04-26-2017, 02:28 AM
Hi all,
I have posted a simulator for the HP-95C at http://www.teenix.org
This printing scientific calculator was never released by HP so it might be a bit of a novelty to try out.
The main features are the continuous memory and the ability to partition programs allowing up to 4 separate programs to be stored at once.
The simulator uses the HP97 microcode as its backbone so all calculations should work as expecting from this series.
The programming side (entering and running code) is all handled by the Windows program which hooks into the 97 microcode code when required. This proved to be quite difficult so there will probably be a bug or two that I missed.
The printer output has many differences to the 97 as well so a lot of this code is intercepted by the main program before the 97 gets to do any printing.
cheers
Tony
cheers
Tony
