Maybe I am too dumb to get it done, but perhaps someone here can help me. Yesterday I tried to transfer a SysRPL program from this forum to my 50G and thought I could use DEBUG4x. Is there a way to make it recognize FPTR2 calls, I already exchanged suprom49 against the newest I could find, building the project still fails.
Arno
(10-01-2017 09:14 AM)Arno K Wrote: [ -> ]Is there a way to make it recognize FPTR2 calls, I already exchanged suprom49 against the newest I could find, building the project still fails.
Arno
FPTR2 ^xxxxxx is an appropriate syntax for the built-in compiler on a 50g, but hp's original RPLCOMP (which Debug4x uses) doesn't recognize that form. Generally speaking, you can usually replace
"FPTR2 ^" with
"FLASHPTR " (note the ^ and space) to compile the code with Debug4x.
As an example, seeing the following in 50g-syntax code:
...would compile properly in Debug4x as:
* Edited to fix a typo.
Thank you, I'll try that.
Arno
