12-22-2017, 01:50 PM
Hello CG
To recover some skins designed for pocketpc, please can add a new command (External INTEGER) that is to visualize the LCD outside the keyboard, in this way you can have the keyboard separated from the screen, this I have also seen in other emulators.
Thanks
PHP Code:
Lcd
Zoom INTEGER
Zoomxy INTEGER INTEGER
Vertical INTEGER
Offset INTEGER INTEGER
External INTEGER
Bitmap STRING
Color INTEGER INTEGER INTEGER INTEGER
End
Thanks
