In the Articles section there is a listing for Program to calculate Sunrise/Sunset times. I came across a character in the program listing on line 68 (and others) that is puzzling. It looks like it should be an operator, but the section of listing below includes the other common arithmetic operators. Can someone explain what this is?
66 18
67 RCL 07
68 •
69 24
70 /
71 RCL 05
72 +
73 STO 08
74 .9856
75 x
76 3.289
77 •
78 STO 09
Link to the article:
http://www.hpmuseum.org/cgi-sys/cgiwrap/...?read=1131
(10-14-2017 04:10 PM)Craig Bladow Wrote: [ -> ]In the Articles section there is a listing for Program to calculate Sunrise/Sunset times. I came across a character in the program listing on line 68 (and others) that is puzzling. It looks like it should be an operator, but the section of listing below includes the other common arithmetic operators. Can someone explain what this is?
If you look at the DOY routine it seems that this "•" must be a minus. This also matches line 68 where the difference between 6:00 resp. 18:00 h and the longitude divided by 15° (R07) is calculated. The same is true for the code around line 145 where, depending on flag 02, either a longitude or 360° minus this is calculated.
BTW there seems to be a similar problem with the 35s version. There are several lines with an "1." which also seems to stand for a "–" minus.
However I wonder why this "•" or "1." lines appear in the listing while elsewhere a simple "–" seems to work fine.
Dieter
Thanks Dieter, I'll give "minus" a try.
Craig
from the 33s listing for the equivalent section of program code:
C0029 FS? 0 If set use 18 for sunset calculation
C0030 18
C0031 RCL- G
C0032 24
C0033 /
so I'ld say Dieter nailed it.
BEST!
SlideRule
Thanks!
I found this also in the DOY program:
11 FS? 01 DMY mode
Should be
11 FS? 31 DMY mode
Still get a DATA ERROR, so need to do some more debugging.
(10-14-2017 09:20 PM)Craig Bladow Wrote: [ -> ]Still get a DATA ERROR, so need to do some more debugging.
FTR: I tried the HP41 version in V41 and it works just fine. The times for today exactly match those from a good online calculator.
However, I think the program can be improved. I also wonder if the FLOOR routine is really required. But I don't get any errors. At least not for my location and timezone. What values did you try?
Edit: The program calculates floor(R10/90) and floor(R11/90). Both R10 and R11 are the result of a mod 360 operation which always returns a value >= 0. So I think the complete FLOOR routine is obsolete and can be replaced with a simple INT command. And maybe the whole thing can be done even more elegantly with MOD.
Edit 2: I now have replaced the following lines of the original program...
99 ATAN
100 360
101 MOD
102 STO 11
103 RCL 10
104 90
105 /
106 XEQ 'FLOOR Floor function. External program
107 90
108 x
109 +
110 RCL 11
111 90
112 /
113 XEQ 'FLOOR Floor function. External program
114 90
115 x
116 -
117 15
118 /
119 STO 11
...with this:
99 ATAN
100 90
101 MOD
102 RCL 10
103 90
104 /
105 INT
106 90
107 x
108 +
109 15
110 /
111 STO 11
And it seems to work. But please do your own tests and report here if you find any cases where errors occur.
Dieter
Thanks for validating the program Dieter! It turns out I misplaced a decimal point in one of the constants so I am now getting good results. Once I save this to mag card(s) I will try your modifications. Since my longitude is > 90 degrees West it will be a good test of your changes.
Dieter, yes it works with your changes for my location. Thank you!
(10-14-2017 09:20 PM)Craig Bladow Wrote: [ -> ]I found this also in the DOY program:
11 FS? 01 DMY mode
Should be
11 FS? 31 DMY mode
BTW, there is no need to check flag 31 at all. Instead of Dec 31 simply count the DOY from 1 Jan, which is 1.01yyyy in either mode. ;-)
Here is a way to do so:
01 LBL"DOY"
02 100
03 SIGN
04 LastX
05 RCL Z
06 x
07 FRC
08 101
09 +
10 %
11 R^
12 DDAYS
13 +
14 END
Edit: The original program uses data registers up to R15. Since some values are only stored and recalled once and can be held on the stack, the program can be modified so that it requires only registers up to R10. Maybe even less. And I got it down to less than 330 bytes (including the DOY routine) so that it will fit on three card tracks.
I don't know if the author of the original program, M. Joury, is still reading this forum, so I'm not sure if it's OK for him if I would post my "streamlined" version of his program. The implemented algorithm looks very accurate.
Dieter
Dieter,
I think the updated version, with corrections of errors in the posting on the HP Articles portion of the old website, would be a valuable contribution to the HP-41c software library.
