11-03-2017, 03:28 PM
This program is meant to find the positions of items in a list.
A simple FOR loop, yes?
No, it has problems if the list contains lists.
It gives a Bad Agument Error...unless you insert a diagnostic print, in which case the inner list is printed, and nothing after that.
Example: Find({1,{},33,4},33) should yield {3}
But (1,{} ,3,4},3 fails.
EXPORT ListFIND(LST,ITEM)
//Find all instances of ITEM
LOCAL II;
LOCAL LSTPOSNS:={};
PRINT();
IF SIZE(LST) THEN //
//LOOP COULD BE OPTIMISED BY USING POS TO LEAP TO NEXT MODE
FOR II FROM 1 TO SIZE(LST) DO
//THIS LOOKS EASY BUT FAILS IF LST CONTAINS A LIST
//EG ({1,{},3,4},3) BAD ARGUMENT TYPE
//BOTH EQ AND == FAIL
//WITH PRINT:NO II=3 PRINTED
//WITHOUT PRINT: BAD ARGUMENT ERROR
//PRINT({II,LST(II)});
IF EQ(LST(II),ITEM) THEN
LSTPOSNS(0):=II;
END;//IF
END;//FOR
END;//IF
//Return Positions that match ITEM
RETURN LSTPOSNS;
EXPORT FINDER()
MSGBOX(ListFIND({1,{},3,4},3));
