06-16-2017, 07:02 AM
(06-15-2017 08:09 PM)Geoff Quickfall Wrote: [ -> ]Well it's time to go from the beta board to a version V5. I am sure I can find some donor shells :-)
Ditto!
One for me, please.
(06-13-2017 07:57 PM)Gene Wrote: [ -> ]From Monte's site:
"Found out that the Flash memory devices used in the 41CL are Last-Time-Buy status. Need to decide how many more 41CL boards there might be."
So, how many new boards should be made if any ? Who wants one...? :-)
(06-15-2017 06:09 PM)Monte Dalrymple Wrote: [ -> ](06-13-2017 07:57 PM)Gene Wrote: [ -> ]From Monte's site:
The only reason that I noticed the EOL status was that I went to the distributor website looking at pricing for larger Flash devices for a possible V5 revision. They are also EOL. Revising the board for the next larger size is a trivial exercise, and I am in the "should I do it" phase. This would double the size of the Flash to 1024 pages, from the current 512, guaranteeing that we would never run out of space again. It turns out that the 18MHz crystal I use is already obsolete, but I think that there is a replacement available. I still need to check the other distributor for any other obsolete parts (the BOM is split between two distis.) This, plus the amount of interest I see, will determine if/when I do another run.
At the same time, I am also considering finally doing an assembly run for the clone of the Time module. I just need to verify the design on the breadboard before I pull the trigger. I'm hoping that there is still interest in that project also.
Monte
(09-19-2017 11:27 PM)Jlouis Wrote: [ -> ]I'm in for a one time module.
As for the board, I have some pretty basic questions:
1- How dificult is to assemble the board on the 41? Is there a step by step, with pictures, on how to do it?
2- I have a 41c fullnut with correded contacts, so this cl pcb comes with the battery contacts too?
3- All the modules are in the memory of the board or we'll have to install through a pc, in this case, how we suppose to make the connection (hp-IL + pil-box)?
I know these questions are pretty obvious for you, so forgive me to be so late to the party!
TIA
JL
(09-20-2017 03:14 AM)Neve Wrote: [ -> ]3- Yes, all the modules are already loaded onto the board. However, you can update the board or install new modules as they become available through either the serial interface that you can also order as an option (requires a bit of soldering and installation) or using the HP-IL—>PIL BOX, I guess. But, as I don’t have a CL board myself yet, I may be wrong about that.
