This is a simple program for tip calculation that took the idea from HP 12C Platinum vertical mode calculator app with Tip functions.
LBL A for Bill Amount
LBL B for Tip%
LBL C for Split (if only yourself enter 1)
LBL D answer for Tip per Person
LBL E answer for Total per Person
LBL A [Bill]
STO 1
RTN
LBL B [Tip%]
STO 2
RTN
LBL C [Split]
STO 3
RTN
LBL D [>Tip]
RCL 1
RCL 2
RCL 3
RTN
LBL E [>Total]
RCL 1
RCL 2
RCL 3
RTN
Total bill is $90.45 with 15% tip and 2 person
Example: 90.45 f A [Bill], 15 f B [Tip%], 2 f C [Split]
Answer: f D result 6.78 per person [Tip], f E result 52.01 per person[Total]
Quick Change: If you decided to lower the [Tip%] to 10% just press 10 f B and result for [Tip per person] and [Total per person] get the update result.
Now press f D result 4.52 per person [Tip], f E result 49.75 per person [Total]
Gamo
(10-07-2017 06:45 AM)Gamo Wrote: [ -> ]This is a simple program for tip calculation that took the idea from HP 12C Platinum vertical mode calculator app with Tip functions.
LBL B for Tip%
LBL C answer for Total per Person
Quote:LBL A [Bill]
STO 1
RTN
LBL B [Tip%]
STO 2
RTN
LBL C [Split]
STO 3
RTN
LBL D [>Tip]
RCL 1
ENTER
RCL 2
RCL 3
RTN
LBL E [>Total]
RCL 1
ENTER
RCL 2
RCL 3
RTN
Quick Chagne: If you decided to lower the [Tip%] to 10% just press 10 f B and result for [Tip per person] and [Total per person] get the update result.
Gamo
Just look at the label Instructions, for the last corresponds LBL E instaed LBL C. Pedro
Pedro Thank You that was typo.
I'm making change to LBL E
Gamo
(10-07-2017 02:10 PM)Gamo Wrote: [ -> ]Pedro Thank You that was typo.
You also can (and should) remove the two ENTERs at LBL D and E.
BTW, this program will also work on other HPs with label keys, such as the HP67 and 97.
Dieter
Dieter Thank You
I update the program now no ENTER
On the HP 67 and 97 even better when using Labels like this program because don't have to press f then LBL just go straight to each labels that very convenience.
Gamo
(10-08-2017 09:04 AM)Gamo Wrote: [ -> ]I update the program now no ENTER
Fine. Please also consider your other program for calculators without label keys.
(10-08-2017 09:04 AM)Gamo Wrote: [ -> ]On the HP 67 and 97 even better when using Labels like this program because don't have to press f then LBL just go straight to each labels that very convenience.
Switch to User mode and it's the same on the 11C and 15C. ;-)
P.S.: I'm a big fan of compact code, so here's another version.
Works on most calculators with R↑ key and does not require any registers.
R↓
LastX
R↑
X<>Y
LastX
90,45 [ENTER] 15 [ENTER] 2 [R/S]
=> 52,01 [X<>Y] 6,78
What? No R↑ key? Replace R↑ with 3x R↓.
Dieter
Dieter Thank You
That shorter program is very compact one.
For this program I try to make the same input steps of the Tip Calculator on the HP 12C Platinum Vertical Mode.
On HP 12CP user key in 3 variables and get the answer for the other 2 variables.
Thank You
Gamo
(10-09-2017 01:24 AM)Gamo Wrote: [ -> ]That shorter program is very compact one.
On the 41/42 it can be even shorter:
R↓
ST+ Y
R↑
ST/ Z
=> 6,78 [X<>Y] 52,01
On the 42s you even see both results at the same time.
(10-09-2017 01:24 AM)Gamo Wrote: [ -> ]For this program I try to make the same input steps of the Tip Calculator on the HP 12C Platinum Vertical Mode.
OK, so post your new version here.
Dieter
For HP 67 longer program and shorter output procedure ==>
R↓
LastX
R↑
X<>Y
LastX
R/S
X<>Y
So ==> Input: 90.45 [ENTER] 15 [ENTER] 2
Output: [R/S] 52.01 [R/S] 6.78
Pedro
