Full Version: EVAL doesn't work in old program
Hi!
I'm trying to use some programs I wrote on the pass but the don't work with the the firmware I use nowadays.
The stops on the function eval
This is an example:
EXPORT YO()
LOCAL k,f;
INPUT({{f,[8]},A,B,H,S},"Data Input",
{"dy/dx=","x0=","y0=","Step=",
"# Steps="});
X:=A;
Y:=B;
PRINT("___________");
PRINT("Solución por Método Euler");
PRINT("");
FOR k FROM 1 TO S DO
PRINT("X="+X);
PRINT("Y="+Y);
Y:=(Y+H*EVAL(f));
X:=(X+H);
PRINT("X="+X);
PRINT("Y="+Y);
Someone could tell me what changed?
Thanks
Until someone wiser jumps here...
I had observed in the past the [allowed_types_matrix] in INPUT don't work as one could expect.
[Edit]
BTW I wish you somebody (Tim? Didier?) to come here and explained WHAT EXACTLY was changed in firmware that your program no longer works.
I had similar issue with different commands here (post #13), but nobody answered. So I wish you better luck.
(10-20-2017 01:29 AM)adrunodro Wrote: [ -> ]Someone could tell me what changed?
As i posted in the other forum, please provide your inputs you are giving the INPUT form, and what your expected result is.
Just throwing in a few inputs it seems to work fine for me on the current public one.
(10-20-2017 12:49 PM)chromos Wrote: [ -> ]I had similar issue with different commands here (post #13), but nobody answered. So I wish you better luck.
Where's the non working source? Some inputs/expected outputs and I can look at it?
(10-20-2017 03:05 PM)Tim Wessman Wrote: [ -> ]
Thank you Tim for your time.
Source code:
PHP Code:
//author chromos
//chromos@chromos.cz
//released 2015-2017
//version 0.18
SUBRMAIN();
SUBRPREAMBLE();
SUBRINPUTCOORDS();
SUBRPRINTINPUTCOORDS();
SUBRPRINTINPUTCOORDSHELP();
SUBRFROMTO();
FUNCDMTODEG();
SUBRVALIDCOORDS();
SysAngle:=HAngle//remember Home setting
SysFormat:=HFormat;
NewCache//flag for skipping inputing data
GK//for GETKEY
Counter//for inputing coords
FC//Are entered all coord digits?
Loop//for FOR-DO (vars A..Z)
Loop1;
Loop2;
Loop3;
Loop4;
Loop5;
Loop6;
Loop7;
Loop8;
Loop9;
Loop10;
Loop11;
Loop12;
Loop13;
Loop14;
Loop15;
Loop16;
Loop17;
Loop18;
Loop19;
Loop20;
Loop21;
Loop22;
Loop23;
Loop24;
Loop25;
Loop26;
Temp//Temp
Temp1;
Temp2;
TempList//for looped variable numbers
TempFor//for making nested loop via EXPR
TempEnd//for making nested loop via EXPR
TempBody//for making nested loop via EXPR
DigitSum//digit sum for coordinates
SubDigitSum//digit sum for KNOWN part of coords
VarDigitSum//digit sum for variables only
PublLat//Published coords in DD.DDDD (cache isn't there)
PublLon//Published coords in DD.DDDD (cache isn't there)
Publinput//flag for different input forms for unsolved and published coords
Dist//Distance from published to solved coords
DMToDeg//for FUNC DD°MM.MMM > DD.DDDDDD
EXPORT Current_Cache()
NewCache
:=1;
IF (
SIZE(L1)<>15 OR SIZE(L7)<>15THEN
 NewCache
:=2;
 PRINT();
 PRINT(
"Sorry, it seems your data got corrupted. You must enter them again.
(Press any key to continue...)"
WAIT;
SUBRMAIN();
EXPORT New_Cache()
NewCache
:=2;
SUBRMAIN();
SUBRMAIN()
HAngle
:=1;
HFormat:=0;
TempList:=MAKELIST("",X,1,1);
TempList:={};
IFTE(NewCache=2,L1:={},""); //Coords in L1
L2:={}; //List of variables
IFTE(NewCache=2,L3:={},""); //Values 'from' of variables in L2
IFTE(NewCache=2,L4:={},""); //Values 'to' of variables in L2
L5:={}; //List of expressions
L6:={}; //Lists of valid variable values
IFTE(NewCache=2,L7:={},""); //Starting coords
L8:={}; //Solved coords Lat
L9:={}; //Solved coords Lon
L0:={}; //Distance and bearing from starting published coords
// Preamble
//IFTE(NewCache==2,SUBRPREAMBLE(),"");
// Enter initial coords
IF NewCache==2 THEN
 Publinput
:="1";
SUBRINPUTCOORDS();
L7:=L1;
PublLat:=EXPR(L7(1)+L7(2))+EXPR(L7(3)+L7(4)+"."+L7(5)+L7(6)+L7(7))/60;
PublLon:=EXPR(L7(8)+L7(9)+L7(10))+EXPR(L7(11)+L7(12)+"."+L7(13)+L7(14)+L7(15))/60;
// Enter unsolved coords
IF NewCache==2 THEN
 Publinput
SUBRINPUTCOORDS();
// Enter digit sum if known
Temp:=0;
DigitSum:=0;
VarDigitSum:=0;
CHOOSE(Temp,"Enter digit sum for:","Whole coords","Variables only","Skip");
IF
Temp==1 THEN
 INPUT
({{DigitSum,[0],{50,10,3}}},"Whole coords digit sum");
IF
Temp==2 THEN
 INPUT
({{VarDigitSum,[0],{50,10,3}}},"Vars only digit sum");
// Extracting expressions (into L5) and variables (into L2) from L1
SubDigitSum:=0;
FOR
Loop FROM 1 TO 15 DO
 IF
SIZE(LNAME(EXPR("'"+L1(Loop)+"'")))>0 THEN
  L5
(0):=L1(Loop);
L2:=UNION(L2,LNAME(EXPR("'"+L1(Loop)+"'")));
 ELSE
SubDigitSum:=SubDigitSum+EXPR(L1(Loop));
L2:=EXECON("STRING(QUOTE&1)",L2);
L2:=SORT(L2);
// Initializing ranges of variables
IFTE(NewCache=2,L3:=MAKELIST(1,X,1,SIZE(L2)),"");
IFTE(NewCache=2,L4:=MAKELIST(20,X,1,SIZE(L2)),"");
// Recapitulation
PRINT();
PRINT(
"                          RECAPITULATION");
TempList:=L1;
L1:=L7;
PRINT(
"Initial coords:");
L1:=TempList;
PRINT(
"Unsolved coords:");
PRINT(
"Variables: "+SIZE(L2));
PRINT(
"Expressions: "+SIZE(L5));
IF (
SIZE(L2)<OR SIZE(L5)<2THEN
PRINT("
GIVE ME AT LEAST ONE VARIABLE AND TWO EXPRESSIONS. BYE!"
KILL;
 IF
DigitSum>0 THEN
PRINT("Digit sum is "+DigitSum+" for whole coords and "+(DigitSum-SubDigitSum)+" for unknown part.");
 IF
VarDigitSum>0 THEN
PRINT("Digit sum for variables is "+VarDigitSum+".");
 PRINT(
WAIT;
// Edit ranges of variables
Temp=1;
CHOOSE(Temp,"Ranges of variables","Edit","Skip");
IF
Temp==1 THEN
 Temp
Temp1:="";
Temp2:="";
 FOR
Loop FROM 1 TO SIZE(L2) DO
Temp:=Temp+"{L3("+Loop+"),[0],{40,10,"+Loop+"}},{L4("+Loop+"),[0],{60,10,"+Loop+"}}";
IFTE(Loop<SIZE(L2),Temp:=Temp+",","");
Temp1:=Temp1+STRING("'"+L2(Loop)+"' is FROM ")+","+STRING("TO ");
IFTE(Loop<SIZE(L2),Temp1:=Temp1+",","");
Temp2:=Temp2+STRING("Lower limit for '"+L2(Loop)+"'")+","+STRING("Upper limit for '"+L2(Loop)+"'");
IFTE(Loop<SIZE(L2),Temp2:=Temp2+",","");
Temp:="INPUT({"+Temp+"},"+STRING("Ranges of variables")+",{"+Temp1+"},{"+Temp2+"})";
EXPR(Temp);
// Computing valid coords
SUBRFROMTO();
// RESULTS
PRINT();
IF
SIZE(L8)==0 THEN //Zero coords
PRINT("Ooops! 0 coords found!
Your input criteria are wrong!"
ELSE
 FOR
Loop1 FROM 1 TO SIZE(L2) DO //print ranges of variables
TempList:={};
  FOR
Loop2 FROM 1 TO SIZE(L6) DO
TempList(0):=L6(Loop2,Loop1);
TempList:=SORT(TempList);
L3(Loop1):=TempList(1);
L4(Loop1):=TempList(0);
 FOR
Loop FROM 1 TO SIZE(L3) DO
  PRINT(
L2(Loop)+" ∈ 〈"+L3(Loop)+";"+L4(Loop)+"〉");
 PRINT(
 IF
SIZE(L8)==1 THEN //for 1 coord
PRINT("Congrats! You solved it!
Cache is here:"
  PRINT(
L8(1)+"   "+L9(1)+"     "+L0(1));
  PRINT(
You can see this result in LIST Editor too:"
 IF
SIZE(L8)>=AND SIZE(L8)<=10 THEN //for 2 to 10 coords
PRINT(SIZE(L8)+" coords found!");
  FOR
Loop FROM 1 TO SIZE(L8) DO
   PRINT(
L8(Loop)+"   "+L9(Loop)+"     "+L0(Loop));
  PRINT(
You can see these results in LIST Editor too:"
 IF
SIZE(L8)>10 THEN //for more than 10 coords
  FOR
Loop FROM 1 TO 10 DO
   PRINT(
  PRINT(
Only ten coords are listed here. For complete results look into LIST Editor:"
 PRINT(
"L8 and L9 contain found coords with values of alphabetically sorted variables in L6.
L0 contains distance and bearing from starting coords.
L3 and L4 contain boundaries for variables in L2."
PRINT(
(Press any key to exit Terminal...)"
// END of program
HAngle:=SysAngle//Restore Home settings
HFormat:=SysFormat;
// --- SUBROUTINES ---
SUBRPREAMBLE()
PRINT();
PRINT(
"This program helps geocachers to solve incomplete coordinates as seen in mystery or multi caches listings.
If you've ever seen something like this:
   N50° 2(A-C).(B)(A+D)(E-F)
   E013° 50.(F)(C-A)(D)
then this program is for you!
WAIT;
SUBRINPUTCOORDS()
Counter
:=0;
L1:=MAKELIST("#",X,1,15);
PRINT();
IFTE(Publinput=="1",PRINT("Enter INITIAL coords:"),PRINT("Enter UNSOLVED coords:"));
REPEAT
FC
:=0;
REPEAT
 GK
:=GETKEY;
 IF
GK==49 AND Publinput=="" THEN
IF Counter<15 THEN
   Counter
:=Counter+1;
L1(Counter):="#";
Temp:="";
   IF
INPUT({{Temp,[2],{20,70,3}}},"Expression","Expr.","Variables must be in UPPERCASE! (e.g. A+B-4)","","")==0 THEN Counter:=Counter-1END;
   IF
Temp<>"" THEN
    IFERR
(EXPR(Temp)) THEN
     Counter
:=Counter-1MSGBOX("'"+Temp+"' isn't valid expression! Press OK to continue.");
    ELSE
L1(Counter):="("+Temp+")";
  PRINT();
 IF
GK==47 THEN
IF Counter<15 THEN
   Counter
:=Counter+1;
L1(Counter) := "0";
  PRINT();
 IF (
GK>=42 AND GK<=44THEN //digits 1-3
IF Counter<15 THEN
   Counter
:=Counter+1;
L1(Counter):=STRING(GK-41);
  PRINT();
 IF (
GK>=37 AND GK<=39THEN //digits 4-6
IF Counter<15 THEN
   Counter
:=Counter+1;
L1(Counter):=STRING(GK-33);
  PRINT();
 IF (
GK>=32 AND GK<=34THEN //digits 7-9
IF Counter<15 THEN
   Counter
:=Counter+1;
L1(Counter):=STRING(GK-25);
  PRINT();
 IF
GK==19 THEN
IF Counter>0 THEN L1(Counter):="#"Counter:=Counter-1END;
  PRINT();
 IF
GK==4 THEN KILLEND;
UNTIL GK==30
END
IF
POS(L1,"#")<>0 THEN FC:=1; PRINT("You must fill in coords before you can continue!"); END;
UNTIL FC==0
END
PRINT("    "+L1(1)+L1(2)+"° "+L1(3)+L1(4)+"."+L1(5)+L1(6)+L1(7)+"
+L1(8)+L1(9)+L1(10)+"° "+L1(11)+L1(12)+"."+L1(13)+L1(14)+L1(15));
PRINT("
Press '1'-'9' for entering coordinates,"
IF
Publinput=="" THEN PRINT("'Space' for unknown digit expression,"); END;
PRINT(
"'Backspace' for backspace,
'Enter' for next step,
'Esc' for abort.
SUBRFROMTO()
//number of possibilities
PRINT();
PRINT(
"No. of possibilities: "+IFTE(SIZE(L3)>=2,ΠLIST(L4-L3+1),L4(1)-L3(1)+1));
PRINT(
WAIT;
IF
SIZE(L2)>=2 THEN //nested loops construction
TempFor:="";
TempEnd:="";
TempBody:="";
 FOR
Loop FROM 2 TO SIZE(L2) DO
TempFor:=TempFor+"FOR Loop"+STRING(Loop)+" FROM L3("+STRING(Loop)+") TO L4("+STRING(Loop)+") DO
TempEnd:=TempEnd+"END;
TempBody:="SUBRVALIDCOORDS();
PRINT();
PRINT(
                          Completed: 0 %"
FOR
Loop1 FROM L3(1TO L4(1) DO //main brute force cycle
IFTE(SIZE(L2)>=2,EXPR(TempFor+TempBody+TempEnd),SUBRVALIDCOORDS());
 PRINT();
 PRINT(
                          Completed: "
+ROUND(100*(1+Loop1-L3(1))/(1+L4(1)-L3(1)),0)+" %");
FUNCDMTODEG(DMToDeg)
LOCAL FuncTemp1
:=""FuncTemp2:=""FuncLoop;
FOR
FuncLoop FROM 1 TO 3 DO
 IF (
MID(DMToDeg,FuncLoop,1)<>"°" AND MID(DMToDeg,FuncLoop,1)<>" "THEN
  FuncTemp1
:=""+FuncTemp1+MID(DMToDeg,FuncLoop,1);
FOR
FuncLoop FROM 4 TO DIM(DMToDeg) DO
 IF (
  FuncTemp2
:=""+FuncTemp2+MID(DMToDeg,FuncLoop,1);
DMToDeg:=EXPR(FuncTemp1)+EXPR(FuncTemp2)/60
RETURN(
DMToDeg);
SUBRVALIDCOORDS()
FOR Loop FROM 1 TO SIZE(L2) DO
EXPR(L2(Loop)+":=Loop"+STRING(Loop));
IFERR (EXPR(L5)) THEN
ELSE
Temp:=0;
Temp1:=-1;
 CASE
  IF
DigitSum>0 THEN
   Temp
:=ΣLIST(EXPR(L5));
Temp1:=DigitSum-SubDigitSum;
  IF
VarDigitSum>0 THEN
   Temp
:=ΣLIST(EXPR(L2));
Temp1:=VarDigitSum;
 IF (
Temp1==-OR Temp==Temp1THEN
//  IF ΠLIST(EXPR(L5+">=0") AND EXPR(L5+"<=9") AND EXPR("FP("+L5+")==0")) THEN
IF ΠLIST(EXECON("EXPR(&1)>=0 AND EXPR(&1)<=9 AND FP(EXPR(&1))==0",L5)) THEN
   L8
(0):=""+EXPR(L1(1))+EXPR(L1(2))+"° "+EXPR(L1(3))+EXPR(L1(4))+"."+EXPR(L1(5))+EXPR(L1(6))+EXPR(L1(7)); //Lat
L9(0):=""+EXPR(L1(8))+EXPR(L1(9))+EXPR(L1(10))+"° "+EXPR(L1(11))+EXPR(L1(12))+"."+EXPR(L1(13))+EXPR(L1(14))+EXPR(L1(15)); //Long
L6(0):=EXPR(L2);
Dist:=acos(sin(PublLat)*sin(FUNCDMTODEG(L8(0)))+cos(PublLat)*cos(FUNCDMTODEG(L8(0)))*cos(FUNCDMTODEG(L9(0))-PublLon));
IFERR(θ:=acos((sin(FUNCDMTODEG(L8(0)))-sin(PublLat)*cos(Dist))/(sin(Dist)*cos(PublLat)))) THEN
    L0
(0):=ROUND(6371*π/180*Dist,-3)+" km  error°";
   ELSE
L0(0):=ROUND(6371*π/180*Dist,-3)+" km  "+IFTE(FUNCDMTODEG(L9(0))-PublLon>=0,ROUND(θ,0),ROUND(360-θ,0))+"°";
END
This code works, but if you uncomment line #454 and comment out line #455 (cca 15 lines from bottom of included code above) then you will get nonworking* version which worked on android in December 2016.
You can find explanation of what this program do in Geocaching Coords Solver thread including result of inputed data. There you can download working version 0.18 (post #4) which is the same as code published in this post. There is also affected version 0.16 (post #3), but I don't recomend it as there are more broken things (for example INPUT syntax was changed too in newer firmware).
*) Nonvorking version means that the program ends with no visible sign when it goes to line #454.
[EDIT:]
For testing purposes, you can assign to list L5 some stringed expressions with A-Z variables, for example:
PHP Code:
L5:={"(A+B)","(C-A)","(D+E)","(D-C)","(B+C)","(A+2*D)"
You can ignore everything inside IF ΠLIST loop.
[EDIT 2:]
Mentioned IF loop tests if result of all expressions in L5 is nonnegative single digit number according to content of the A-Z variables.
(10-20-2017 01:29 AM)adrunodro Wrote: [ -> ]Hi!
This is an example:
EXPORT YO()
LOCAL k,f;
"# Steps="});
X:=A;
Y:=B;
PRINT("");
PRINT("X="+X);
PRINT("Y="+Y);
Y:=(Y+H*EVAL(f));
X:=(X+H);
PRINT("X="+X);
PRINT("Y="+Y);
Thanks
I don't understand the problem, after I had copied the program into my Emulator I started the program, entered some function (X^2+X, without quotes, upper case X) and the program seems to do what is wanted.
Arno
