03-28-2017, 09:32 PM
experiences using the EQW. Is the following a known bug or there is there a reason for the error? (three powers one over the other are refused, if split with parentheses , they are computed)
(03-28-2017 07:32 PM)Han Wrote: [ -> ](03-28-2017 06:13 PM)pier4r Wrote: [ -> ]Could you explain (or hint a known relationship) how did you get that d/2+x = d/2*sqrt(2) ?
The right picture can be worth a 1000 words, as they say :-)
(03-29-2017 07:54 AM)Dieter Wrote: [ -> ]Right you are!
The following picture should say it all.
(03-29-2017 11:04 AM)pier4r Wrote: [ -> ]Thanks Simone.
Anyway, following the recent pattern, I guess I'm missing something obvious here. I can determine almost all the angles but not the wanted ones.
Furthermore I do not even have a clue how can I employ the 50g to help me (until now I had some pseudo-working directions on the previous problems)
http://i.imgur.com/fWE9736.jpg
(03-29-2017 11:31 AM)Han Wrote: [ -> ]Have you considered the sum of the angles in a triangle and a quadrilateral, and properties of vertical angles?
(03-29-2017 08:48 AM)pier4r Wrote: [ -> ]Neat image, which tools did you use?
(03-29-2017 11:49 AM)pier4r Wrote: [ -> ](03-29-2017 11:31 AM)Han Wrote: [ -> ]Have you considered the sum of the angles in a triangle and a quadrilateral, and properties of vertical angles?
Yes I considered the angles in a triangle (180) and quadrilateral (360), I considered that an angle is the same when opposite or the complementary that have a sum of 180. Unless I missed some internal shape, I got all the possibilities of which I'm aware of.
What I did see after your question is the concave pentagon. And maybe this will help.
(03-16-2017 11:06 AM)Logan Wrote: [ -> ](03-15-2017 11:56 PM)Thomas Okken Wrote: [ -> ]in fact, many such problems are notoriously difficult, for example:
find a, b, c, n such that
a^n + b^n = c^n
It's trivial to find solutions to this, but if you add these conditions:
a, b, c, n ∈ N
a, b, c > 0
n > 2
It's suddenly a lot harder. :-)
That's not hard, I could write down my marvelous little proof but this text box is too narrow.
%%HP: T(0)A(D)F(.);
@ You may edit the T(0)A(D)F(.) parts.
@ The earlier parts of the line are used by Debug4x.
@ in npp, just select language "normal" to get rid of the highlight.
@ Objective:
@ - We want to compare the expected performances of teams of a certain
@ average strength in some types of tournaments to determine
@ what is the one that determines the best team.
@ Assuming that the best team is the one to which is given higher strength
@ a priori. Of course the simulation of the tournaments
@ should be done some times to determine the percentage of winning for each team.
@ 1. round robin. Every team meets everyone else, at least twice.
@ (it could be extended with four times, six and so on)
@ Often used in long tournaments.
@ This is assumed as the best format and will be used as reference.
@ 2. swiss tournament
@ Random pairings, and then teams with high score meet other teams
@ with high score, if possible avoiding pairings already done.
@ The minimum is that teams meet once.
@ Often used in chess, short but maybe effective.
@ 3. knockout tournaments. Random pairing at the start and then
@ the ones that wins proceed.
@ Often used in "show tournaments", short but maybe not so effective.
@ 4. only one match against all the others (like half of a round robin)
@ Often used in show tournaments. Short but maybe not so effective.
@ Remarks: the comments try to give an idea, the values in the comments may
@ be different from the actual code though.
@TODO: to pass variables between programs, try to use the compiled local variables.
@ so one does not have persistent variables after the execution.
@ Although it is not so bad to have global variables and modifying them for the next
@ trial. It is like using inputs, without having to type them on the stack.
DIR
main
0 @tmpV to use for short time, value can be changed in other functions!
0 @tmpV2
0 @rrResArr
0 @rrResList (not sure what I'll use)
@external inputs
@local var
tmpV
tmpV2
rrResArr
rrResList
@creating/updating global variables
@to use among programs without too much passing
@of values
'n*25+1200' 'n' 1 16 1 SEQ 'listTeams' STO
@ list of teams with a priori strength score
listTeams SIZE 'numTeams' STO
'0' 'n' 1 numTeams 1 SEQ 'finalTournResList' STO
creMatrVarProb
@Eval not needed when calling globals
1 maxTournRepV
FOR counter
rrFunc
DUP @leaving a copy of the final list of rrFunc
@using the list returned by rrFunc
updWinList
NEXT
finalTournResList
@of values
@remark: to recall and put in local var only when speed is needed.
@flag for team A winning
uFteamAwon
10
@temp flag, not possible to expect to persist
@in different block executions
uFtmp
20
@flag for finding a probability
uFmatchingProbFound
30
listTeams
{ 0 }
numTeams
0
@max cumulative probability
maxSumProbV
0
@number of possible choices or probabilties
numProbV
0
@column for cumulative probability values
colSumProb
1
@column for single probabilities
colProb
2
@column for variance result
colVar
3
@final matrix with cumulative probability, probability, variance results.
mVarProb
0
@points assigned for a win
pointsForWin
1
@repeating the same tournament type to get the winners.
maxTournRepV
1000
finalTournResList
0
@end globals
creMatrVarProb
@createMatrixWithVarianceAndProbability
0 @tmpV
0 @tmpV2
@external inputs
@local var
tmpV
tmpV2
@ creating the matrix containing the probability of the points. Variance
@ between -400 points and +400 points
@ every drop or increment of the base strength is made in 25 points.
@ those points have a probability. So I assign "probability tokens" at every
@ change. For example.
@ -400 has 25 prob tokens. -375 has 50, -350 has 75 and so on, until the
@ base value then goes back. +25 has 400 tokens, +50 has 375 and so on.
@ so I want to model those tokens.
'n' 'n' 25 400 25 SEQ
425 +
@ expanding the previous list with 425
'n' 'n' 400 25 -25 SEQ
@ Or REVLIST could have been used.
+ 'tmpV' STO
@ storing the list
@ the complete list now goes from 25 to 425 and back to 25.
@ Now we want to create the sum of all those tokens,
@ one value for each token, We can use STREAM but we need to recall
@ objects from the tack. I do not like stack operations because
@ they are unreadable but when they are a few it is ok.
@ otherwise one should comment the actions that they do.
1 'tmpV2' STO
@ counter, it needs to start from 1.
tmpV
@ having 25 50 75 100
@ STREAM 25 2 Pick 25 + 25 STREAM 25 Pick 2 25 + 25 STREAM 25 Pick 2 25 + 25
@ 50 50 75 75 75 75 75 75 75
@ 25 75 75 150 150 150 150
@ 75 100 100 250
@ 150
2 PICK
1 'tmpV2' STO+
@we need to count the objects that we leave on the stack. Plus 1 added at the start.
STREAM
@now we have the list with all the sums
@before making a vector out of it we save the last value that is the maximum value.
DUP 'maxSumProbV' STO
@we continue
tmpV2
@ the number of objects.
\->ARRY
@ transformed in a vector
tmpV
@ the first list
OBJ\->
@ exploded
@before saving it as vector I save the number of elements or
@probility tokens (equals to variances)
DUP 'numProbV' STO
\->ARRY
'n' 'n' -400 -25 25 SEQ
0 +
'n' 'n' 25 400 +25 SEQ
+ OBJ\->
@ added and then exploded
\->ARRY
3 COL\-> 'mVarProb' STO
@final matrix with columns: sum of probability tokens, probability tokens for variance, variance in points.
@output
getVarFunc
@program to extract the variance out of the built matrix
@output, the variance of the strength points out of the matrix
0 @curProbV
0 @tmpV
@external inputs
@local var
curProbV
tmpV
maxSumProbV RAND * 1 + IP 'curProbV' STO
@ we get a random vnumber that has to be compared with the probability sums
1 'tmpV' STO
@with tmpV we will use it as a counter
uFmatchingProbFound CF
WHILE
uFmatchingProbFound FC?
tmpV numProbV \<=
AND
REPEAT
IF
curProbV 'mVarProb(tmpV, colSumProb)' EVAL \<=
@accessing the matrix in algebraic mode, slower but more readable.
@ than the messy RPN (RPN is not always less readable, but in some cases)
@maintenance and debug use resources as well that often are more valuable.
THEN
@ found a probability sum bigger than the actual random value.
uFmatchingProbFound SF
ELSE
1 'tmpV' STO+
END
END
'mVarProb(tmpV, colVar)' EVAL
matchResFunc
@program to compute the result of a match based on the variance and probability of it.
@ should be used by all the tournaments.
0 @teamAtmpV
0 @teamBtmpV
@external inputs
teamAstrV
teamBstrV
@local var
teamAtmpV
teamBtmpV
@In input are expected the strength of the two teams
@ and a user flag for the result
@as for of variables already existing.
@teamA
@teamB
@userFlagNumber
@in output a flag is set
@if teamA won, otherwise teamB
uFteamAwon CF
@ teamA streangth modified
teamAstrV getVarFunc
+ 'teamAtmpV' STO
@ teamB streangth modified
teamBstrV getVarFunc
+ 'teamBtmpV' STO
@there is no draw possible, at least for now.
IF
teamAtmpV teamBtmpV >
THEN
@teamA won.
uFteamAwon SF
ELSE
@ teamA with lower or equal strength
IF
teamAtmpV teamBtmpV <
THEN
@teamA lost
uFteamAwon CF
ELSE
@ same strength
@ coin toss
IF
RAND 10 * IP
5 <
THEN
@teamA won
uFteamAwon SF
ELSE
@teamA lost
uFteamAwon CF
END
END
END
IncListElFunc
@ program to increase the value of element in a list
@ input on the stack see variables
@ see the following, that if I keep adding variables on the main
@ program it gets too unreadable.
@output, the list in input, modified, on the stack
@external inputs
lList
@list
lPosV
@position of the element
lincV
@increase
@local var
lList lPosV
@placing list and position on the stack
@for storing, later.
lList lPosV GET
lincV +
@getting the value and increasing it
PUT
@putting the increasing value back
updWinList
@program that updates the winner list given the
@last tournament result list
0 @maxV
0 @tmpV
0 @tmpList
lastTresList
maxV
tmpV
tmpList
uFtmp CF
@we use it to determine if we are done
lastTresList SORT REVLIST 'tmpList' STO
@to find the maximum quickly
WHILE
uFtmp FC?
REPEAT
tmpList HEAD 'tmpV' STO
IF
tmpV maxV \>=
THEN
@valid new max
tmpV 'maxV' STO
@make tmpList smaller.
tmpList TAIL 'tmpList' STO
@increase the value in the position of the team with highest value
@ and saving.
finalTournResList
lastTresList maxV POS
1
IncListElFunc
ELSE
@we are done
uFtmp SF
END
END
rrFunc
@program to compute a round robin tournament
0 @rrResList
0 @teamAstrV
0 @teamBstrV
@external inputs
@numTeams
@listTeams
@pointsForWin
@uFteamAwon
@local var
rrResList
teamAstrV
teamBstrV
@ given a list of teams with their strength and other
@already named and set variables.
@output, the list of teams with final points.
SEQ 'rrResList' STO
@saving the result list that at the start is just zeroes
1
numTeams 1 -
FOR teamPosA
listTeams teamPosA GET 'teamAstrV' STO
@get first team
teamPosA 1 +
numTeams
FOR teamPosB
listTeams teamPosB GET 'teamBstrV' STO
@get second team team
@compute the result of a match. twice
@as round robin requirement.
1 2
FOR counter
teamAstrV teamBstrV
matchResFunc
IF
uFteamAwon FS?
THEN
@update results
rrResList teamPosA pointsForWin
IncListElFunc
'rrResList' STO
ELSE
@update results
rrResList teamPosB pointsForWin
IncListElFunc
'rrResList' STO
END
NEXT
NEXT
NEXT
rrResList
@directory end
END
@ log {
@ 20:59 29.03.2017 {
@ After the discovery of the DIR END structure, I'm going to refactor the program.
@ 12:05 29.03.2017{
@ Generating list of 16 teams between 1200 and 1600 strength points
@ 'n*25+1200' 'n' 1 16 1 SEQ
(03-30-2017 08:30 AM)pier4r Wrote: [ -> ]My Hp 50g is actually computing since 10+ hours (and I dread that it will take days to finish) so I cannot readily try the suggestions of Han.
(03-29-2017 06:15 PM)Han Wrote: [ -> ]So \(\angle BED\) , \(\angle BDE \), \( \angle CDE \) and \( \angle AED \) should be the only angles whose measure you cannot determine directly from the properties mentioned. What if you set up an appropriate system of equations involving these angles?
(03-30-2017 12:26 PM)Dieter Wrote: [ -> ](03-29-2017 06:15 PM)Han Wrote: [ -> ]So \(\angle BED\) , \(\angle BDE \), \( \angle CDE \) and \( \angle AED \) should be the only angles whose measure you cannot determine directly from the properties mentioned. What if you set up an appropriate system of equations involving these angles?
I have tried this as well. Let <BDE = u, <BED = v, <CDE = x and <AED = y and it is possible to set up several linear equations, for instance...
u + v = 162
x + y = 111
u + x = 132
v + y = 141
...but I cannot get four independent ones, so there is no solution for a linear equation system. What do you get?
Dieter
u + v = 162
x + y = 111
u + x = 132
v + y = 141
Dieter
(03-30-2017 12:13 PM)Dieter Wrote: [ -> ]?!? – *what* is it computing?
Obviously this in not related to the triangle problem we are discussing.
Dieter
(03-30-2017 05:47 PM)Gerson W. Barbosa Wrote: [ -> ]That's what I'd done too, but the solution is very simple, I realize now. No need to solve any linear system.
Quote:PS: From E draw a perpendicular line to line AB, which intercepts it at F. Now we have two similar right-triangles: BEF and EFD. Angle DEF = angle EBF = 18 degrees, as we already know. Angle BDE, which you have named 'u' is its complement, 72 degrees. Finally, angle EDC, or your 'x', can be easily determined as 180 - 72 - 48 = 60 degrees.
