Did you realize that there are two different battery packs for the HP-41? One has 2 charging pins, the other has 3 pins. Both are coded HP82120A.
I'm currious as the charger for this unit has only 2 pins... the middle pin of the 3 pin version is absolutly "useless".
Matthias
(09-11-2017 05:36 PM)HP-Collection Wrote: [ -> ]Did you realize that there are two different battery packs for the HP-41? One has 2 charging pins, the other has 3 pins. Both are coded HP82120A.
Matthias
Hello Matthias,
You can find the information on the HP82120A with two pins
here and with three pins
here.
Sylvain
Matthias
Of course we
know, Matthias.
My first one was a 3-pins design.
