More info from
http://www.finseth.com/hpdata/hp42s.php
(Edited with Dieter's observations...thx)
Flags: 100, of which 0-10 and 81-99 are user and the rest system or reserved
0-4 show annunciator when set
11 auto execution
12 print double wide
13 print lower case
15-16 HPIL printer: 0)manual 1)normal 2)trace 3)trace w/stack print using the flags as a two-digit binary
21 printer enabled
22 numeric input available
23 alpha input available
24 ignore range errors
25 ignore any errors & clear
26 Clear - audio output is ignored Set - audio output is enabled
27 custom mode is active
28 radix mark: Clear is a comma, set is a period.
29 digit groupings shown: Clear - no Set - yes
30 stack lift disable
34 AGRAPH merging: 0) OR 1) duplicate "on" get turned off 2) overwrite 3) XOR
36-39 number of digits, 0-15 by using the four flags as a binary number.
40-41 display format: 0)sci 1)eng 2)fix 3)all by using the two flags as a two-digit binary
42-43 angle mode: 0)deg 1)rad 2)grad 3)rad by using the two flags as a two-digit binary
44 continuous on
45 currently solving equation
46 currently integrating
47 variable menu active
48 alpha keyboard active
49 low battery
50 set when a message is displayed line 1
51 set when a message is displayed line 2
52 program mode
53 INPUT in progress
55 printer exists
56 curve fit model: 1)linear 2)log 4)exponential 8)power
60 all \GS mode
61 logarithmic model invalid
62 exponential model invalid
63 power model invalid
65 matrix editor in use
66 auto grow matrices
68 base: 0)decimal 1)binary 7)octal 15)hexadecimal
72 local label
73 polar mode
74 real result only
75 programmable menu selected
76 matrix wrap, edge to edge
77 matrix wrap, first to last
