08-16-2017, 05:16 AM
08-16-2017, 09:06 AM
(08-16-2017 05:16 AM)Gamo Wrote: [ -> ]Here is the HP 12C program to find Fibonacci Sequence accurate up to 40
Anyone have a better solution?
Gamo
Hi, for interest see posts #2 & #3 in this thread in the Software Library:
http://www.hpmuseum.org/forum/thread-835...i#pid73315
Best regards
08-16-2017, 04:38 PM
Your program implements an interesting formula that calculates the Fibonacci numbers directly instead of the usual approach with adding the two previous ones. I did not know this before, but it seems to be the Moivre-Binet formula:
\[F_n = \frac{1}{\sqrt{5}} \left [ \left ( \frac{1+\sqrt{5}}{2} \right )^n - \left ( \frac{1-\sqrt{5}}{2} \right )^n \right ] \]
A straightforward implementation does not require any registers and could be done like this:
01 ENTER
02 5
03 √x
04 1
05 +
06 2
07 /
ß8 1/x
09 x<>y
10 LstX
11 x<>y
12 y^x
13 x<>y
14 CHS
15 LstX
16 y^x
17 -
18 5
19 √x
20 /
21 INTG
22 GTO 00
(08-16-2017 05:16 AM)Gamo Wrote: [ -> ]Anyone have a better solution?
Since for n≥0 the second term is always less than 1/2 it doesn't have to be calculated. Simply round \(\frac{1}{\sqrt{5}} \left (\frac{1+\sqrt{5}}{2} \right )^n\) to the nearest integer. That's what the following program does.
01 ENTER
02 5
03 √x
04 1
05 +
06 2
07 /
08 x<>y
09 y^x
10 5
11 √x
12 /
13 .
14 3
15 +
16 INTG
17 GTO 00
On the 10-digit 12C this also works correctly up to n=40. Above that the results are a bit larger than expected because the 10-digit value of \(\Phi\) is slightly high while \(\sqrt{5}\) in the denominator is slightly low. That's also why the rounding function in the above code does not add 0,5 but 0,3.
BTW, using code boxes like this instead of attaching a PDF (which is only available after login) may be the better solution.
Dieter
02-15-2023, 05:32 PM
I have come to a code to run the Fibonacci Sequence with just 13 steps!
No data need to inupted in memories or registers, just add the code and press R/S
Please, add a star to the repo if you like, that means a lot to me:
https://github.com/joaomariowd/hp-12c
