Full Version: Calculator name bug in Beta
In the old release, if your calculator has the same name as the virtual machine on the PC, it detected 2 calculators. However, in the beta it only shows one. I had to start the virtual one, change the name (Settings), close it and open it again. Then it had the new name and then I'd plug in the physical calculator showing both names.
I don't think this is a "bug": why two calculators should have the same name?
When both of them are in the list with the same name it is no easy to distinguish...
My Prime (HW, emu, iOS) have the same programs and vars: it would be almost very difficult for me operate with them if they'd have the same name...
Salvo
(12-04-2017 10:20 AM)webmasterpdx Wrote: [ -> ]In the old release, if your calculator has the same name as the virtual machine on the PC, it detected 2 calculators. However, in the beta it only shows one. I had to start the virtual one, change the name (Settings), close it and open it again. Then it had the new name and then I'd plug in the physical calculator showing both names.
Have you cloned your hardware calculator to your emulator? If so, the serial number of the clone came along with it. Check your "About HP Prime" screen on the emulator and I suspect it will match your HW. This is why it shows up the same. In your emu, just delete the "settings" file and you should be good again.
We haven't figured out what to do regarding the serial number in clones. There are drawbacks to just discarding it at any time and loading the old one...
(12-04-2017 06:23 PM)Tim Wessman Wrote: [ -> ]
That seems not to be the problem, I have cloned my VC using a backup from HW, both show up in CK when connected and they have the same serial-no (checked that right now).
Arno
The problem here is only naming, my Android got, after latest install, a backup replayed with all my newest changes, so I now started the connkit, VC and HW showed up and Android said "No adapter found", it still had the name of my HW-Prime. I changed it to something else and all three showed up in the connkit, although they are the of the same serial.
