11-19-2017, 09:34 PM
11-20-2017, 05:46 PM
I use an old version of Emu50g on an iOS 7 device. It runs perfectly, except that port 2 does not work, so I had to store my programs in port 1 and change some user key definitions. I am very satisfied with this app.
I've not found other 50g emulators for iOS.
11-20-2017, 05:52 PM
(11-20-2017 05:46 PM)Helix Wrote: [ -> ]I use an old version of Emu50g on an iOS 7 device. It runs perfectly, except that port 2 does not work, so I had to store my programs in port 1 and change some user key definitions. I am very satisfied with this app.
Merci Jean-Charles!
I'll see for it soon. I thought also HP had a such emulator, but maybe it is not in their planes at the moment.
Salvo
11-20-2017, 07:36 PM
(11-20-2017 06:59 PM)moonbeam Wrote: [ -> ]m48/m48+
thank you. Have it a "realistic" skin like Emu50g? That of Emu50g is impressive: I've installed it in my iPad and it looks like my real HP 50g...
Salvo
11-20-2017, 10:23 PM
(11-20-2017 09:42 PM)moonbeam Wrote: [ -> ](11-20-2017 07:36 PM)salvomic Wrote: [ -> ]thank you. Have it a "realistic" skin like Emu50g? That of Emu50g is impressive: I've installed it in my iPad and it looks like my real HP 50g...
Salvo
It does; a realistic light brown(?) skin compared to Emu50g's black one. The two apps are remarkably (almost suspiciously) similar and it wouldn't surprise me if the skins are interchangeable.
thank you I'll try!
Only a question: has m48+ a simple way to pass data between iOS (Cloud?) and the app, as Emu50g (via http)? I hope yes...
EDIT: installed!
you are right: they are very similar... also the server
11-21-2017, 08:17 AM
(11-21-2017 12:29 AM)moonbeam Wrote: [ -> ]Neither one is cloud-aware, both have a built-in http server. As far as I can tell, Emu50g is a clone of m48+. I wonder if anybody here knows more about the provenance of the respective apps.
I agree.
I tested a bit, yesterday and they are too similar, also the velocity. Only the HP50 skin has in the iPhone a row less in the display, both are better on the iPad and in iPad Pro both are a bit quicker.
Salvo
