    CLA
111    ARCLI
112    RCL 01
113    XTOA
114    X<> Z
115    ARCLI
116    "|- "
117    APPREC
118    RTN
119    LBL 11
120    CF 01
121    CLA
122    FRC
123    X=0?
124    SF 01
125    X<> L
126    FS? 01
127    ARCLI
128    FC? 01
129    ARCL X
130    "|- "
131    APPCHR
132    X<>Y
133    END
    289 bytes
Modified EEA Program follows - maintains the same logic as the original to read the circuit file and create the system matrices, only slightly modified the data output routine to account for the differences between PVT and MSYS. Refer to the original article for user instructions and documentation.
1    LBL " EEA"
2    CLRG
3    CLX
4    SEEKPTA
5    GETREC
6    ATOX
7    STO 09
8    ANUM
9    ST+ X
10    STO 14
11    X^2
12    LASTX
13    ST+ X
14    +
15    15
16    +
17    SF 25
18    ARCL IND X
19    FC?C 25
20    PSIZE
21    SF 00
22    SF 01
23    LBL 08
24    GETREC
25    AVIEW
26    ATOX
27    48
28    -
29    STO 00
30    ATOX
31    STO 07
32    ATOX
33    48
34    -
35    STO 01
36    ANUM
37    STO 02
38    ATOX
39    LBL 09
40    ATOX
41    44
42    X<=Y?
43    GTO 09
44    CLX
45    ANUM
46    STO 03
47    CLA
48    RCL 09
49    XTOA
50    "|-ELS"
51    ASTO X
52    XEQ IND X
53    FC? 00
54    GTO 07
55    FS? 02
56    XEQ 01
57    FC? 02
58    XEQ 03
59    GTO 08
60    LBL 07
61    "WAIT…"
62    AVIEW
63    RCL  14
64    X^2
65    LASTX
66    +
67    14
68    +
69    STO 00
70    "R"
71    AIP
72    RCL 14
73    2E-3
74    +
75    MATDIM
76    RCL 14
77    E3
78     /
79    RCL 14
80    STO 13
81    +
82    ASTO 12
83    "R14"
84    MATDIM
85    "|-,"
86    ARCL 12
87    MSYS
88    LBL 10
89    RCL 13
90    2E3
91     /
92    E
93    +
94    STO 01
95    LBL 12
96    RCL 00
97    RCL 01
98    ST+ X
99    E
100    -
101    +
102    STO 02
103    CLA
104    RCL 09
105    XTOA
106    RCL 01
107    AIP
108    ASTO 10
109    "|-(RE)="
110    ARCL IND 02
111    PROMPT
112    CLA
113    ARCL 10
114    "|-(IM)="
115    RCL 13
116    RCL 02
117    +
118    ARCL IND X
119    PROMPT
120    ISG 01
121    GTO 12
122    GTO 10
123    ….
    the rest is as the original
[code]
Hope you enjoy it - Many thanks to Guillermo for the original contribution!
Attached File(s)
.zip  updated.zip (Size: 912 bytes / Downloads: 67)
01-24-2018, 01:43 PM
RE: 41 Electric Circuits - Reloaded
Hey,
i am trying to bring this on my calculator. Two questions:
in the EEA program, there are some lines with "E", for example Line 77: E3. is this "1E3", as in 1 EEX 3?
Also in line 92, there is a single "E". is this the EEX key, and if so why do you use it in this place?
secondly, the EEE program uses "PMTK" and "PMTA". I guess these are CCD module functions. is there a good way to replace them with standard, advanced, or ex.func functions?
thanks!
01-24-2018, 02:49 PM
(01-24-2018 01:43 PM)damaltor Wrote:  in the EEA program, there are some lines with "E", for example Line 77: E3. is this "1E3", as in 1 EEX 3?
These are synthetic commands, which are both shorter and faster than the 'normal' version of their respective commands, but otherwise functionally the same. You can enter them the normal way and the program will work the same. E3 is the same as 1.00E3 ([1] [EEX] [3]), E is 1.00E1, etc.
Any of the normal synthetic resources can explain how to create these commands, but likely it's not worth the effort (though it is fun).
01-24-2018, 04:30 PM (This post was last modified: 01-24-2018 04:32 PM by Massimo Gnerucci.)
E is 1.00E1, etc.
E is 1E0=1, methinks
01-24-2018, 08:04 PM
(01-24-2018 04:30 PM)Massimo Gnerucci Wrote:
(01-24-2018 02:49 PM)rprosperi Wrote:  E is 1.00E1, etc.
4
Youthinks correctly, my mistake. E = 1E0 = [1] [EEX] [0].
Sorry 'bout that.
01-26-2018, 08:20 AM (This post was last modified: 01-26-2018 08:21 AM by damaltor.)
Ok, great. Thank you very much.
I had a second problem: I could not get the command MSYS into barcode form with the barcode generator at http://rwiker.github.io/hp41barcode/# because the command was not recognized. after looking through the source code of the barcode generator, i found out that the command was coded as MSVS instead of MSYS. i wondered why that would be the case, and found that the error is already present in the "official" xrom code list:
http://www.hpmuseum.org/software/xroms.htm
after googling around i found that spelling error in some other locations too, probably picked up from the hpmuseum xrom list. i wonder why that mistake was never found?
i will replace the synthetics with the "usual" commands, thats fine for me Smile still, how about PMTK and PMTA and such? as far as i recognize they are just alpha mode addons, which probably arent even really needed for the program to run and can be replaced by simpler commands, but if there are known direct replacements i would be happy to use them.
11-28-2018, 07:39 PM
Hello Ángel Martin and everybody.
I'm here again after several years and I just discoverer your kind words about my old electric circuit program.
Happy that someone found it interesting or useful.
Thanks a Lot.
You did my day!
Regards.
Guillermo Castarés
12-11-2018, 10:26 AM
(11-28-2018 07:39 PM)morex Wrote:  Happy that someone found it interesting or useful.
Thanks a Lot.
You did my day!
It's great to have you back, many thanks again for sharing your original work.
Saludos,
ÁM
