11-25-2016, 09:24 PM
First, thanks to all here for their patience as we have been working on this project. I'm surprised by the view counts of the threads and can't help but wonder if many have clicked on them to hope that we had finally finished. :-)
Thanks to Dieter, Robert and all for their help.
Here it is:
67 FUN mod file
67 FUN .rom file
More here later on how to play them.
Game of 1130: XROM 23,01
History: This is based on the HP-65 game of Eleven-Thirty written by John Rausch. It appeared in the V2N3P28 issue of PPC Journal (March 1975).
Object: The calculator generates two random numbers between 11 and 30 and displays them as XX.YY (for example, 15.22 could be displayed). The user then places a bet that the next number is equal to or between the two numbers displayed, endpoints inclusive. You win if it is and pay if it is not. Obviously, if 13.14 is displayed, then you should probably bet $0 and so that you will lose $0. If the numbers shown are 13.16 and you bet $0, the program will say you win if the next number is 14, but you won that $0 bet nothing more.
Play:
1) XEQ 1130.
2) At SEED? Prompt, enter a value between 0 and 1, preferably at least 6 decimal digits and press R/S.
3) At POT? Prompt, enter your starting monetary amount you are playing with in the game and press R/S.
4) Calculator displays numbers in the form of XX.YY and asks you to enter a bet. Enter a value for your bet that the next number is between XX and YY and press R/S.
5) Calculator displays WIN or PAY and shows the number generated and the XX.YY range previously.
6) Press R/S to try again.
7) To check your bank at any time, press E in USER mode. Display shows POT=$ZZZ. Press A to play again.
Example game:
See Key
1) XEQ ALPHA 1130 ALPHA
2) SEED? 0.123456789 R/S
3) POT? 50 R/S
4) 24.29 BET? 10 R/S
5) WIN 28–24.29 R/S
6) 13.14 BET? 0 R/S
7) WIN 14–13.14 R/S (Note: You won $0 here)
8) 16.24 BET? 50 R/S
9) PAY 14–16.24 etc.
Specifics:
1) Program is 130 bytes long.
2) Calls XROM 23,25 (Seed? Prompt) and XROM 23,26 (Random Number Generator)
3) Uses registers 00 – 05. SIZE 006 required.
a. 00 – random number seed
b. 01 – first two digit number (XX)
c. 02 – second two digit number (YY)
d. 03 – third two digit number to see if between XX.YY
e. 04 – amount of BET
f. 05 – amount of POT
4) Labels used
a. 01 – Random number routine. Calls XROM R (23,26)
b. 02 – You lost
c. 03 – Common label to display results
d. A – Starts a new game
e. E – Displays POT
Program Listing:
Game of 2636:
History: This is based on the game of Twenty-six or Thirty-six from the HP 67/97 Users’ Library Solutions Book Games of Chance, page 6. Originally written by Matthew Bishop.
Object:
Game of 26: You choose a number from 1 to 6 as your number and pay $0.25 to play. The calculator then rolls 10 dice 13 times for a total of 130 numbers of 1 to 6. If your number appears 11 or fewer times, then you win a dollar. If it appears exactly 13 times, then you win $0.50. If it appears 26 or more times, you win $1. If it appears 33 or more times, you win $2. (Note: If your number appears 28 times, you win $1, if it appears 35 times, you win $2 total).
Game of 36: Place a bet (deducted from your account). Player continues to roll dice until he decides to stop or the sum or all numbers rolled exceeds 36 automatically losing. When the first player is done, if his total is 36 or less, the second rolls, following the same procedure. If the second player stops before his or its total exceeds 36, the totals are compared. Whoever comes closes to 36, wins. On a tie, you get your bet back. The calculator will match your bet (winner gets total bet by both players); it uses a simple strategy to decide when to stop rolling dice.
Play:
1) XEQ 2636.
3) To play 26, key in die you choose (1-6) and press A.
4) Display pauses and displays a sequence of 10 digit random numbers (13 times).
5) The number of times your number occurs is displayed, followed by the amount you won or lost, followed by your total monetary position. To play again, go back to step 3.
6) To play 36, decide if you wish to go first or you want the calculator to go first.
7) If you wish to go first, enter your bet and press B and the calculator will roll your dice. If you wish to let the calculator go first, enter your bet and press C.
8) The calculator will display your total points and show HP’s points.
9) Continue to let the program run until you wish to stop accumulating your points. If you do not stop before your total goes over 36, then you automatically lose.
10) When you wish to stop, press the decimal point and the calculator will begin accumulating points.
11) If the calculator goes over 36 before it stops, you automatically win.
12) If the calculator stops with its total under 36, the winner is whoever is closer to 36.
13) Go to step 6 to play again.
Example game of 26:
See Key
1) XEQ ALPHA 2636 ALPHA
3) BANK=$0.00 6 A (Note: Choose the number 6 and play the game of 26)
4) 5662125224
6411215332
5136614123
27 TIMES
WIN $1.00
BANK=$0.75
5) WIN 28–24.29 R/S
6) 13.14 BET? 0 R/S
Example game of 36:
See Key
3) BANK=$0.00 5 B (Note: Bet $5 and go first in a game of 36)
4) You-5 HP-0
You-11 HP-0
You-17 HP-0
You-19 HP-0
You-20 HP-0
You-22 HP-0
You-27 HP-0
You-29 HP-0
You-31 HP-0
You-35 HP-0 Press . quickly (The decimal point)
You-35 HP-6
You-35 HP-10
You-35 HP-11
You-35 HP-12
You-35 HP-14
You-35 HP-15
You-35 HP-20
You-35 HP-23
You-35 HP-26
You-35 HP-28
You-35 HP-30
You-35 HP-35
WIN $0 (Note:A tie game)
BANK=$0.00
Specifics:
1) Program is 297 bytes long.
b. 01 – Bank $
c. 02 – times your die occurred in game of 26.
d. 03 – Your score in 36.
e. 04 – HP’s score in 36.
f. 05 – amount of BET
4) Labels used
a. 00 –
b. 01 – Random number routine. Calls XROM R (23,26)
c. 02 – You lost
d. 03 – Common label to display results
e. 06
f. 07
g. 08
h. 09
i. 77
j. 88
k. 99 – Random number generator
l. A – Starts a new game of 26
m. B – Starts a new game of 36 – human first
n. C – Starts a new game of 36 – HP first
o. D – Displays BANK amount.
Program Listing:
Here it is:
67 FUN mod file
67 FUN .rom file
28 FNCTIONS XROM # Description
FCT: -HP67 FUN+ XROM 23,00 Rom Header
FCT: "1130" XROM 23,01 Game of 11-30
FCT: "2636" XROM 23,02 Game of 26 or 36
FCT: "ART" XROM 23,03 Artillery game
FCT: "BSP" XROM 23,04 Battleship
FCT: "CH" XROM 23,05 Chess
FCT: "CHK" XROM 23,06 Chuck-a-luck
FCT: "GOLF" XROM 23,07 Golf
FCT: "JT" XROM 23,08 Jive Turkey
FCT: "ML" XROM 23,09 Moon Lander
FCT: "OAB" XROM 23,10 One Arm Bandit
FCT: "SPW" XROM 23,11 SpaceWar
FCT: "ST" XROM 23,12 Star Trek
FCT: "TTT" XROM 23,13 Tic-tac-toe
FCT: "AOS" XROM 23,14 Algebraic Operating System
FCT: "+" XROM 23,15 -- functions in AOS Program
FCT: "-" XROM 23,16 -- functions in AOS Program
FCT: "*" XROM 23,17 -- functions in AOS Program
FCT: "/" XROM 23,18 -- functions in AOS Program
FCT: "<" XROM 23,19 -- functions in AOS Program
FCT: ">" XROM 23,20 -- functions in AOS Program
FCT: "=" XROM 23,21 -- functions in AOS Program
FCT: "YX" XROM 23,22 -- functions in AOS Program
FCT: "NEG" XROM 23,23 -- functions in AOS Program
FCT: "SD" XROM 23,24 Sum of Digits game
FCT: "S" XROM 23,25 Seed? Prompt Store R00 subroutine
FCT: "R" XROM 23,26 Random Number Generator subroutine
FCT: "RF" XROM 23,27 Reset Flags from PPC ROM
Play:
1) XEQ 1130.
Example game:
See Key
3) POT? 50 R/S
5) WIN 28–24.29 R/S
6) 13.14 BET? 0 R/S
Specifics:
4) Labels used
b. 02 – You lost
e. E – Displays POT
Program Listing:
01 LBL "1130"
02 XROM 23,25
03 "POT?"
04 PROMPT
05 STO 05
06 LBL A
07 XEQ 01
08 STO 01
09 XEQ 01
10 STO 02
11 RCL 01
12 X<=Y?
13 X<>Y
14 STO 02
15 X<>Y
16 STO 01
17 X<>Y
18 E2
19 /
20 +
21 CLA
22 FIX 02
23 ARCL X
24 >" BET?"
25 PROMPT
26 STO 04
27 FIX 00
28 CF 29
29 XEQ 01
30 STO 03
31 RCL 01
32 X>Y?
33 GTO 02
34 RDN
35 RCL 02
36 X<Y?
37 GTO 02
38 RCL 04
39 ST+ 05
40 "WIN "
41 GTO 03
42 LBL 02
43 RCL 04
44 ST- 05
45 "PAY "
46 LBL 03
47 ARCL 03
48 >"-"
49 ARCL 01
50 >"."
51 ARCL 02
52 PROMPT
53 GTO A
54 LBL 01
55 XROM 23,26
56 20
57 *
58 11
59 +
60 INT
61 RTN
62 LBL E
63 "POT=$"
64 ARCL 05
65 AVIEW
66 END
Game of 2636:
Object:
Play:
1) XEQ 2636.
Example game of 26:
See Key
4) 5662125224
6411215332
5136614123
27 TIMES
WIN $1.00
BANK=$0.75
5) WIN 28–24.29 R/S
6) 13.14 BET? 0 R/S
Example game of 36:
See Key
4) You-5 HP-0
You-11 HP-0
You-17 HP-0
You-19 HP-0
You-20 HP-0
You-22 HP-0
You-27 HP-0
You-29 HP-0
You-31 HP-0
You-35 HP-6
You-35 HP-10
You-35 HP-11
You-35 HP-12
You-35 HP-14
You-35 HP-15
You-35 HP-20
You-35 HP-23
You-35 HP-26
You-35 HP-28
You-35 HP-30
You-35 HP-35
BANK=$0.00
Specifics:
b. 01 – Bank $
4) Labels used
a. 00 –
c. 02 – You lost
e. 06
f. 07
g. 08
h. 09
i. 77
j. 88
Program Listing:
01 LBL "2636"
02 XROM 23,25
03 CLX
04 STO 01
05 GTO D
06 LBL 01
07 10
08 STO 04
09 CLX
10 LBL 02
11 10
12 *
13 XEQ 99
14 RCL 05
15 X=Y?
16 ISG 02
17 LBL 00
18 RDN
19 +
20 DSE 04
21 GTO 02
22 FIX 00
23 CF 29
24 VIEW X
25 DSE 03
26 GTO 01
27 PSE
28 PSE
29 " "
30 ARCL 02
31 >" TIMES"
32 AVIEW
33 PSE
34 1
35 STO 05
36 15
37 RCL 02
38 11
39 -
40 X<Y?
41 X<=0?
42 GTO 03
43 2
44 -
45 ABS
46 .5
47 X<Y?
48 INT
49 STO 05
50 GTO 88
51 LBL 03
52 22
53 X<=Y?
54 ISG 05
55 LBL 88
56 RCL 05
57 ST+ 01
58 FIX 02
59 "WIN $"
60 X<0?
61 "PAY $"
62 ABS
63 ARCL X
64 AVIEW
65 PSE
66 LBL D
67 CF 01
68 SF 27
69 FIX 02
70 RCL 01
71 "BANK=$"
72 ARCL 01
73 AVIEW
74 RTN
75 LBL A
76 STO 05
77 .25
78 ST- 01
79 13
80 STO 03
81 CLX
82 STO 02
83 GTO 01
84 LBL B
85 SF 01
86 CHS
87 GTO 07
88 LBL C
89 CF 01
90 LBL 07
91 STO 05
92 CLX
93 STO 04
94 STO 03
95 9
96 STO 02
97 FS? 01
98 DSE 02
99 CF 00
100 FIX 00
101 CF 29
102 XEQ IND 02
103 FS?C 00
104 GTO 88
105 17
106 ST- 02
107 XEQ IND 02
108 RCL 05
109 CHS
110 STO 05
111 FS?C 00
112 GTO 88
113 RCL 03
114 RCL 04
115 -
116 X!=0?
117 SIGN
118 RCL 05
119 ABS
120 *
121 STO 05
122 GTO 88
123 LBL 08
124 3
125 XEQ 77
126 X>0?
127 FS? 00
128 RTN
129 GTO 08
130 LBL 09
131 4
132 XEQ 77
133 FS? 00
134 RTN
135 RCL 03
136 RCL 04
137 FS? 01
138 X=Y?
139 GTO 06
140 X<Y?
141 GTO 09
142 RTN
143 LBL 06
144 33
145 RCL 04
146 X<=Y?
147 GTO 09
148 RTN
149 LBL 77
150 XEQ 99
151 ST+ IND Y
152 36
153 RCL IND Z
154 X>Y?
155 SF 00
156 "YOU-"
157 ARCL 03
158 >" HP-"
159 ARCL 04
160 AVIEW
161 PSE
162 RTN
163 LBL 99
164 XROM 23,26
165 6
166 *
167 INT
168 1
169 +
170 END
