08-17-2017, 09:49 PM
C(n,r) and P(n,r) for HP-12C.
This should work for all cases where the result is less than 1E100.
The C(n,r) routine is based on the identity C(n,r) = C(n,n-r), selecting the minimum value of r and n-r for the calculations. In the loop body, the division and multiplication are done alternately to avoid overflows in cases where the intermediate calculations exceed the dynamic range of the HP-12C. Since doing division can result in non-integer results, the final result is rounded to the nearest integer.
The P(n,r) routine is based on the identity P(n,r) = n x (n-1) x (n-2) x ... x (n-r+1).
To use the C(n,r) routine, position the program counter at step 0 if it's not there already, key in n, hit enter, key in r and hit R/S.
To use the P(n,r) routine, position the program counter at step 25 (GTO 25), key in n, hit enter, key in r and hit R/S.
Accuracies (wrong didgits are underlined)
\hline Inputs & HP-12C & Wolfram Alpha \\\hline
15C5 & 3003 & 3003 \\\hline
36C7 & 8347680 & 8347680 \\\hline
90C7 & 747137556\underline{7} & 7471375560 \\\hline
101C6 & 126733992\underline{1} & 1267339920 \\\hline
70C8 & 94403509\underline{38} & 9440350920 \\\hline
425C23 & 5.9872995\underline{10}E37 & 5.987299532821716... E37 \\\hline
200C55 & 7.7183408\underline{23}E49 & 7.718340811430957... E49 \\\hline
335C167 & 3.044358\underline{801}E99 & 3.044358793146979... E99 \\\hline
\end{array}
\hline 25P7 & 2422728000 & 2422728000 \\\hline
99P5 & 8582777280 & 8582777280 \\\hline
100P45 & 7.35060259\underline{4}E84 & 7.350602595423500... E84 \\\hline
5000P27 & 6.94462245\underline{9}E99 & 6.944622452543926... E99 \\\hline
\end{array}
01 - ; X=n-r
02 lastx ; X=r, Y=n-r
03 X<>y ; for X and Y comparison in next step
04 x<=y ; would like to use X>Y? test to save previous step, but not available on 12C
05 x<>y ; place minimum of r and n-r in X
06 + ; X=n
07 sto 1 ; Store n in R1
08 lastx ; X=min(r,n-r)
09 sto 0 ; store in R0. Use as loop counter
10 1 ; Initial value is 1
11 sto 3 ; R3 = result register
12 rcl 0 ; X = loop counter
13 x=0 ; have we reached the end?
14 gto 22 ; if so, then exit
15 sto/ 3 ; update the result
16 rcl 1 ; recall next numerator factor
17 sto* 3 ; update the result
18 1 ;
19 sto- 0 ; decrement loop count
20 sto- 1 ; decrement numerator factor
21 gto 12 ; loop
22 rcl 3 ; place the result on the stack
23 intg ; take integer
24 gto 00 ; end
25 x<>y ; P(n,r) routine. X=n, Y=r
26 sto 0 ; Store n in R0
27 x<>y ; X=r, Y=n
28 - ; X=n-r
29 rcl 0 ; X=n, y=n-r
30 1 ;
31 - ; subtract 1 from X
32 x<=y ; are we done yet?
33 gto 36 ; if so, then display the result
34 sto* 0 ; update result
35 gto 30 ; loop
36 rcl 0 ; display the result
37 gto 00 ; end
Combinations
\begin{array}{|l|r|r|}\hline Inputs & HP-12C & Wolfram Alpha \\\hline
\end{array}
Permutations
\begin{array}{|l|r|r|}\hline 25P7 & 2422728000 & 2422728000 \\\hline
\end{array}
