09-27-2017, 06:56 PM
electronic translation
I am thoroughly testing XCAS PC version and web (on-line), and has educational potential (teaching and learning math), but has many problems in GUI and especially run on Windows-PC, the creator and respected Mr. Bernard Parisse BP, has fulfilled its work, it is time for third parties to continue with the project, more than 20 years of development, but many other years dedicated to symbolic calculation.
XCAS does not run on win64bits machines.
XCAS seems to work fine only on Linux and the BP computer.
XCAS has a problem storing functions in Windows, it generates junk files, a bug that also happens in hp-prime and that will not be solved, neither by BP nor by the developers of hp-prime.
The port of xcas to the hp-prime has to make many adjustments, for this reason, with several enthusiasts and collaborators xCAS will evolve significantly,
Because the XCAS engine depends only on BP, the development group can not do much and the problems continue, a repository is required where many are constantly evaluating, verifying, etc.
Thank you so much
I have been participating in the official xcas forum, but the answers are not encouraging
Original
Llamado a la comunidad, continuar con el proyecto XCAS
Estoy probando exhaustivamente XCAS versión PC y web (on-line), y tiene potencial educativo (enseñanza y aprendizaje de la matemática), pero tiene muchos problemas en la GUI y en especial de ejecución sobre Windows-PC, el creador y respetado señor Bernard Parisse BP, ha cumplido con su labor, es tiempo que terceros continúen con el proyecto, más de 20 años de desarrollo, mas muchos otros años dedicado al cálculo simbólico.
XCAS no corre en máquinas win64bits.
XCAS parece que funciona bien solo en Linux y el computador de BP.
XCAS tiene problema al almacenar funciones en Windows, genera archivos basura, bug que también ocurre en la hp-prime y que no será solucionado, ni por parte de BP, ni por parte de los desarrolladores de la hp-prime.
El port de xcas a la hp-prime hay que hacerle muchos ajustes, por esta razón, con varios entusiastas y colaboradores xCAS evolucionara significativamente,
Como el motor del XCAS depende solo de BP, el grupo de desarrollo no puede hacer mucho y los problemas continuaran, se requiere un repositorio donde muchos estén constantemente evaluándolo, verificándolo, etc.
Muchas Gracias
He estado participando en el foro oficial de xcas, pero las respuestas no son alentadoras
http://xcas.e.ujf-grenoble.fr/XCAS/viewforum.php?f=19
Thank you so much
Original
Muchas Gracias
