let's say I perform a STRING command to an objet (like a list, a matrix... for example).
how can I transform it to its original form ?
in other word, what is the reverse function of STRING ?
Thank you.
Do you mean a string relationship like quote() is to eval()? (A specific example would be helpful).
EXPR: Parses a string into a number or expression and returns the result evaluated.
For ex:
L1:={2,4,6,8,10}
STRING(L1) -> "{2,4,6,8,10}"
EXPR("{2,4,6,8,10}") -> {2,4,6,8,10}
(10-01-2017 01:43 PM)Didier Lachieze Wrote: [ -> ]EXPR: Parses a string into a number or expression and returns the result evaluated.
For ex:
L1:={2,4,6,8,10}
Yes, thank you Dider, that's exactly that.
BTW, I found that Connectivity Kit can not save/export user variables,
if you want to export your variable, you have to use built in ones (L0 to L9 for lists)
or use Notes trick, see below :
for example : Notes("myList_saved"):=STRING(mylist); -- Notes can be exported to windows with CK...
and then EXPR is needed to recover mylist:=EXPR(Notes("mylist_saved"));
