09-01-2017, 05:59 PM
Hi Friends,
Last week I had one HP Prime (1st gen) that once connected to charger, it did not turn on, no flicker on screen, changed the battery with one from other good hp prime and no luck.. reset button, on+symb, reset C+F+O.. absolutly nothing.. the only thin that I perceved was the high heat on back of screen. Same problem I had saw about 5 Hp prime on last 2 years.
Now I have one with serial 7CD5180... that connected the charger only the led near of usb connector lights up on blue. Only one time the screen lights up on white.. Chanched battery, removed battery connect only charger, reset, no high heat back screen.. and no vital signs.. then it is clinical dead.
Someone knows a solution or any hit ?
Pd. Most people reporter that the problem occurred after last charge..
Best regards!!
josephec
Best regards!!
josephec
