(01-05-2019 08:40 PM)Neve Wrote: [ -> ]2 of the updated modules do not get installed on the machine.
TIME-3A.ROM
NUT0-N.ROM
ROMs that are part of the OS (these are) are never updated by default as the OS ROMs are write-protected. So, issue the OSUPDT command, which temporarily removes the OS write protection, the redo the update (probably "*" FLUPD will do it after starting the server). This is covered in the manual, though you're not even the first person today to run into this; everyone does sooner or later
Once updated, use OSPROT to restore protection.
(01-06-2019 05:28 AM)rprosperi Wrote: [ -> ]ROMs that are part of the OS (these are) are never updated by default as the OS ROMs are write-protected. So, issue the OSUPDT command, which temporarily removes the OS write protection, then redo the update (probably "*" FLUPD will do it after starting the server). This is covered in the manual, though you're not even the first person today to run into this; everyone does sooner or later Once updated, use OSPROT to restore protection.
I feel ridiculous now. LOL
