12-09-2017, 02:24 PM
41CL How-to's (using embedded serial port)
Table of Content
- MMU configuration for this how-to's
- Copy plug-in ROM to RAM page
- Copy ROM image from Flash/RAM page to computer file
This article uses two modules: 41CL Extreme Functions (YFNX) and 41CL Update Functions (YUPS).
execute the following functions:
MMUDIS // disable 41CL memory management unit
TURBO50 // to speed up things
MMUCLR // clear 41CL memory management unit configuration
"YFNX" // 41CL Extreme Functions ROM image ID
PLUGH // plug it to logical page 7 (Interface Loop port) leaving all physical ports available
"YUPS" // 41CL Update Functions ROM image ID
PLUGP // plug it to logical page 6 (Printer port) leaving all physical ports available
MMUEN // enable 41CL memory management unit
CAT then 2 // show ROMs mapped
"UPDAT XX" // 41CL Update ROM with revision in XX
"-YFNX XX" // 41CL Extreme ROM with revision in XX
Copy plug-in ROM to 41CL RAM page
This example will copy the time module in port 5 to physical RAM page 0x820.
"5-1>820" // ROM module location: 4K word from logical page 5 bank 1 >to> RAM physical address 0x820000
YMCPY // do the copying
"COPYING"
Note: you must replace the address-bank from the above example ("5-1") by your specific information based on your module location and type.
This example saves the physical RAM page at address 0x820 in a computer file.
Connect your 41CL to your computer
Physically connect your 41CL to your computer using the serial cable.
MMUEN // just in case, sometimes connecting/disconnecting the serial cable to/from 41CL has the effect of disabling the MMU
SERINI // initialize the serial port
BAUD then 48 // set communication speed to 4800 bauds
Start computer program to receive upcoming ROM image.
To do this step, you have to start a command line and need to be in the folder were the clupdate program is located.
Replace the FILENAME.ROM tag in the following step, by your specific filename.
Replace the SERIAL_PORT tag in the following step, by its specific serial port:
- Windows: find your serial port name with DeviceManager and use that name instead of the SERIAL_PORT tag. (ex.: COM4)
- Linux..: find your serial port name in /dev folder and use that name instead of the SERIAL_PORT tag. (ex.: /dev/ttyUSB0)
- macOS..: find your serial port name in /dev folder and use that name instead of the SERIAL_PORT tag. (ex.: /dev/tty.usbserial)
java -jar clupdate-1.1.0.jar --download FILENAME.ROM SERIAL_PORT 4800 [RETURN]
HH:MM:SS --upload [fileName: FILENAME.ROM] [portName: SERIAL_PORT] [baudRate: 4800]
HH:MM:SS Serial SERIAL_PORT opened.
HH:MM:SS Receiving
Warning: you now have 60 seconds to do the next steps before getting a timeout.
Export RAM/Flash page to serial port
"820000-0FFF" // physical address 0x820000 of length 0x0FFF in RAM
YEXP // export page
"SENDING"
HH:MM:SS Receiving 710 2186 2186 2186 924 = 8192 bytes received
HH:MM:SS File FILENAME.ROM saving ... done [YCRC=0x9931943C]
HH:MM:SS Serial SERIAL_PORT closed.
Note: this RAM page currently contains the time module copied in the previous steps.
Validate integrity of the saved file
"820" // calculating CRC of the copied module
YCRC
"9931943C" // value should match the above value
Have Fun! 8-)
Sylvain
