Hi all,
I managed to squeeze in the HP-91 original microcode into the Multicalc.
As this model has an extra 7 buttons, some of the key mapping was changed slightly and all the number keys were assigned some of the shifted functions.
The 91 also has 2 switches with 3 positions each, so one mechanical switch is used for the printer mode and the Deg/Grd/Rad is selected from the keyboard menu. The printer interface also works with the USB port like the other models.
There were a lot of changes made, so I'm just doing some final testing and then I will upload the files. Those who have a kit already can update the software and it will be ready for use.
cheers
Tony
(01-13-2018 09:05 AM)teenix Wrote: [ -> ]Those who have a kit already can update the software and it will be ready for use.
Alas, still waiting...
(01-13-2018 11:30 AM)Massimo Gnerucci Wrote: [ -> ]Alas, still waiting...
Hopefully not much longer and was just due to Xmas postage delays. To the US has been around 2 to 3 weeks.
cheers
Tony
Received the assembled kit this week, safely packaged and shipped all the way from Australia.
Thank you very much for this great work, Tony!
Andreas
(01-13-2018 12:29 PM)Andreas Wrote: [ -> ]Received the assembled kit this week, safely packaged and shipped all the way from Australia.
Andreas
Beauty mate :-)
cheers
Tony
(01-13-2018 11:39 AM)teenix Wrote: [ -> ] (01-13-2018 11:30 AM)Massimo Gnerucci Wrote: [ -> ]Alas, still waiting...
cheers
Tony
A padded envelope from Australia just rang my bell... :D
Can't wait to go home!
(01-16-2018 03:17 PM)Massimo Gnerucci Wrote: [ -> ]A padded envelope from Australia just rang my bell...
Xmas did last a long time :-)
cheers
Tony
(01-16-2018 11:00 PM)teenix Wrote: [ -> ] (01-16-2018 03:17 PM)Massimo Gnerucci Wrote: [ -> ]A padded envelope from Australia just rang my bell...
Indeed.
I tried to update via USB to the latest firmware but I couldn't realize if I succeeded (changed port number, program recognized the multicalc, messages as expected...).
I have to read all docs more carefully!
A very nice new toy, however.
Thank you Tony.
(01-17-2018 08:48 AM)Massimo Gnerucci Wrote: [ -> ]Indeed.
Thank you Tony.
Hi Massimo,
When the calculator connects to the PC you should see a list of current settings appear in the listing window of the programmer screen. The latest upgrade has an extra 2 mouse clicks to perform due to the additional data for the HP-91, but normally just 2 mouse clicks will be required. If a PIC upgrade is available, the procedure for the upgrade will be listed in the window.
If the last line says...
PIC Code Version = Current
then the latest update from the web site is valid.
...and thank you.
cheers
Tony
Hi everyone,
I'm posting a link to a collection of programs in the General Software Library for the Teenix MultiCalculator and the HP Classic upgrade board. Hope you find it useful!
http://www.hpmuseum.org/forum/thread-10046.html
~Mark
A new MultiCalc version has been posted to teenix.org.
There is a new PIC code upgrade included also.
cheers
Tony
(02-07-2018 09:36 PM)teenix Wrote: [ -> ]A new MultiCalc version has been posted to teenix.org.
Just a short info: the HP-01 doesn't work anymore with this update.
Franz
(02-07-2018 10:54 PM)fhub Wrote: [ -> ]Just a short info: the HP-01 doesn't work anymore with this update.
Franz
Oops, apologies.
New upload available.
cheers
Tony
(02-08-2018 12:57 AM)teenix Wrote: [ -> ]Oops, apologies.
No reason to apologize - you're doing a really great job with your emulators!
Thanks,
Franz
Hi Tony,
I saw that you've now added the HP-33C (thanks for it!) and found a small glitch:
the button for RUN/PRGM is not moving correctly (in the HP-33E it's ok).
And one more minor bug: the HP-91 creates a cce97.ini file instead of cce91.ini.
Franz
(02-09-2018 01:42 PM)fhub Wrote: [ -> ]Hi Tony,
Franz
Hi Franz,
Thanks for the feedback.
Yes, I noticed the switch problem today and it is fixed.
The HP91 ini file is also fixed.
With some data storage/retrieval modifications in the PIC code for the MultiCalc, I have also managed to add the HP-33C to the list of calculators that it can emulate without taxing the external memory. The PIC for my calculator and Harald's Classic controller can now emulate 23 models.
New updates available.
cheers
Tony
(02-09-2018 03:14 PM)teenix Wrote: [ -> ]Yes, I noticed the switch problem today and it is fixed.
Well, the HP33c.zip is still the same as yesterday, so it's not fixed yet.
Quote:The HP91 ini file is also fixed.
Unfortunately now the HP-91 isn't working anymore at all.
Error message: invalid OCM file
And there's also a problem with the HP-38C from yesterday:
it would (probably) require a file cce38c.dll, but the zip-file contains cce38.dll.
After renaming it the calc worked, but I guess it's still the 38E, not the 38C.
Franz
(02-09-2018 03:14 PM)teenix Wrote: [ -> ] (02-09-2018 01:42 PM)fhub Wrote: [ -> ]Hi Tony,
Franz
Hi Franz,
cheers
Tony
So now that the 33c and 38c are added, why not add the 25c as well and make the woodstock series complete as well
I believe the Spices have different roms for the e and c models, but the Woodstock (25) does not.
Cheers,
Harald
(02-09-2018 04:49 PM)fhub Wrote: [ -> ]Unfortunately now the HP-91 isn't working anymore at all.
Franz
That'll teach me to fiddle until 3 in the morning.
Should be fixed.
cheers
Tony
(02-09-2018 09:03 PM)Harald Wrote: [ -> ]So now that the 33c and 38c are added, why not add the 25c as well and make the woodstock series complete as well
Cheers,
Harald
Now included in the MultiCalc hardware and your Classic controller.
Upgrade available at teenix.org
cheers
Tony
