02-09-2017, 02:49 PM
I made a small program for calculating voltage dividers. It allows the calculation of both resistors and the input and output voltage.
The program works similar to the TVM program on the advantage module: It starts with displaying a menu
which is mapped to the top row of keys (A/B/D/E). To enter a value for one of the four variables, simply type in the value and press the corresponding button. To calculate one of the four variables after entering values for the others, press the corresponding button without entering a value before. To show the menu again, press J. This will not work if any of the keys A,B,D,E or J has assigned functions, as the program uses the user mode for the "softkeys".
If any of the values should be changed, you do not need to re-enter all values - simply enter the new value followed by the appropriate softkey and then press the key for the desired variable again.
Please note that this program is made for ease of use and is certainly not the smallest possible.
Example 1: Calculate R1 if U_in is 10V, U_out should be 3V, and R2 is 5kOhm
Example 2: Calculate U_out if U_in is 5V, R1 is 5kOhm and R2 is 10 kOhm. Same if input voltage is 10V.
Example 3: Find a good resistor pair to divide 5V to 3.3V
Here is the program. It has 77 steps in 22 registers and fits on one magnetic card, using both sides. It uses storage registers 01 to 04.
U_in --+
R1
+--- U_out
R2
GND ---+--- GND
R1 R2 UI UO
Input Output
XEQ RDIV R1 R2 UI UO (Menu)
10 D U.IN=10.000 (Set U_in to 10V)
3 E U.OUT=3.000 (Set U_out to 3V)
5 EEX 3 B R2=5,000.000 (Set R2 to 5kOhm)
J R1 R2 UI UO (Menu, optional)
A R1=11,666.667 (Calculated optimal value for R1)
Input Output
5 D U.IN=5.000 (Set U_in to 5V)
5 EEX 3 A R1=5,000.000 (Set R1 to 5kOhm)
10 EEX 3 B R2=10,000.000 (Set R2 to 10kOhm)
E U.OUT=3.333 (Calculated output voltage)
E U.OUT=6.667 (new output voltage)
Input Output
10 EEX 3 B R2=10,000.000 (Set R2 to 10kOhm as a guess)
3.3 E U.OUT=3.300 (Set U_out to 3.3V)
A R1=5,151.151 (Calculated optimal value for R1)
5.1 EEX 3 A R1=5,100.000 (as 5.1kOhm is the next standard value, select this as R1)
E U.OUT=3.311 (If the standard valued resistor is used, the voltage will be 3.311V which should be ok for most uses)
01 LBL "RDIV"
02 LBL J
03 SF 27
04 CF 22
05 "R1 R2 UI UO" (two spaces in the middle)
06 PROMPT
07 GTO J
08 LBL A
09 "R1"
10 STO 03
11 FC?C 22
12 XEQ 33
13 GTO 99
14 LBL B
15 "R2"
16 STO 04
17 FC?C 22
18 XEQ 44
19 GTO 99
20 LBL D
21 "U.IN"
22 STO 01
23 FC?C 22
24 XEQ 11
25 GTO 99
26 LBL E
27 "U.OUT"
28 STO 02
29 FC?C 22
30 XEQ 22
31 GTO 99
32 LBL 11
33 RCL 02
34 RCL 03
35 *
36 RCL 04
37 /
38 RCL 02
39 +
40 STO 01
41 RTN
42 LBL 22
43 RCL 01
44 RCL 03
45 RCL 04
46 +
47 /
48 RCL 04
49 *
50 STO 02
51 RTN
52 LBL 33
53 RCL 01
54 RCL 02
55 -
56 RCL 04
57 *
58 RCL 02
59 /
60 STO 03
61 RTN
62 LBL 44
63 RCL 03
64 RCL 02
65 *
66 RCL 01
67 RCL 02
68 -
69 /
70 STO 04
71 RTN
72 LBL 99
73 "꜔=" (append =)
74 ARCL X
75 PROMPT
76 GTO J
77 END
