... with visual feedback. Probably the simplest program so far, it's a key definition.
// Cycles over entry mode options.
KEY K_On()
LOCAL an:={"Textbook","Algebraic","RPN"};
Entry:=(Entry+1)MOD3;
STARTVIEW(-8,1); // Out to ANY AVAILABLE view...
STARTVIEW(-1,1); // ... and back in, to refresh
TEXTOUT_P(an(Entry+1),G0,2,207,2,RGB(255,0,0));
Very simple.
VERY useful.
VERY NICE!
Thanks for sharing.
+2 Simple and powerful - well done
How do you run this? I'm new to running HP Prime programs.
Thanks!
(05-10-2014 05:16 AM)darwin513 Wrote: [ -> ]How do you run this? I'm new to running HP Prime programs.
Thanks!
Once you have copied the program in the Program Catalog, activate the user keyboard by pressing SHIFT HELP ("1U" will be displayed when activated), then press the customized key, ON in this case. More info: User Guide page 516. Easy as π.
(05-11-2014 12:21 AM)Cristóbal De Jesús Wrote: [ -> ] (05-10-2014 05:16 AM)darwin513 Wrote: [ -> ]How do you run this? I'm new to running HP Prime programs.
Thanks!
Got it working, thank you!
Meaner, leaner, tighter (and works with the latest firmware)...
KEY K_On()
Entry:=(Entry+1) MOD 3;
STARTVIEW(-1,1); // Refresh Home view BEFORE tagging...
FREEZE; // the mean part!
Thank you very much Cristobal, still very useful.
Bonjour
C'est une excellente idée, si je peut proposer une petite
amélioration ?
Pour les différentes langues disponibles.
Hello
It's a great idea, if I may offer a small
improvement ?
For the available languages .
KEY K_On()
STARTVIEW(-1,1);
TEXTOUT_P(STRINGFROMID(1903+Entry),G0,2,207,2,RGB(255,0,0));
FREEZE;
(05-05-2016 11:11 AM)Tyann Wrote: [ -> ]
KEY K_On()
STARTVIEW(-1,1);
FREEZE;
Your English is fine and your code is clever!
(05-05-2016 11:11 AM)Tyann Wrote: [ -> ]Bonjour
amélioration ?
Hello
improvement ?
KEY K_On()
STARTVIEW(-1,1);
FREEZE;
Great! Thanks for the improvement, I learned something new today.
Here is a popup version.
It will fill in based on the user's preferred language.
//Popup selection of Entry method
// To run: Shift:Help:On
// String in language of user
Key K_On
LOCAL epick, title, entry1, entry2, entry3;
title := STRINGFROMID(1902); //"Choose entry method"
entry1 := STRINGFROMID(1903); //"Textbook"
entry2 := STRINGFROMID(1904); //"Algebraic"
entry3 := STRINGFROMID(1905); //"RPN"
CHOOSE(epick,title, entry1, entry2, entry3);
Entry := epick - 1;
