I think toshk wrote this app. His PM is disabled, so I'm having to post this here. Is there any documentation for the Bode Plot App?
Thanks in advance.
-Donald
hi,
surely you have already seen
this post...
Read also
this one that has some examples and a bit of discussion inside...
Salvo
I can't find Bode() after installing it...in the toolbox-User menu?
This is the only example...have no idea how to use the symbolic view...
Thx
(10-21-2017 01:37 PM)webmasterpdx Wrote: [ -> ]I can't find Bode() after installing it...in the toolbox-User menu?
Thx
Recompile the App first;
toolbox-User menu>>App
It wasn't in the user menu, but I was able to edit the program and close it (which should compile it) and the call to BODE(0.01,100,[1 2],[3 4 5]) ran with a result of 0.33333, but the plot said insufficient stats data....on the virtual prime. Also, the history changed the numerator and denom to [2] and [60] respectively. I don't put apps on the actual calc unless they work on the virtual prime.
I guess it doesn't work...I got the latest zip from hpcalc.org. Note that there were a bunch of extra .png files but they weren't in the app directory....I just grabbed everything and tried to install in my virtual prime.
Note that I reset the virtual prime to the factory defaults before installing this.
(10-21-2017 07:11 PM)webmasterpdx Wrote: [ -> ]It wasn't in the user menu, but I was able to edit the program and close it (which should compile it) and the call to BODE(0.01,100,[1 2],[3 4 5]) ran with a result of 0.33333, but the plot said insufficient stats data....on the virtual prime. Also, the history changed the numerator and denom to [2] and [60] respectively. I don't put apps on the actual calc unless they work on the virtual prime.
It does not appear in user menu b'cos is (CAS + HOME syntax) + App;
http://www.hpmuseum.org/forum/thread-3891.html
it should appear on Apps; unzip file drag to Virtual/Prime
>>Apps>>Bode Plot>>Shift>>1>>Bode plot(App)>>Check
if no errors after Check. voila!
open App.
type on command line BODE syntax;
use VIEW button for selections.
I did all that....same results.
I'll look at the code when I have time. Obviously has bugs.
...unless hpcalc.org doesn't have the latest version....anyone know this?
