Full Version: Numericintegration
This program uses an hybrid of CAS and Home-program to compute the integral of an via input entered function, the borders and intervals to compute diverse numeric integrals. It can easily be extended to other formulas, the included ones are those I sometimes need to check hand-calculations made by my pupils.
Arno
[attachment=5492]
Edit: Update attachment, now provides exact value, too
Can you please post the listing?
Thanks!
Namir
Its a little bit long, but here it is:
#cas
integr(g,a,b):=
logal h,x;
g:=expr(g);
IF type(g)==DOM_SYMBOLIC THEN
     g:=unapply(g,x);
h:=int(g(x),x,a,b);
RETURN (h);
#end
#cas
simpsonint(g,a,b,n):=
local l,l1;
g:=expr(g);
IF even(n) THEN
IF (type(g)==DOM_SYMBOLIC  OR type(g)== DOM_FUNC)
  THEN
   l:=MAKELIST(X,X,a,b,(b-a)/n);
     g:=unapply(g,x);
   l:=apply(g,l);
   l1:=MAKELIST(even(X)+1,X,1,n+1);
 return (2*DOT(l,l1)-g(a)-g(b))*(b-a)/(3*n);
   ELSE return ("f must be symbolic or function!");
ELSE return "n must be even!";
#end
#cas
trapezregel(g,a,b,n):=
local l;
g:=expr(g);
  THEN
     g:=unapply(g,x);
   l:=apply(g,l);
   return (2*ΣLIST(l)-g(a)-g(b))*(b-a)/(2*n);
#end
#cas
rightsum(g,a,b,n):=
local l;
g:=expr(g);
  THEN
     g:=unapply(g,x);
   l:=apply(g,l);
   return (ΣLIST(l)-g(a))*(b-a)/n;
#end
#cas
leftsum(g,a,b,n):=
local l;
g:=expr(g);
  THEN
     g:=unapply(g,x);
   l:=apply(g,l);
   return (ΣLIST(l)-g(b))*(b-a)/n;
#end
EXPORT NumericIntegr()
local a,N,f,b;
N:=12; a:=1;b:=3;
f:='X^2';
   if input(
     {{f,[8],{20,70,0}},
     {a,[0],{20,30,1}},
     {b,[0],{20,30,2}},
     {N,[0],{20,30,3}}},
     "Enter Data",
     {"f(X)=", "a= ", "b= ","N= "
       "Enter the function, upper case X!",
       "Enter the starting point",
       "Enter the endpoint",
       "Enter the amount of intervals"
     {f,a,b,N}
then
f:=lower(string(f));
PRINT();
PRINT("Simpsonsum:   "+simpsonint(f,a,b,N));
PRINT("Trapezoidsum:    "+trapezregel(f,a,b,N));
PRINT("Rectangleleft:  "+leftsum(f,a,b,N));
PRINT("Rectangleright: "+rightsum(f,a,b,N));
PRINT("Integral:"+integr(f,a,b));
return;
end;
Arno
Edit: Got that thing with the exact integral implemented, I thought it to be nice to see it for comparing.
Thank you!
Namir
