04-14-2017, 07:28 PM
Source. I did not post this in the thread dedicated to my clumsy explorations because I thought it may be interesting to see it solved with as little "existing aid as possible" (I'm looking at you GCD) and on calculators that I regard as requiring more effort than the hp 50g to be coded (the ones that do not have a quick interface with the PC). In other words, let's say that one cannot use functions that are designed to produce exact output with flags -3 and/or -5 cleared.
If someone wants to propose variants / other inputs (maybe to test speed), that is welcomed.
my solution so far, I do use FACTORS as built in function, and nothing else hopefully. With GCD it would have been way shorter and faster.
Quote:Description
Simplify square roots in the form \( \frac{a \cdot \sqrt{b} }{c \cdot \sqrt{d}} \). A simplified radical should have no square roots in the denominator and no number in a square root should have a square factor. For example, the input 2 5 5 10 for a b c d, respectively, should simplify to 1 2 5 where a=1, b=2, and c=5.
Output description
a b c
(d should not exist after simplifying)
Challenge input
45 1465 26 15
Challenge output
15 879 26
%%HP: T(0)A(D)F(.);
@ alternative found online %%HP: T(3)A(R)F(.);
@ You may edit the T(0)A(D)F(.) parts.
@ The earlier parts of the line are used by Debug4x.
@ in npp, just select language "normal" to get rid of the highlight.
DIR
c20170412
DIR
factorsFsetUnset
@to set the flag and unset it around factors otherwise the main program
@is affected
@input, a number
@output, factors.
-3 CF
@exact mode
@the number should be converted now in exact mode
\->Q
FACTORS
-3 SF
@numerical mode
@ www.reddit.com/r/dailyprogrammer/comments/64y4cf/20170412_challenge_310_intermediate_simplifying/
@ Description
@ Simplify square roots in the form (a sqrt(b))/(c sqrt(d)). A simplified
@ radical should have no square roots in the denominator and no number in
@ a square root should have a square factorV. For example, the input 2 5 5
@ 10 for a b c d, respectively, should simplify to 1 2 5 where a=1, b=2,
@ and c=5. Output description
@ a b c
@ (d should not exist after simplifying) Challenge input
@ 45 1465 26 15
@ Challenge output
@ 15 879 26
@ Credit
@ This challenge was suggested by user /u/alchzh on
@ /r/dailyprogrammer_ideas, many thanks. If you have an idea, please share
@ it there and we might use it!
cRootSol
45. 1465. 26. 15. @ a b c d , for quick testing. reals.
0 @factorsListV1
0 @factorsListV2
0 @factorsListNumEl
1 @cdProd
1 @bdProd
1 @numeratorProd
1 @rootProd
0 @factorV
0 @multiplicity
0 @extrMultiplicity
0 @maxMultiplicity
0 @posV
10 @uFlag1
0 @sysFlags
@external input
a
b
c
d
@local var
factorsListV1
factorsListV2
factorsListNumEl
cdProd
bdProd
numeratorProd
@product outside the root at numerator
rootProd
factorV
multiplicity
extrMultiplicity
maxMultiplicity
posV
uFlag1
sysFlags
@output
@3: numerator value, outside the root
@2: numerator value in the root
@1: denominator value
RCLF 'sysFlags' STO
@set flags to avoid exact fractions
@we have to set, unset for factors,
-3 SF
-105 SF
@so we know that ( a sqrt (b) ) / ( c sqrt (d) )
@can be rewrtitten as
@[( a * sqrt (b) ) / ( c * sqrt (d) )] * ( sqrt(d) / sqrt (d) )
@giving back
@( a * sqrt (b*d) ) / ( c * d )
@from sqrt (b*d) we need to extract the proper factors. (and FACTORS is a good command)
c d * 'cdProd' STO
@we extract what can be extracted from the root
b d * factorsFsetUnset
@ now in the stack there is a list with factors and multiplicity.
OBJ\->
@list exploded
@ the number of elements is on the stack on level 1
'factorsListNumEl' STO
@save num elements
@we know that from an exploded list, the multiplicity is always in position
@after the factorV, so odd positions since the list is inverted.
@so we just consume the entries until we are finished
a 'numeratorProd' STO*
@we start to build the num prod
uFlag1 CF
@we use this flag to say if the multiplicity was big enough
@to extract a factorV.
1 factorsListNumEl
FOR counter
IF
counter 2 MOD
0 ==
THEN
@ we have an even position, so the factorV
'factorV' STO
@we continue to compute the rootProduct
factorV multiplicity ^ 'rootProd' STO*
@if the program is correct, the multiplicity of the factorV is 1 or 0
@within the root.
@we compute the external product
IF
uFlag1 FS?
THEN
uFlag1 CF
@for the next iteration
factorV extrMultiplicity ^ 'numeratorProd' STO*
0 'extrMultiplicity' STO
@reset
END
ELSE
@ we have an odd position, so the multiplicity
'multiplicity' STO
IF
multiplicity 2 \>=
THEN
@the factorV can be extracted
uFlag1 SF
@we mention this in the flag for the next operation
@ we collect how many times the factorV can be extracted
WHILE multiplicity 2 \>=
REPEAT
1 'extrMultiplicity' STO+
'multiplicity' 2 STO-
END
END
@multiplicity here is either 0 or 1.
END
NEXT
@now the product under the root is fine
@time to simplify the other two terms still using factors.
@GCD function avoided.
cdProd factorsFsetUnset 'factorsListV1' STO
numeratorProd factorsFsetUnset 'factorsListV2' STO
1 factorsListV1 SIZE
FOR counter
@factors in odd positions
@we get the factor
factorsListV1 counter GET 'factorV' STO
@we see if it exist in the other factorization
factorsListV2 factorV POS 'posV' STO
IF
posV 0 >
@compare the position
THEN
@if the position is non-zero, then the factor exists in
@both lists, so we can compare the multiplicity
@get the min multiplicity (I could use the GCD actually
@to make things faster)
factorsListV1 counter 1 + GET
factorsListV2 posV 1 + GET
MIN
@ we get the min factor multiple for both numbers
factorV SWAP
@2: factorV
@1: min multiplicity
@we divide the numbers
DUP
@ 2: factor^minMultiplicity
@ 1: factor^minMultiplicity
'cdProd' SWAP
@ 3: factor^minMultiplicity
@ 2: 'cdProd'
STO/
'numeratorProd' SWAP
@ 2: 'numeratorProd'
STO/
END
2 STEP
@output
numeratorProd
rootProd
cdProd
sysFlags STOF
END
END
