12-04-2016, 02:32 PM
12-05-2016, 05:19 PM
Congratulations Tetris into the third dimension https://en.wikipedia.org/wiki/Blockout I
Idea
Pressing the [help] key displays a dialog box
Idea
Quote:Up/Down/Left/Right - move ↑↓←→
Home - move down along the Z axis (Home - Go to the bottom)
A/F - rotate aroun the X-axis ⇈⇊
B/G - rotate aroun the Y-axis ⇉⇇
C/H - rotate aroun the Z-axis ↺↻
Esc - exit
Help - this screen
After exit press View to restart.
If you can't rotate - move by Up/Down/Left/Right/Home
12-05-2016, 09:07 PM
I updated the program in line with suggestions from compsystems.
12-07-2016, 04:08 PM
Please also include gray transparency.
Thank you
Thank you
12-07-2016, 05:09 PM
(12-07-2016 04:08 PM)compsystems Wrote: [ -> ]Please also include gray transparency. Activated or not with the [+/-] key for example
(Allows to see better parts of the piece)
Thank you
Such a change requires a deeper code modification. At the moment I do not plan such a modification. Original BlockOut from 89 did not have anything like that. Preferable to try to change the colors.
slawek39
12-07-2016, 05:50 PM
Application updated to version v1.03. I changed the colors and perspective + minor fixes.
12-07-2016, 06:55 PM
Ok, if the image with gray transparency is the version BlockOut II.
Please can in the future add some comments to source code, I want to learn to handle the graphical view
12-09-2016, 01:26 AM
Application updated to version v1.04. WAIT instead of GETKEY in Help loop, minor changes.
12-09-2016, 09:44 PM
Application updated to version v1.05.
Now the blocks are automatically moved away from the wall during rotation + bug fix.
