06-26-2017, 09:37 AM
Hello
I bought recently a HP-48GX version P and it happens that this calculator sometimes hangs. Only have it for three days.
I have other HP-48GX version R and it almost never hanged (while normaling using it in UserRPL).
When the P version calculator hanged the first time, on the first day, I knew I was doing "strange" things, like passing whole directories from the version R calculator to the version P, in ascii, and the P version errored while parsing the ascii result. I thought it could be due to differences in the calculator versions.
Then I transfered the directories in binary and the transfer was ok. But after a while the calculator start hanging, and I thought it could be some memory corruption due to the transfer. I have checked the bug list for version P, and there are bugs in the transfer commands.
I reset the calculator, passed again lot of programs, and libraries, and it worked very well for a couple of days
but now, after a couple of days, it hanged again in the editor, while writing a user rpl program.
Is there any stability problem with version P? Or is this device malfunction?
I made all the ROM tests and they are all OK
