04-03-2017, 08:38 AM
Reading old discussions I stumbled on one that reports that the Jazz compiler/builder for sysRPL can tell the user if there is a syntax error and on which line.
Instead when I use userRPL and I pass a program to the calculator in text mode, getting back a "syntax error", the information given back are much more cryptic and often not helpful. (especially for files that in origin are 21 Kbytes and at the end -after trimming the comments - are 3 Kbytes)
So I normally end up toggling large part of a program as "comments" until I identify the part with the unwanted error.
Is there a way to get more information about the syntax error message? That would speed up a part of debugging.
