Hi
Is there a way to copy program from the Hepax RAM back to the HP-41
I do miss a HGETP as option to HSAVEP.
Sine I have a corrupt file in one Hepax RAM file on go41cx, I would like to get it back to the HP-41, so I can create a new RAM file and copy it back there.
(07-29-2017 04:53 PM)Jotne Wrote: [ -> ]Hi
I am not sure if this will work with a corrupt file... but normally the HP41 COPY function is designed to copy a FOCAL program from ROM to RAM. HEPAX treats programs in its RAM as ROM programs, so I think the standard COPY command should work here. If not, maybe some other expert on HEPAX can chime in!
Greg
Greg is correct here, COPY "PRG-NAME" will copy your program (PRG-NAME) from the HePaX RAM to main RAM.
Now if your HePaX RAM is corrupted, you can either
- with the help of the users manual file system information, use HEXEDIT to hopefully correct the invalid entries
or
- try to save all your programs & data from HePaX RAM to main/offline memory and then reset HePaX RAM
HePaX RAM brute force reset & assuming HePaX RAM are between page 8 and 11
- "OK"
- 8
- CLRAM
- 9
- CLRAM
- 10
- CLRAM
- 11
- CLRAM
- OFF
- ON
- HEPDIR (should give you the message H:DIR EMPTY)
Sylvain
It worked nice. I do have the program on other RAM, so I can make all back to one healthy module.
