02-07-2017, 11:25 AM
Updated version of the SIROM Module is available.
Short on the heels of a nested implementation of FINTG for double integrals, it is now also possible to use FROOT in a recursive scheme to resolve systems of 2 equations (linear or not).
The module includes the original SOLVE and INTEG (renamed as FROOT and FINTG), plus several other FOCAL routines for root-finding and integral calculations. Three housekeeping MCODE functions are included to manage the nested configurations: RESET, CLOAK, and EXPOSE - all completely transparent to the user, refer to the examples provided in the ROM for utilization details.
FOCAL programs for double integrals and systems of 2 equations are also thrown in so you can compare the methodologies.
Several application examples are included, like Sine & Cosine Integrals, Error Function, Inverse Normal Probability, Fourier Coefficients, Bessel J(n,x), Integral of Bessel J(n,x), and Zeros of Bessel J(n,x) for integer orders.
Here's the QRG for the ROM contents - 41 FAT entries in total:
The routines are not fast, their interest is in the methodology - not optimized for speed to say the least. If you need faster response then the SandMath provides dedicated MCODE for many of these and yet some more.
Using the 41-CL or turbo mode on emulators is highly recommended.
A manual will follow - early adopters can get started with the MOD file attached.
PS. The recursive root finding in "FRT2" requires the Library#4 module also plugged in.
# Name Description Instructions
00 -SOLINTG 2D Section Header n/a
01 FINTG HP's INTEG Fnc in Alpha, a^b in Stack
02 FROOT HP's SOLVE Fnc in Alpha, a^b in Stack
03 SILOOP Solve/Integ Loop n/a
04 "SIRTN" Solve/Integ RTN n/a
05 "2DITG" 2D Integration Step in R10, limits in stack
06 "FITG2" Recursive FINTG "FName", in Alpha, limits in stack
07 "*2D" Auxiliary for FITG2 n/a
08 "FRT2" Recursive FROOT "F1,F2" in Alpha, limits in stack
09 "*FG" Auxiliary for FRT2 n/a
10 "SYS2" Non-linear 2-eq system Prompts for data
11 "SLV" PPC's Solve FNC in ALPHA, a^b in stack
12 ASWAP Alpha Swap around comma "A,B" in Alpha
13 CLAC CLA from comma "A,B" in Alpha
14 CLOAK Nest SIROM buffer within nested loop
15 EXPOSE Undo Nested Buffer within nested loop
16 RESET Prepare Nested Buffers in main loop
17 -APPLIED Free registers finder returns # available regs
18 "2DF1" Example 1 for 2DITG x in R01, y in X
19 "2DF2" Example 2 for 2DITG x in R01, y in X
20 "2DF3" Example 3 for 2DITG x in R01, y in X
21 "F1XY" Example 1 for FINTG2 x in X, y in R01
22 "F2XY" Example 2 for FINTG2 x in X, y in R01
23 "F1" Example 1-1 for FRT2 x in R01, y in R02
24 "F2" Example 1-2 for FRT2 x in R01, y in X
25 "FF" Example 2-1 for FRT2 x in R01, y in R02
26 "GG" Example 2-2 for FRT2 x in R01, y in X
27 "CI" Cosine Integral argument in X
28 "ERF" Error Function argument in X
29 "FOURN" Fourier Coefficients Prompts for data
30 "ITJB Integral of J Bessel n in Y, x in X
31 "JYX" Bessel J (int. order) n^x in stack, F00 clear(!)
32 "Q-1" Inverse Probability P(x) in X
33 "SI " Sine Integral argument in X
34 "ZJYX" Zeros of Bessel J Prompts for order
35 "*C" Integrand Fnc. n/a
36 "*E" Integrand Fnc. n/a
37 "*FN" Integrand Fnc. n/n
38 "*JN" Integrand Fnc. n/a
39 "*Q" Integrand Fnc. n/a
40 "*S" Integrand Fnc. n/a
