11-02-2017, 07:20 AM
I believe I've found a bug in the code. At first, I thought I'd just corrupted my calculator, but I managed to crash the virtual version on the PC too....
Type the following verbatim...
<Home>
S1:="dogs you too cool" if it asks if it can create the variable, hit OK
S1(1,1e9) <Enter>
On my machine, it reboots the calculator. On the PC, it crashes the virtual calculator.
I've done it with just 18 blanks as the string, but I originally found this in CAS mode and it was inconsistent. Certain variable names didn't fail, but just gave me a bad index error.
I think what's happening is it's actually trying to index 1e9 into the string which is a memory leak/intrusion into bad space....which could be a way to get into the system if exploited....if understood :-)
I also found when running this from CAS, I lost some of my history .....sometimes....
The steps above with S1 seem to be the most consistent way to force this failure.
I've gotten it to fail with S1:=" "
However, it doesn't fail with S1:="" (null string).
Can someone at least try this to confirm it.
Thanks
-Donald
<Home>
S1(1,1e9) <Enter>
Thanks
-Donald
