Paul Dale sent me text, in other of the threads, that included a Greek character. I looked at the source code and was able to determine that it is related to information found in
ShareLaTeX web site. The raw text code used in this web site is a variant of the codes listed in ShareLaTeX. Is there a document or web site that spells the exact character codes for Greek letters (lowercase and uppercase), math symbols and operators, and other symbols, that can be applied to messages in this web site?
For example:
Generates the uppercase Greek Phi character \( \Phi\).
Likewise:
Generates the lowercase Greek Phi character \( \phi\).
Namir
(12-26-2016 03:08 PM)Namir Wrote: [ -> ]Paul Dale sent me text, in other of the threads, that included a Greek character. I looked at the source code and was able to determine that it is related to information found in ShareLaTeX web site. The raw text code used in this web site is a variant of the codes listed in ShareLaTeX. Is there a document or web site that spells the exact character codes for Greek letters (lowercase and uppercase), math symbols and operators, and other symbols, that can be applied to messages in this web site?
First of all, his forum supports MathJax, with a syntax similar to Latex. This allows inserting complex formulas as well as single special characters. MathJax expressions start with backslash + open bracket and end with backslash + closing bracket. I am sure you will find a MathJax reference somewhere on the web. Most of the special characters on the site you linked to should also be possible in MathJax.
Second, this forum also supports Unicode. On a Windows system, simply execute "charmap", select "Unicode" and insert any character you like, for instance a greek Phi: uppercase Φ as well as lowercase φ. For a first impression of what can be done in Unicode take a look at
this post.
Dieter
