Full Version: Inform2 or similar for 50g
Is there something like Inform2 (http://www.hpcalc.org/details/1890) for 50g? I have been browsing the hpcalc.org, but have not found similar.
Thx.
I thought this would be a good challenge to port to the 50g. I'm so close, but so far. It seems to be referencing a missing ROMPTR. It was ROMPTR B1 1C on the 48, which corresponds to library 177 command 28. But that must be different on the 49/50, because it's failing for me when I try to run the below code after compiling it.
In case anyone else wants to take a stab at it, my code follows (ready to assemble on Jazz on the 50g, followed by a call to CRLIB).
%%HP: T(3)A(D)F(.);
DIR
  INFORM2
 CK5&Dispatch
 # 35555
 ID x006
 # 35155
  ROT
  ONE{}N
  UNROT
  ID x006
  x001
 CK1
 DUPTYPELIST?
 NOT?SEMI
 DUPLENCOMP
 THREE
 ?SEMI
 INNERCOMP
 OVER
 TRUE
 EQUAL
 3PICK
 FALSE
 EQUAL
 OR
 ITE
  SWAP
  IT
   DUP
   ROLLDROP
   #1-
  SWAP
  ITE
  DROP
   #2-
   {}N
 {}N
  x002
 DUP
 CARCOMP
 DUP
 TYPECSTR?
 ITE
  DROP
  FALSE
  >TCOMP
  FALSE
  >TCOMP
  DO>STR
  SWAP
  INNERCOMP
  #1+
  {}N
  FALSE
  >TCOMP
  TRUE
  >TCOMP
  x003
 INNERCOMP
 DUP
 ZERO
 DO
 INDEX@
 #2+
 ROLL
 DUPTYPELIST?
 ITE
 ID x002
  DUP
  DO>STR
  SWAP
  TRUE
  TRUE
  FOUR
  {}N
 INDEX@
 #2+
 UNROLL
 LOOP
 {}N
  x004
 INNERCOMP
 DUP
 ZERO
 DO
 INDEX@
 #2+
 ROLL
 DUP
 FALSE
 EQUAL
 OVER
 TRUE
 EQUAL
 OR
 IT
  ITE
  %1
  %0
 ID x001
 INDEX@
 #2+
 UNROLL
 LOOP
 {}N
  x005
C$ 1387 ::
 3PICK
 ZERO
 DO
 ZERO
 ID x007
 ROLL
 DUP
 TAG CHECK
 %1
 EQUAL
 OVER
 TAG CHECK
 %0
 EQUAL
 OR
 ITE
  TAG CHECK
  %1
  EQUAL
  ZERO
  ID x007
  UNROLL
  ONE
  ID x007
  ROLL
  DROP
  ZERO
  ID x007
  PICK
  ONE
  ID x007
  UNROLL
  FIVE
  ID x007
  ROLL
  DROP
  MINUSONE
  FIVE
  ID x007
  UNROLL
  SIX
  ID x007
  ROLL
  DROP
  MINUSONE
  SIX
  ID x007
  UNROLL
  SEVEN
  ID x007
  ROLL
  DROP
  THIRTYTWO
  SEVEN
  ID x007
  UNROLL
  NINE
  ID x007
  ROLL
  SIX
  #MIN
  NINE
  ID x007
  UNROLL
  DUPTYPETAG?
  ITE
   DUP
   xOBJ>
   EvalNoCK
   $ "CHOOSE"
   EQUAL
   OVER
   TYPELIST?
   AND
   OVER
   NULL{}
   EQUAL
   NOT
   AND
   ITE
    ID x003
    FOUR
    ID x007
    UNROLL
    THREE
    ID x007
    ROLLDROP
    SEVENTEEN
    THREE
    ID x007
    UNROLL
    TWO
    ID x007
    ROLL
    FOUR
    ID x007
    PICK
    CARCOMP
    SWAPDROP
    TWO
    ID x007
    UNROLL
    ONE
    ID x007
    ROLL
    FOUR
    ID x007
    PICK
    CARCOMP
    SWAPDROP
    ONE
    ID x007
    UNROLL
    DROP
    FIVE
    ID x007
    ROLLDROP
    SEVENTEEN
    FIVE
    ID x007
    UNROLL
    SIX
    ID x007
    ROLLDROP
    MINUSONE
    SIX
    ID x007
    UNROLL
    SEVEN
    ID x007
    ROLLDROP
    TWELVE
    SEVEN
    ID x007
    UNROLL
    DROP
    ZERO
    ID x007
    UNROLL
   ZERO
   ID x007
   UNROLL
 LOOP
  x006
 ROMPTR B1 1C
 ROMPTR@
 NOT?SEMI
 DUP
 DoInputForm
 EQUALPOSCOMP
 #1-
 ONE
 SWAP
 SUBCOMP
 EVAL
 ID x005
 ROMPTR B1 1C
 ROMPTR@
 DROP
 DUP
 DoInputForm
 EQUALPOSCOMP
 OVER
 LENCOMP
 SUBCOMP
 EVAL
 DUP
 %1
 IT
  SWAP
  ID x004
  SWAP
  x007
 FIVE
 INDEX@
 THIRTEEN
  $CONFIG
 # 67B
 TOSRRP
  $VISIBLE {
INFORM2 }
  $HIDDEN {
x001 x002 x003 x004 x005 x006 x007 }
  $ROMID 1659
  $TITLE
"INFORM/EXTRA - MBW"
END
Wow. I would have imagined it would be a few lines of sysRPL and that it is.
(08-26-2017 05:55 PM)Vtile Wrote: [ -> ]Wow. I would have imagined it would be a few lines of sysRPL and that it is.
...and it looks like it's actually even more code. The ROMPTR call Eric references appears to be a wrapper around DoInputForm. INFORM2 pulls that entire routine onto the stack, executes all of it before the DoInputForm call, executes its own subroutine, then executes the remaining part of B1 1C. After that it does some more custom clean-up activity if the result wasn't canceled.
I suppose you could replicate all of that, but then you'd have to trace through the 9 or so other library calls B1 1C makes and replicate them as well (or find their equivalents in the 50g [if they even exist]). And who knows what else those routines call. It could take a while just to figure out what all you had to replicate.
Getting all of that to work successfully would probably be harder than simply learning how to do this in SysRPL on the 50g in the "normal" way. Smile
Seriously, though: I suspect the B1 1C routine doesn't exist on the 50g due to the newer InForm functionality that was added in later O/S revisions. It was apparently never a supported function, and it probably got revised to the point that it wouldn't be usable in this new context if it even still exists at all.
Eric: you'd probably be better off just trying to write your own version instead of retro-fitting INFORM2. It seems rather dependent on those library entries being present.
(08-26-2017 08:46 PM)DavidM Wrote: [ -> ]Eric: you'd probably be better off just trying to write your own version instead of retro-fitting INFORM2. It seems rather dependent on those library entries being present.
Yeah, after spending about an hour on it I realized it wasn't going to solve itself anytime soon so I gave up. Oh well.
Hello Eric,
Most likely it is
ROMPTR B1 1E
that you are looking for (the internal name is Ck&DoInForm).
However, Ck&DoInForm calls FLASHPTR IfMain instead of DoInputForm. As long as there is no message handling involved it should not matter and as far as I can see (I only had a quick look on it) there is no message handling involved.
I don’t have a machine ready with Jazz on the 50g, so I can not easily try this. But I am pretty sure, that this is the ROMPTR you are looking for and you should give it a try IMHO. (In case it does not work with IfMain than there is also the possibility to modify the code at run time and exchange it to DoInputForm – but you should give it a try first.)
The 49G ROM does indeed contains the whole old DoInputForm engine (GUISLV/GUIMES is entirely built around that) which is Lib # B0 and all its supporting libraries (which are # B1 # B3 # B4 # B5 # B9 # BA # BB # BC # BD # BE # BF).
There is even SX code in the 49G ROM!
IfMain (the newer engine) is totally independent from that (and has different and less message handling than DoInputForm).
However, due to the introduction of the FLASHPTR there was need for adding some ROMPTRs here and there, as not everything is in the same FlashBank.
And generally a FlashPtr call should be faster (and does not need TempOb RAM) than a ROMPTR call (the drawback is, that there is no RAM entry for FlashPtrs whereas there is a RAM entry for ROMPTRs).
In particular two ROMPTR were added to Lib # B1 in the 49G ROM. I did not check in detail which and where and leave this exercise to the reader.
HTH,
Andreas
