Full Version: Means API
Having noticed that some means are not built-in on the Prime (or perhaps I have overlooked them), here is a collection of common means and other numerical list routines.
See also thread: http://www.hpmuseum.org/forum/thread-9757.html
Means V0.1
Errors are handled by my List program, which should be compiled first (or comment out error messages).
Don't assume negative values are handled as you wish:
 LOCAL CRID:="Means V0.1 © 2018 StephenG1CMZ";
 LOCAL MN:="Means.";
 LOCAL MORETEXT:="A bag of mostly means.";//ST:TNG
 //IMPORT({LIST}); //LIST Handles Error Messages
 LOCAL EMPTY0:=0;//ADDITIVE
 LOCAL EMPTY1:=1;//MULTIPLICATIVE
 //NAN CAN BE GENERATED
 //NONE OF THESE ROUTINES HANDLE NAN IN INPUT LST DATA
 //BUT YOU CAN USE List.IsNumeric to check IF A LIST IS OK
 //ERR
 LOCAL NaN:="NaN";
 LOCAL ListErrK:=1;//1=SHOW ERROR
 //MLSTRING TO MATCH ML
 LOCAL MLS:={
   "MIN:              ",
   "MIN|:             ",
   "HarmonicMean:     ",
   "GeometricMean:    ",
   "GeometricMeanS:   ",
   "GeometricAverage: ",
   "ArithmeticMean:   ",
   "InterQuartileMean: ",
   "MidRange:          ",
   "RootMeanSquare RMS: ",
   "Cubic:             ",
   "ContraHarmonicMean: ",
   "PowerMean(−1):     ",
   "PowerMean(3):      ",
   "MAX:               ",
   "MAX|:              " };
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 // List math procedures
 // Probably only work on numeric lists
 TBD()
  MSGBOX("TBD");
 NAN()
  RETURN NaN;
 EMPTIES(ST)
  RAISE(MN+ST,EL,ListIsEmptyError,"",ListErrK);
  RAISE(MN+ST,EL,ListStatisticsError,"",ListErrK);
  RETURN NAN();
 DIVBY0(ST)
  RAISE(MN+ST,EL,DivBy0Error,"",ListErrK);
  RETURN NAN();//IN LIEU OF +INF OR −INF
 EXPORT ListΣLIST(LST)
  RETURN IFTE(SIZE(LST),ΣLIST(LST),EMPTY0);
 EXPORT ListΠLIST(LST)
  LOCAL SZ:=SIZE(LST);
  IF SZ>1 THEN RETURN ΠLIST(LST);
  IF SZ==1 THEN RETURN LST(1);
  //IF SZ==0 THEN
  RETURN EMPTY1;
  //END;
 EXPORT ListCUMSUM(LST)
 //Puzzle #41
 //{}={0}
  RETURN IFTE(SIZE(LST),cumSum(LST),{0});
 EXPORT ListMAX(LST)
  RETURN IFTE(SIZE(LST),MAX(LST),EMPTY0);
 EXPORT ListMAXABS(LST)
 //MAX MAGNITUDE IGNORING SIGN
  RETURN  MAX(ListMAX(LST),−ListMIN(LST));
 EXPORT ListMEAN(LST)
  IF SIZE(LST) THEN
   RETURN (mean(LST));
  RETURN EMPTIES("");
 //NB MEAN AND MEAN2 CURRENTLY RETURN TYPE RAT
 //USE approx if you prefer real
 EXPORT ListMEAN2(LSTV,LSTF)
  IF SIZE(LSTV) AND SIZE(LSTF) THEN
   RETURN (mean(LSTV,LSTF));
  RETURN EMPTIES("");
 //MEDIAN
 EXPORT ListMIN(LST)
  RETURN IFTE(SIZE(LST),MIN(LST),EMPTY0);
 EXPORT ListMINABS(LST)
  IF SIZE(LST) THEN
   RETURN MIN(ABS(LST));
  RETURN 0;
 //MODE
 EXPORT ArithmeticMean(LST)
  RETURN ListMEAN(LST);
 EXPORT ContraHarmonicMean(LST)
 //POSITIVE LST
  LOCAL DEN:=ListΣLIST(LST);
  IF SIZE(LST) THEN
   IF DEN THEN
    RETURN ListΣLIST(LST^2)/DEN;
   ELSE
    RETURN DIVBY0("");
  RETURN EMPTIES("");
EXPORT CubicMean (LST)
  LOCAL NN:=SIZE(LST);
  IF NN THEN
   RETURN approx(surd(((ListΣLIST(LST^3))/NN),3));
  RETURN EMPTIES("");
 GeometricAverage(LST)
 //AVERAGE GROWTH FROM LST(1) TO LST(0) IN NN STEPS.
 //NB INTERMEDIATE VALUES ARE NOT REFERENCED
 //BUT SIZE OF LST IS
  LOCAL AZ,AN;
  LOCAL NNN:=SIZE(LST)-1;//BECAUSE 1.N NOT 0.N
  IF NNN>0 THEN
   AZ:=LST(1);
   IF AZ THEN
    AN:=LST(SIZE(LST));
    RETURN (AN/AZ)^(1/NNN);
   ELSE
    RETURN DIVBY0("");
  RETURN EMPTIES("");
 EXPORT GeometricMean(LST)
 //Geometric mean
 //Positive (not checked)
 //ANY 0:0
 //Products can overflow:See GMeanS
  IF NN THEN
   //using surd instead of ^1/N avoids <0FAIL
   //negatives may yield imaginary mean
   RETURN approx(surd(ListΠLIST(LST),NN));
  RETURN EMPTIES("");
 //NB WHEN NEGATIVES ARE PRESENT
 //GMEAN AND GMEANS YIELD DIFFERING RESULTS
 //VERIFY?
 EXPORT GeometricMeanS(LST)
 //SLOW VERSION USES LOGS TO AVOID OVERFLOW
 //SO ABS TO AVOID NEGATIVES
 //ANY 0=0 AS GMEAN
 LOCAL MULT,SIGNLST;
 IF NN THEN
  IF POS(LST,0) THEN
   RETURN 0;
  //MULTIPLY NEGATIVES TBC
  //RECOMMENDED: MULT=(−1)^(MM/NN): MM=COUNT NEGATIVES
  //TO AVOID COUNTING  MM I THINK MULTIPLYING ALL SIGNS MAY BE QUICKER
  //TBC
  SIGNLST:=SIGN(LST);
  MULT:=IFTE(POS(SIGNLST,−1),ListΠLIST(SIGNLST),1);//COULD JUST MULTIPLY ALWAYS
  //EITHER LOG COULD BE USED
  RETURN MULT*e^(ListΣLIST(LN(ABS(LST)))/NN);
 RETURN EMPTIES("");
 EXPORT HarmonicMean(LST)
 //Positive preferred
 //EG(1,−1)=/0=NAN
  LOCAL DEN;
  IF NN THEN
   IF POS(LST,0) THEN
    RETURN 0;//ANY 0=0
   DEN:=ΣLIST(1/LST);//0 UNEXPECTED:UNDERFLOW?=INF MEAN
   RETURN IFTE(DEN,SIZE(LST)/DEN,NAN());//GUARD 0 DEN
  RETURN EMPTIES("");
 EXPORT InterQuartileMean (SORTEDLST)
 //InterQuartileMean:List must be sorted
 //TBC
 //DO THE SLICE INDICES NEED CASTING TO INT
 //IF SO ROUND OR TRUNC?
 //THIS IMPLEMENT IS ONLY CORRECT IF THE SIZE IS DIVISBLE BY 4
 //TBC
  LOCAL NN:=SIZE(SORTEDLST);
  IF SIZE(SORTEDLST)≥4 THEN
   RETURN (2/NN)*ListΣLIST(SORTEDLST({(NN/4)+1,(3*NN/4)}));
  //SMALL LIST: FALLBACK TO MEAN
  RETURN ArithmeticMean(SORTEDLST);//In this case it neednt be
 EXPORT InterQuartileMeanL(LST)
 //This temporary version also works if not divisible by 4
 //But is inefficient
 //It is not recommended
  //MAKE LST 4 TIMES BIGGER INSTEAD:MAY FAIL
  LOCAL TMP;
  TMP:=CONCAT(LST,LST);
  TMP:=CONCAT(TMP,LST);
  TMP:=SORT(TMP);
  RETURN (ArithmeticMean(TMP({NN+1,3*NN})));
 EXPORT MidRange(LST)
  //MSGBOX("MID");
  RETURN (ListMAX(LST)+ListMIN(LST))/2;
EXPORT PowerMean (LST,PWR)
 //AKA GeneralisedMean
 //PWR:REAL NONZERO
 //LST:POSITIVE SO ABS
 //IMPLEMENT MAY DIFFER FROM CUBIC ETC
  IF NN THEN
   RETURN IFTE(PWR,approx(surd(((ListΣLIST(ABS(LST)^(PWR)))/NN),PWR)),DIVBY0(""));
  RETURN EMPTIES("");
 EXPORT RMS(LST)
  IF NN THEN
   RETURN √((ListΣLIST(LST^2))/NN);
  RETURN EMPTIES("");
 EXPORT RootMeanSqare(LST)
  RETURN RMS(LST);
 EXPORT TruncatedMean(LST)
 //EXCLUDE EXTREMES
  TBD();
 //SPECIFY A PERCENTAGE OR SIMILAR TO EXCLUDE
 EXPORT WinsorisedMean(LST)
 //A VARIATION OF TRUNCATED:CLAMP EXTREMES
 //There is an implementation in the library
  TBD();
 EXPORT ManyMeans(LST)
 //WHAT NUMBER DID YOU WANT? :)
  LOCAL SAVED:=ListShowErrors;
  LOCAL ML:={};
  //SEQUENCE TO MATCH MLS
  ListShowErrors:=0;
  ML:={
   ListMIN(LST),
   ListMINABS(LST),
   HarmonicMean(LST),
   GeometricMean(LST),
   GeometricMeanS(LST),
   GeometricAverage(LST),
   ArithmeticMean(LST),
   InterQuartileMean(SORT(LST)),
   MidRange(LST),
   RMS(LST),
   CubicMean(LST),
   ContraHarmonicMean(LST),
   PowerMean(LST,−1),
   PowerMean(LST,3),
   ListMAX(LST),
   ListMAXABS(LST) };
  ListShowErrors:=SAVED;
  RETURN ML;
 EXPORT ManyMeansCHS(LST)
  LOCAL II,TM,CHS;
  LOCAL ML:={};
  LOCAL RLST;
  //PRINT(MN+" SIZE: "+SIZE(LST));//SIZE WARNS OF POSSIBLE SLOW CALCS
  TM:=TEVAL(ML:=ManyMeans(LST));//TIMED CALCULATION
  RLST:=MAKELIST((MLS(II)+ML(II)),II,1,SIZE(MLS));
  CHOOSE(CHS,CRID,RLST);
  //PRINT("Used "+TM);//Performance.And confirms list completed.
 EXPORT ManyMeansPRINT(LST)
  LOCAL II,TM;
  LOCAL ML:={};
  PRINT();
  PRINT(CRID);
  FOR II FROM 1 TO SIZE(MLS) DO
   PRINT(MLS(II)+ML(II));
 EXPORT IsMEAN(LST,XX,PWR)
 //Is XX a possible mean
 //First exact match
  LOCAL ML:=ManyMeans(LST);
  RETURN POS(ML,XX);
 EXPORT IsNAN(LST)
  MSGBOX(MN+"IsNAN\nUse StephenG1CMZ's List.IsNUMERIC");
  RETURN 0;
EXPORT MeansSeeAlso ()
  LOCAL KK;
  LOCAL CatFuns:={
   "cumSum",
   "deltalist",
   "max",
   "mean",
   "min",
   "product",
   "trunc"};
  //Just Listed as a reminder:not Selectable
  CHOOSE(KK,MN+" Relevant Cat Functions",CatFuns)
 EXPORT MEANS()
  //DIVBY0("");//TEST
Well, Stephen, thank you!
I had also post here very short code to get Geometric, Harmonic (and also Weighted, but this is already in the Prime) Mean. I'm putting there the link to your code, now.
Salvo
