09-25-2017, 09:45 AM
The last time I saw this in the forums was in a FOCAL discussion, but I first ran into it somewhere else. Those of you who know what FIZZBUZZ is, won't need this explanation, but for everyone else who's not in the loop, fizzbuzz is a children's number game.
Numbers are counted from 1 to ... however many. There's a twist. If the number's divisible by 3, you say "fizz". If the number's divisible by 5, you say "buzz" instead. If it's divisible by both 3 and 5, you say fizzbuzz. Everything else, you simply say the number. A sample run would go like this:
1, 2, fizz, 4, buzz, fizz, 7, 8, fizz, buzz, 11, fizz, 13, 14, fizzbuzz, 16, 17, fizz, ... etc.
Here's my rough-cut example, I've had a rat-through and removed most of the bugs I know about. Could you suggest improvements?
progname: FBTST
To get the complete sequence of numbers (at least to whatever I specify on the stack), I use the following dead simple loop.
Progname: FBLP
My ideal would be to not need two spare vars and to operate using just the stack, but I then have to start learning how to use ROLL, PICK, or ROT in various incarnations. I don't know whether that will make the program larger, but I'll give that a go within the next few days.
(Post 97)
progname: FBTST
@ This takes one arg on stack and reports arg, fizz or buzz
@ fizz if divisible by 3, buzz if divisible by 5 and "fizzbuzz" if both
@ replies the arg otherwise
'J' STO
"" 'K' STO
'J' RCL
DUP @ copy for if-test
IF
3. MOD NOT
THEN
'K' "FIZZ" STO+
END
@ This tests the first J value
IF
5. MOD NOT
THEN
'K' "BUZZ" STO+
END
@ grab this back out for a quick test
'K' RCL
IF
SIZE 1 < @ Is it empty?
THEN
'J' RCL @ spit the value back out
ELSE
'K' RCL @ otherwise, spit out fizz,buzz or fizzbuzz
END
Progname: FBLP
@ Accepts two args on stack. 2: 1 1:25 loops from 1 to 25
FOR J J FBTST NEXT
@ alternative would have been 1. 25. FOR J J FBTST NEXT
(Post 97)
