For real input the programme returns Floor of input without disturbing the stack.
Improvements most welcome.
0. LBL “F”
1. X>=0?
2. GTO O
3. STO F
4. FP
5. STO G
6. ABS
7. X≠0?
8. RCL/ G
9. RCL+ F
10. LBL O
11. IP
12. RTN
I'm not familiar with the 32S, but on the 42S I just solved this myself using the code in the picture (it's labeled "80" because I made it part of a KEYG/MENU structure). It did take me a while though, I'm only just getting used to RPN and its quirks.
attachment=4991]
Doesn't work for -0.999999999999 (-1 + 1e-12), or in general for
-9.9999999999x Eyyy, x=5..9, yyy>=-1
(both the 32S and 42S versions, BTW)
The easiest way without stack preservation is
>LBL "FLOOR"
RCL ST X (or ENTER X<>Y)
1
MOD
END
I don't have a 32S so I don't know what commands are available there.
For the 41/42S, one version with stack preservation is as follows:
>LBL"FLOOR"
IP
X<>Y
X<> ST L
X<Y?
DSE ST Y always skips
>LBL 00
X<> ST L
X<>Y
END
Cheers, Werner
(06-30-2017 07:05 AM)Werner Wrote: [ -> ]Doesn't work for -0.999999999999 (-1 + 1e-12), or in general for
Are you sure? I just tried, the 42S code works fine on Free42 and on the DM42.
I'm sure ;-)
Free42 and DM42 work with 34 digits, so there, take (-1 + 1e-34)
Werner
OK, you're right. "IP" after "+" isn't a good idea, so replace the sequence
with
and everything should be OK. Now even -1+10^-34 gives the right result on the DM42.
OK, I think I got the idea now. How about this:
> LBL "FLOOR"
IP
RCL- ST L
X>0?
DSE ST L
CLX
X<> ST L
RTN
LastX is not correct ;-) In my version above, it is.
Werner
You're right once again. The only thing I'd do differently is the "nop" command -- a label there is quite misleading and can lead to trouble when the code is part of a larger program, so I prefer "X<>X" in its place.
In any case, RPN is great. What I could have done with RPL in about five minutes now took me several days to grasp. But I did learn a thing or two.
X<> ST X is two bytes, and I have a label there for the CEIL function to jump to ;-)
{ 38-Byte Prgm }
>LBL"CEIL"
INT
X<>Y
X<> L
X>Y?
ISG Y always skips
X<=Y? nop
GTO 00
>LBL"FLOOR"
INT
X<>Y
X<> L
X<Y?
DSE Y always skips
>LBL 00 not a nop
X<> L
X<>Y
END
Cheers, Werner
