Full Version: Article - 42.86% responded “Yes” on an opinion poll. How many people responded?
The answer is
Quote:0.4286 Enter XQ Enter
Big Grin Tongue sry. I couldn't resist. The article is a good read.
Thank you.
The Joe Horns article is on article section of the forums with real answers.
http://www.hpmuseum.org/forum/thread-7984.html
(03-21-2017 03:43 PM)Vtile Wrote: [ -> ]The answer is
Thank you.
When I type 0.4286 XQ on my 50g I get 2143/5000, which is not the answer sought by the article. Perhaps you have your machine in 2FIX or 4FIX mode? I keep mine in STD mode. Regardless, the XQ function only uses the simple continued fraction algorithm, which fails to obtain the best solution much of the time, as explained in the PDQ Algorithm posting.
I think the question is wrong, it should be "What is the minimum people who responded?"
Yes: 3
No: 4
From 7 people, 42.85714286% of the people answered Yes.
(03-22-2017 09:19 AM)eried Wrote: [ -> ]I think the question is wrong, it should be "What is the minimum people who responded?"
That's exactly the point that Chapter 3 of the article makes. It starts off explaining how most people ASSUME that more people were polled than necessary, and then the 3rd paragraph says, "So the question becomes: What is the smallest number of respondents which can make such a ratio possible?" The article thus points out the necessity of changing the assumed question into the more accurate question. So, as you can see, the article agrees with you.
(03-22-2017 11:56 AM)Joe Horn Wrote: [ -> ]That's exactly the point that Chapter 3 of the article makes. It starts off explaining how most people ASSUME that more people were polled than necessary, and then the 3rd paragraph says, "So the question becomes: What is the smallest number of respondents which can make such a ratio possible?" The article thus points out the necessity of changing the assumed question into the more accurate question. So, as you can see, the article agrees with you.
Ups, sorry! I checked the pdf in the phone without much care. I thought this question was not answered in that article Big Grin
^^ That is the reason of the bold note to look the real answer from the article..
@Joe, yes I use 4 decimal engineering notation. It happens to give the answer you end up with arguments in the article.
It is a good read.
(03-22-2017 01:49 PM)Vtile Wrote: [ -> ]^^ That is the reason of the bold note to look the real answer from the article..
It is a good read.
Yes, I see that now. I was just eager for any challenge, I guess Smile
What if, 30.10335917% responded "Yes" on an opinion poll. How many people responded?
(03-22-2017 02:40 PM)eried Wrote: [ -> ]What if, 30.10335917% responded "Yes" on an opinion poll. How many people responded?
Minimum: 233 out of 774. Maximum: currently approximately 2254741602 out of 7.49 billion. Smile
(03-22-2017 02:51 PM)Joe Horn Wrote: [ -> ]
hahaha! correct Big Grin
..And the silly fools method.
7 ENG
Enter
XQ
Enter
Big Grin
(03-22-2017 03:15 PM)Vtile Wrote: [ -> ]..And the silly fools method.
7 ENG
Enter
XQ
Enter
Big Grin
Yep, XQ even works for this example in STD mode! Ok, so my next quest is for an example that works as shown in the article and FAILS for XQ (and →Q) in EVERY display setting....
AHA! I think I found one: 71.45%. The simplest ratio that rounds to 71.45% is 388/543, but that's not returned by XQ or →Q in any display setting. So there. Big Grin
Here's how to work it out using the article's method:
0.71445 = {0, 1, 2, 1, 1, 123, 1, 1, 1, 7} (continued fraction)
0.71455 = {0, 1, 2, 1, 1, 76, 1, 1, 1, 5, 2}
Truncated where they begin to differ plus 1 =
{0, 1, 2, 1, 1, 77} = 388/543
Or, using PDQ: 0.7145 0.00005 PDQ --> 388/543.
EDIT: Wow, there are many such examples. Try 10.1%. Or even 1%. Golly.
Oh that's interesting. Thanks for the contribution!
I don't have the prime, does someone has the program for the 50g? Although XQ should be there.
Then an extension of the question: one has the percentage of Yes but also the number of yes over the no.
So one has:
yes / ( yes + no )
and
yes - no = number
How many yes and no are required for this?
This is a common case in sites with like/dislike. For example reddit: https://www.reddit.com/r/math/search?q=s...rict_sr=on
Taking one result at random:
https://www.reddit.com/r/math/comments/5...questions/
Now reddit masks a bit the votes at every refresh(but not the ratio of likes/dislikes), but nevertheless one can try.
Yes - no = 62
Yes% = 94
How many 'yes', how many 'no'? (minimum of course)
The numeric solver on the hp 50 g returns (I translated in fraction) yes 1457/22 and no 93/22 . It may be not possible to get integers that solve the system above, maybe due to the reddit masking of numbers.
(03-23-2017 09:02 AM)pier4r Wrote: [ -> ]I don't have the prime, does someone has the program for the 50g?
If you are referring to PDQ, it's here (read PDQ.TXT first): http://holyjoe.net/hp/PDQ.zip
(03-24-2017 06:40 AM)Joe Horn Wrote: [ -> ]If you are referring to PDQ, it's here (read PDQ.TXT first): http://holyjoe.net/hp/PDQ.zip
Many thanks, why do you not share it in the software library or on hpcalc.org ? Already the readme is way better than many other programs.
