Full Version: (42S) Integer Quotient
For large input, eg 888,888,888,888 the 42S snippet
5 / IP
does not return the correct integer quotient.
I have a programme to do the calculation correctly without disturbing the stack but believe it is inefficient.
Could someone suggest a more efficient programme that leaves the stack intact?
0.    { 29-Byte Prgm }
 1.    LBL “IQT5”
 2.    R↑
 3.    STO 01
 4.    R↓
 5.    STO 02
 6.    5
 7.    MOD
 8.    +/-
 9.    RCL+ 02
 10.    5
 11.    /
 12.    R↑
 13.    X<> 01
 14.    R↓
 15.    END
You always need an auxiliary variable. I use "." for that.
This program will compute Quotient and Rest
Y := q.X + r
In: Y: Y
    X: X
Out: Y: r
     X: q
     L: X
00 { 22-Byte Prgm }
01>LBL "RQ"
02 X<>Y
03 STO "."
04 X<>Y
05 MOD
06 STO- "."
07 LASTX
08 STO/ "."
09 X<> "."
10 END
Thank you, Werner, I shall certainly use your programme when I need IDIV2.
For my current problem I guess it's necessary to calculate modulo off the stack using register arithmetic, but that appears to be too complicated to be efficient, or at any rate more efficient than my programme above.
If all you want to do is IDIV5:
01>LBL "5/"
02 10
03 /
04 IP
05 STO+ ST X
06 LASTX
07 FP
08 STO+ ST X
09 IP
10 +
11 END
Cheers, Werner
Beautiful, Werner, I love you.
Which leads to my programme which does what I want.
Store 10 in variable "10" & the following programme finds integer quotient on division by 5 without disturbing the stack:
0.    { 27-Byte Prgm }
1.    LBL “IQT5”
2.    RCL/ "10"
3.    IP
4.    STO+ ST X
5.    STO "."
6.    CLX
7.    LASTX
8.    FP
9.    STO+ ST X
10.    IP
11.    RCL+ "."
12.    END
The question now is which is faster, my programme in the initial posting or this one - in terms of elegance this one wins hands down.
(09-19-2017 06:38 AM)Gerald H Wrote: [ -> ]For large input, eg 888,888,888,888 the 42S snippet
5 / IP
Have you tried 5 BASE÷ ? I don't have my HP-42S with me so can't test this.
(09-20-2017 10:17 AM)grsbanks Wrote: [ -> ]
5 / IP
Yes, that's the right idea, but doesn't work for large numbers.
