Full Version: Raw files for these HP 67 program listings ?
Pages: 1 2 3 4 5
(09-05-2016 04:26 PM)RobertM Wrote: [ -> ]I'm going to take a swing at the One Armed Bandit next. It's a holiday today, so I may not get to it until tomorrow. Smile
Here's my attempt at this program. It includes a lot of streamlining which makes the program more compact, it also uses less registers:
In the original program registers A to E hold some constants that are only used once (!) in the program, reg. A is even not used at all. So instead of a RCL the constants have been inserted directly into the code. Also registers 3 and 5 remained unused, so I replaced reg. E with R05 (R03 still is not used). This way the 41 program is shorter and requires significantly less registers than the original 67 version.
The attached zip file contains a listing (.TXT) and a .RAW file. Maybe someone can do some tests and compare this version with the original one. If you find errors, please report here.
Dieter
[attachment=3884]
(09-06-2016 10:35 PM)RobertM Wrote: [ -> ]I agree with all of your comments here. I removed the use of the I reg, and changed the random number generator to generate between 1 and 9.
Agreed. I also found only clearing 00 and 02 were needed, and I left it in the init routine (LBL e) instead of the "preamble". I changed RegA-E into R10-14. Technically, we could shave off a couple more registers, since R03 and R05 aren't used, but I left it as is, so only SIZE 015 is required.
Great. Please see my post that I seem to have written while you wrote yours. ;-)
(09-06-2016 10:35 PM)RobertM Wrote: [ -> ]Love to! I've included my fully commented version in the zip.
Hmmm... I do not see any zip file. ?!?
(09-06-2016 10:35 PM)RobertM Wrote: [ -> ]Love to see what you did the same/differently.
I did some similar changes and added some others (e.g. removing register A...E completely since the are only called once). But you seem to have analyzed the code more thoroughly so that even a bugfix was applied.
Maybe we can make an optimized version from the two individual ones. ;-)
(09-06-2016 10:35 PM)RobertM Wrote: [ -> ]Here is a list of my changes for the "OB" version:
- added preamble
- translated 7xxx calls into 41C calls (no card reader required)
- translated A-E storage registers to 10-14, removed need for I (SIZE 015)
This can be reduced to SIZE 010, or even 009 if in my version R9 is replaced with the last unused register 03.
(09-06-2016 10:35 PM)RobertM Wrote: [ -> ]- fixed bug: original program left out a multiply at line 68 (otherwise not holding
digit 1 when there are other holds will always result in a 1 being the first digit)
I knew there was something wrong but I didn't know what. #-)
EDIT: I see you now added the zip file. Let me add these remarks on OB_commented.txt:
- The init routine at LBL e sets the constants 0.11, 111 and 123. On the other hand at LBL 9 where these constants are used the comment says 0.111 and 0.123. ?!?
BTW the "1000" in R10 is never recalled, so it can be removed completely.
- The CF 3 at LBL D resets flag 3 simply because it has been set automatically when the user entered the payment (flag 3 on the 67 does the same as flag 22 on the 41, it's the data entry flag).
- Clearing all flags on startup at LBL"OB" is fine, but not required since the init routine at LBL e already does this: it calls LBL b which clears all flags.
Dieter
(09-06-2016 10:59 PM)Dieter Wrote: [ -> ]I did some similar changes and added some others (e.g. removing register A...E completely since the are only called once). But you seem to have analyzed the code more thoroughly so that even a bugfix was applied.
Great idea! See below...
Quote:- The init routine at LBL e sets the constants 0.11, 111 and 123. On the other hand at LBL 9 where these constants are used the comment says 0.111 and 0.123. ?!?
Bad comments. Typos with extra heavy on the '.' key. Smile
Quote:BTW the "1000" in R10 is never recalled, so it can be removed completely.
Had that in the back of my mind, but forgot to do anything about it. Good idea.
Quote:- The CF 3 at LBL D resets flag 3 simply because it has been set automatically when the user entered the payment (flag 3 on the 67 does the same as flag 22 on the 41, it's the data entry flag).
Thanks, I'd forgotten that. Which means that the CF 03 can be removed, because on the 41, it doesn't get set with data entry (and it isn't being tested, so don't need to change it to a flag 22 test).
Quote:- Clearing all flags on startup at LBL"OB" is fine, but not required since the init routine at LBL e already does this: it calls LBL b which clears all flags.
Nice catch. Didn't notice.
So I've incorporated an "optimized" version of your comments/changes and mine. I moved the "constants" what were only being used once from register to direct in the program. I changed the constant 100 to use R05 instead of R10, and I moved R09 into R03, so now SIZE 009 is all that is required. Also, incorporated all of your other suggestions and things I noticed from your code (*4 instead of /.25, etc.). I think I captured everything.
Enclosed in this OB.zip is the optimized version (.RAW, .txt, and _commented.txt).
This version requires only 9 registers, and is down to 260 bytes, but still "feels" the same. Thanks for all the help. Let me know if you see something else.
(09-07-2016 04:11 AM)RobertM Wrote: [ -> ]Enclosed in this OB.zip is the optimized version (.RAW, .txt, and _commented.txt).
Got it, will try to squeeze it in the module but it's looking very full...
(09-07-2016 05:16 AM)Ángel Martin Wrote: [ -> ]Got it, will try to squeeze it in the module but it's looking very full...
Here is a shorter version with some improvements and maybe even a bugfix:
- I think there is a bug in the original program: if there are any holds the user can pull the lever even if there are no no more pulls available. This is tested right *after* checking for holds, while the test should be *before* this. I changed this in the attached version. If this is not the way the program is supposed to work, please correct.
- XEQ b is called only once by the init routine so LBL b can be placed there and requires no separate call.
- R05 (=100) is recalled three times. Replacing this with R04^2 saves two bytes in the init routine and requires three more bytes in the code. At the same time it frees up another register for the cost of just one single byte. This way registers 6...8 move down to 5...7 and SIZE 008 is sufficient.
- The only jump to LBL 03 is done after testing flag 0, so the following CF 00 can be omitted by replacing the flag test with FS?C 00.
- The test for holds can be done more efficiently and faster. The current version tests for a hold on a particular digit, and if true it jumps to a forward label, and finally jumps back to test the next digit. This is slow (especially on the 67 without compiled GTOs) and can be improved. For the third digit even a simple inverse flag test (FC?C) can be used, without any jumps at all. BTW this is also possible on the 67/97, here two consecutive F? 3 are the same as a FC?C 03 on the 41.
- This frees up several labels, so that LBL a can be replaced with the (shorter) LBL 09.
CAT 1 on V41 says we're down to 240 Bytes.
Now it's your turn again, Robert. ;-)
BTW Ángel: what about a text file with the complete listings so far in the new 67 Games ROM? I think there is *much* room for improvement and more effective, byte-saving code.
Dieter
Edit: sorry, forgot the attachment... #-)
[attachment=3887]
(09-07-2016 01:54 PM)Dieter Wrote: [ -> ]CAT 1 on V41 says we're down to 240 Bytes.
I give up! Nice work!
(09-07-2016 01:54 PM)Dieter Wrote: [ -> ]BTW Ángel: what about a text file with the complete listings so far in the new 67 Games ROM? I think there is *much* room for improvement and more effective, byte-saving code.
I'll give you something better: the Excel-based "blueprint", which includes the macro to compile into a ROM file so you can take control ...
Step 155 RTN can be deleted.
Steps 39-48 could be this:
LBL c
SF 01
SF 02
LBL C
SF 00
SF 03
RTN
This is fun! It feels like I'm reading successive issues of PPC Journal in 1983, without the month-long delay between 'better versions'. Smile
(09-07-2016 02:22 PM)RobertM Wrote: [ -> ][ ...240 bytes... ]
Don't give up, join the party. ;-)
I now got it down to 206 bytes in 135 steps.
The program essentially has two routines that generate a three digit number. One at the beginning and another one at LBL 03 that checks for holds. This can be combined into one single routine.
I also wondered why the counter in R00 is decremented only if no holds are active. I am not sure if this is a bug or a feature, but the attached version now decrements the counter in both cases. Also the random number generator was modifed. Gene's suggestions were implemented as well.
Robert et al., would you try this and check for bugs and unexpected results?
Dieter
[attachment=3892]
Looks like it runs ok to me. As with all these games, I'm so tempted to add some sort of alpha labels to the outputs displayed, but byte count, byte count... :-)
(09-07-2016 07:24 PM)Gene Wrote: [ -> ]As with all these games, I'm so tempted to add some sort of alpha labels to the outputs displayed,
Gene, remember your own words:
(08-31-2016 04:08 PM)Gene Wrote: [ -> ]Dieter, I don't disagree, but some of the "fun" is actually leaving them the way they were.
Regarding size issues...
(09-07-2016 07:24 PM)Gene Wrote: [ -> ]...but byte count, byte count... :-)
... I'd say we can be much more effective than the original programs. Consider the last example: from 187 steps and 15 data registers we're now down to 135 steps and merely 8 registers. So the byte count is not much of an issue. But... remember your own words. ;-)
Dieter
(09-07-2016 02:29 PM)Ángel Martin Wrote: [ -> ]I'll give you something better: the Excel-based "blueprint", which includes the macro to compile into a ROM file so you can take control ...
Great – but what is this?
For me everything is fine as long as it does not require more than some Excel/VBA skills and HP41 user code experience. :-)
You should post this "blueprint" here in the forum so that more users can work with it. See what we did with the one-arm-bandit program in a joint effort. ;-)
Dieter
I think we should work through the code for these as was done with the One Arm Bandit.
The code for the programs to be included is essentially from the HP 41 library on the museum site here. The listings for the HP67/97 games pac and games solution books (there were two) are available here on the site.
Eight of the .raw files from the existing HP67 games rom are in this .zip file. More are coming. The code is from the rom image Angel posted here.
zip of raw games
Let's pick one and start optimizing.
1) Remove card reader functions where possible.
2) Save registers with program steps where possible.
3) Avoid CLRG if it makes sense.
4) Save bytes
5) Maybe... add limited alpha but watch the byte count
Angel, are you ok if we save some space and go through this over the next week or so ?
Star Trek
 01 LBL "ST"
 02 CLRG
 03 CF 02
 04 SF 27
 05 FIX 02
 06 "STAR TREK"
 07 PROMPT
 08 LBL A
 09 STO 14
 10 2 E4
 11 STO 08
 12  E2
 13 STO 10
 14 4
 15 STO 15
 16 /
 17 STO 00
 18 0
 19 STO 06
 20 LBL 09
 21 XEQ 08
 22 RCL 10
 23 *
 24 RND
 25 STO IND 15
 26 DSE 15
 27 GTO 09
 28 LBL 00
 29 RCL 04
 30 FIX 02
 31 VIEW X
 32 PSE
 33 PSE
 34 PSE
 35 CLD
 36 STOP
 37 LBL 08
 38 RCL 14
 39 ATAN
 40 FRC
 41 STO 14
 42 RTN
 43 LBL B
 44 3
 45 STO 15
 46 LBL 06
 47 XEQ 02
 48 RCL 00
 49 X<=Y?
 50 GTO 05
 51 RDN
 52 RCL 15
 53 FIX 00
 54 VIEW X
 55 PSE
 56 PSE
 57 PSE
 58 CLD
 59 RDN
 60 VIEW X
 61 PSE
 62 PSE
 63 PSE
 64 CLD
 65 X<>Y
 66 VIEW X
 67 PSE
 68 PSE
 69 PSE
 70 CLD
 71 XEQ 08
 72 LASTX
 73 ST+ 05
 74 LBL 05
 75 DSE 15
 76 GTO 06
 77 XEQ a
 78 GTO 00
 79 LBL 07
 80 INT
 81 FS?C 02
 82 STO 11
 83 LASTX
 84 FRC
 85 RCL 10
 86 *
 87 INT
 88 RTN
 89 LBL C
 90 STO 12
 91 X<>Y
 92 STO 11
 93 8
 94 RCL 10
 95 RCL 04
 96 XEQ d
 97 -
 98 %
 99 RCL 12
100 X>Y?
101 X<>Y
102 10
103 *
104 STO 12
105 X^2
106 XEQ 01
107 RCL 11
108 RCL 12
109 P-R
110 INT
111 ST+ 04
112 X<>Y
113 INT
114 RCL 10
115 /
116 ST+ 04
117 GTO 00
118 LBL 01
119 SF 02
120 LBL D
121 RCL 08
122 X<>Y
123 X<=Y?
124 GTO 04
125 0
126 LBL 14
127 PSE
128 GTO 14
129 LBL 04
130 ST- 08
131 FS?C 02
132 RTN
133 ST+ 06
134 RCL 06
135 RTN
136 LBL E
137 STO 15
138 XEQ 02
139 STO 11
140 RCL 06
141 RCL 10
142 RCL IND 15
143 XEQ d
144 -
145 XEQ 08
146 *
147 X>Y?
148 XEQ 03
149 ST- 06
150 STO 05
151 RCL 06
152 STOP
153 STO 13
154 RCL 00
155 2
156 /
157 RCL 11
158 X>Y?
159 GTO 00
160 X^2
161 RCL 13
162 *
163 XEQ 01
164 XEQ 08
165 RCL 10
166 *
167 RCL 11
168 SQRT
169 /
170 VIEW X
171 PSE
172 PSE
173 PSE
174 CLD
175 XEQ c
176 XEQ a
177 GTO 00
178 LBL 03
179 XEQ 01
180 R^
181 -
182 SF 02
183 RTN
184 LBL 02
185 RCL IND 15
186 SF 02
187 XEQ 07
188 RCL 04
189 XEQ 07
190 RCL 11
191 RDN
192 RDN
193 X<>Y
194 R^
195 -
196 RDN
197 -
198 R^
199 X<>Y
200 R-P
201 RTN
202 LBL e
203 RCL 15
204 CHS
205 STO IND 15
206 STOP
207 LBL b
208 STO 15
209 RCL IND 15
210 LBL d
211 RCL 10
212 *
213 FRC
214  E3
215 *
216 RTN
217 LBL a
218 RCL 05
219 X=0?
220 RTN
221 ST- 05
222 4
223 STO 15
224 FS?C 02
225 1/X
226 /
227 VIEW X
228 PSE
229 PSE
230 PSE
231 CLD
232 LBL c
233 RCL IND 15
234 XEQ d
235 +
236 RCL 10
237 X<=Y?
238 GTO e
239 RDN
240  E5
241 /
242 RCL IND 15
243 FIX 02
244 RND
245 +
246 STO IND 15
247 END
Golf
 01 LBL "GOLF67"
 02 LBL 16
 03 LBL b
 04 RCL 20
 05 997
 06 *
 07 FRC
 08 STO 20
 09 .5
 10 -
 11 RTN
 12 LBL 10
 13 LBL A
 14 XEQ 16
 15 1
 16 +
 17 40
 18 *
 19 STO 22
 20 0
 21 STO 05
 22 STO 03
 23 STO 02
 24 7P<>S -- XROM 30,31
 25 STO 05
 26 STO 03
 27 STO 02
 28 7P<>S -- XROM 30,31
 29 XEQ 16
 30 9
 31 *
 32 7
 33 +
 34 50
 35 *
 36 STO 23
 37 ST- 02
 38 7P<>S -- XROM 30,31
 39 ST- 02
 40 7P<>S -- XROM 30,31
 41 215
 42 /
 43 3
 44 +
 45 INT
 46 ST+ 09
 47 7P<>S -- XROM 30,31
 48 ST+ 09
 49 1
 50 ST+ 00
 51 7P<>S -- XROM 30,31
 52 ST+ 00
 53 RCL 00
 54 RCL 23
 55 R^
 56 RCL 22
 57 7PRSTK -- XROM 30,33
 58 RTN
 59 LBL 13
 60 LBL D
 61 19
 62 GTO 12
 63 LBL 11
 64 LBL B
 65 4
 66 -
 67 2
 68 *
 69 LBL 12
 70 LBL C
 71 1
 72 ST+ 01
 73 RDN
 74 20
 75 -
 76 10
 77 *
 78 CHS
 79 STO 08
 80 0
 81 STOP
 82 STO 21
 83 2
 84 1/X
 85 XEQ 16
 86 -
 87 LASTX
 88 X<>Y
 89 RCL 07
 90 56
 91 /
 92 *
 93 -
 94 RCL 08
 95 5
 96 /
 97 *
 98 RCL 08
 99 RCL 21
100 *
101 +
102 ABS
103 STO 24
104 XEQ 16
105 3
106 *
107 RCL 07
108 36
109 +
110 SQRT
111 *
112 STO 21
113 RCL 03
114 ABS
115 RCL 22
116 X<=Y?
117 XEQ 09
118 RCL 04
119 4
120 +
121 RCL 24
122 X>Y?
123 GTO 04
124 RCL 04
125 5
126 1/X
127 -
128 X>Y?
129 GTO 04
130 LASTX
131 RCL 04
132 /
133 ATAN
134 RCL 21
135 ABS
136 X>Y?
137 GTO 04
138 0
139 7DSP9 -- XROM 30,21
140 7PRTX -- XROM 30,34
141 RCL 01
142 RCL 07
143 18
144 /
145 RCL 00
146 *
147 -
148 RCL 09
149 -
150 7DSP0 -- XROM 30,12
151 7PRTX -- XROM 30,34
152 RTN
153 LBL 04
154 RCL 21
155 RCL 05
156 +
157 RCL 24
158 P-R
159 RCL 02
160 +
161 STO 02
162 X<>Y
163 RCL 03
164 +
165 STO 03
166 CHS
167 X<>Y
168 CHS
169 R-P
170 STO 04
171 X<>Y
172 STO 05
173 RCL 24
174 RCL 21
175 RCL 02
176 RCL 03
177 7PRTX -- XROM 30,33
178 ABS
179 RCL 22
180 X<=Y?
181 GTO 08
182 GTO 07
183 LBL 08
184 7DSP6 -- XROM 30,18
185 LBL 07
186 RCL 04
187 7PRTX -- XROM 30,34
188 RCL 05
189 7PRTX -- XROM 30,34
190 7DSP0 -- XROM 30,12
191 RTN
192 LBL 09
193 RCL 21
194 ABS
195 RCL 05
196 ABS
197 SIN
198 3
199 *
200 RCL 03
201 ABS
202 RCL 22
203 -
204 /
205 ATAN
206 ABS
207 X>Y?
208 RTN
209 RCL 24
210 9
211 /
212 STO 24
213 RCL 21
214 9
215 *
216 STO 21
217 RTN
218 GTO 67
219 END
Game of 26/36
 01 LBL "G2636"
 02 LBL 10
 03 LBL A
 04 STO 20
 05 .25
 06 ST- 00
 07 0
 08 STO 01
 09 13
 10 STO 21
 11 LBL 18
 12 LBL d
 13 10
 14 STO 25
 15 0
 16 ENTER
 17 LBL 00
 18 10
 19 *
 20 XEQ 19
 21 RCL 20
 22 X=Y?
 23 XEQ 01
 24 CLX
 25 +
 26 +
 27 7DSZ -- XROM 30,23
 28 GTO 00
 29 7PRTX -- XROM 30,34
 30 RCL 21
 31 1
 32 -
 33 STO 21
 34 X!=0?
 35 GTO 18
 36 1
 37 STO 25
 38 RCL 01
 39 33
 40 X<=Y?
 41 7ISZ -- XROM 30,29
 42 7
 43 -
 44 X<=Y?
 45 7ISZ -- XROM 30,29
 46 2
 47 /
 48 X=Y?
 49 XEQ 02
 50 2
 51 -
 52 X<>Y
 53 X<=Y?
 54 7ISZ -- XROM 30,29
 55 1
 56 RCL 25
 57 X=Y?
 58 0
 59 ST+ 00
 60 RCL 01
 61 PSE
 62 X<>Y
 63 PSE
 64 RCL 00
 65 RTN
 66 LBL 01
 67 1
 68 ST+ 01
 69 CLX
 70 +
 71 RTN
 72 LBL 02
 73 .5
 74 STO 25
 75 CLX
 76 +
 77 RTN
 78 LBL 11
 79 LBL B
 80 SF 01
 81 STO 05
 82 ST- 02
 83 0
 84 STO 03
 85 STO 04
 86 XEQ 15
 87 XEQ 16
 88 LBL 17
 89 LBL c
 90 7DSP2 -- XROM 30,14
 91 RCL 04
 92 RCL 03
 93 X>Y?
 94 GTO 09
 95 X<>Y
 96 X>Y?
 97 GTO 04
 98 RCL 05
 99 ST+ 02
100 PSE
101 RCL 02
102 RTN
103 LBL 12
104 LBL C
105 CF 01
106 STO 05
107 ST- 02
108 0
109 STO 03
110 STO 04
111 XEQ 16
112 XEQ 15
113 GTO 17
114 LBL 13
115 LBL D
116 RCL 02
117 RTN
118 LBL 14
119 LBL E
120 STO 24
121 RTN
122 LBL 15
123 LBL a
124 7DSP2 -- XROM 30,14
125 LBL 05
126 XEQ 19
127 ST+ 03
128 LBL 03
129 36
130 RCL 03
131 X>Y?
132 GTO 04
133 PSE
134 X>0?
135 GTO 03
136 X<0?
137 GTO 05
138 RTN
139 LBL 04
140 7DSP2 -- XROM 30,14
141 RCL 05
142 CHS
143 STOP
144 LBL 16
145 LBL b
146 7DSP0 -- XROM 30,12
147 LBL 06
148 XEQ 19
149 ST+ 04
150 36
151 RCL 04
152 CF 22
153 PSE
154 FS?C 22
155 GTO 04
156 X>Y?
157 GTO 09
158 FS? 01
159 GTO 07
160 LBL 08
161 33
162 X<=Y?
163 RTN
164 GTO 06
165 LBL 07
166 RCL 03
167 X<>Y
168 X=Y?
169 GTO 08
170 X<=Y?
171 GTO 06
172 RTN
173 LBL 09
174 7DSP2 -- XROM 30,14
175 RCL 05
176 2
177 *
178 ST+ 02
179 STOP
180 LBL 19
181 LBL e
182 RCL 24
183 997
184 *
185 FRC
186 STO 24
187 6
188 *
189 1
190 +
191 INT
192 RTN
193 STOP
194 END
Follow me (from mag card pack)
 01 LBL "FLLW67"
 02 LBL 10
 03 LBL A
 04 7CLRG -- XROM 30,11
 05 7P<>S -- XROM 30,31
 06 7CLRG -- XROM 30,11
 07 24
 08 STO 25
 09 CLX
 10 RTN
 11 LBL 15
 12 LBL a
 13 +
 14 1
 15 GTO 00
 16 LBL 16
 17 LBL b
 18 -
 19 2
 20 GTO 00
 21 LBL 17
 22 LBL c
 23 *
 24 3
 25 GTO 00
 26 LBL 18
 27 LBL d
 28 /
 29 4
 30 LBL 00
 31 7DSZ -- XROM 30,23
 32 GTO 01
 33 GTO 09
 34 LBL 01
 35 STO IND 25
 36 RDN
 37 RTN
 38 LBL 19
 39 LBL e
 40 %
 41 STO 24
 42 CLX
 43 5
 44 GTO 08
 45 LBL 11
 46 LBL B
 47 STO 24
 48 CLX
 49 6
 50 GTO 08
 51 LBL 12
 52 LBL C
 53 STO 24
 54 CLX
 55 7
 56 7DSZ -- XROM 30,23
 57 GTO 01
 58 LBL 09
 59 CLX
 60 24
 61 PSE
 62 GTO 09
 63 LBL 01
 64 STO IND 25
 65 CLX
 66 RCL 24
 67 LBL 08
 68 7DSZ -- XROM 30,23
 69 GTO 01
 70 GTO 09
 71 LBL 01
 72 STO IND 25
 73 CLX
 74 RCL 24
 75 RTN
 76 LBL 13
 77 LBL D
 78 CLX
 79 24
 80 STO 25
 81 CLX
 82 STO 00
 83 RTN
 84 LBL 14
 85 LBL E
 86 STO 24
 87 RDN
 88 7DSZ -- XROM 30,23
 89 RCL IND 25
 90 X<> 25
 91 7GTOI -- XROM 30,28
 92 LBL 00
 93 CLX
 94 24
 95 STO 25
 96 CLX
 97 RCL 24
 98 RTN
 99 LBL 01
100 X<> 25
101 CLX
102 RCL 24
103 +
104 GTO 14
105 LBL 02
106 X<> 25
107 CLX
108 RCL 24
109 -
110 GTO 14
111 LBL 03
112 X<> 25
113 CLX
114 RCL 24
115 *
116 GTO 14
117 LBL 04
118 X<> 25
119 CLX
120 RCL 24
121 /
122 GTO 14
123 LBL 05
124 X<> 25
125 CLX
126 RCL 24
127 %
128 GTO 14
129 LBL 06
130 X<> 25
131 CLX
132 RCL 24
133 RTN
134 LBL 07
135 X<> 25
136 CLX
137 RCL 24
138 7DSZ -- XROM 30,23
139 RCL IND 25
140 GTO 14
141 STOP
142 END
Chuck a luck
 01 LBL "CHKLCK"
 02 LBL 10
 03 LBL A
 04 7DSP0 -- XROM 30,12
 05 INT
 06 LASTX
 07 X!=Y?
 08 GTO 19
 09 7DSP3 -- XROM 30,15
 10 STO 00
 11 1
 12 X>Y?
 13 GTO 19
 14 CLX
 15 7
 16 X<=Y?
 17 GTO 19
 18 CLX
 19 STO 25
 20 STO 03
 21 XEQ 01
 22 XEQ 01
 23 XEQ 01
 24 RCL 25
 25 X=0?
 26 GTO 00
 27 RCL 01
 28 *
 29 ST+ 04
 30 RCL 03
 31 +
 32 RTN
 33 LBL 00
 34 RCL 01
 35 ST- 04
 36 RCL 03
 37 +
 38 CHS
 39 RTN
 40 LBL 01
 41 RCL 00
 42 RCL 05
 43 PI
 44 +
 45 X^2
 46 FRC
 47 STO 05
 48 6
 49 *
 50 1
 51 +
 52 INT
 53 X=Y?
 55 ST+ 03
 56 10
 57 ST/ 03
 58 RTN
 59 LBL 11
 60 LBL B
 61 7DSP0 -- XROM 30,12
 62 INT
 63 LASTX
 64 X!=Y?
 65 GTO 19
 66 STO 01
 67 RTN
 68 LBL 13
 69 LBL D
 70 CLX
 71 STO 04
 72 LBL 12
 73 LBL C
 74 7DSP0 -- XROM 30,12
 75 RCL 04
 76 RTN
 77 LBL 14
 78 LBL E
 79 PI
 80 +
 81 STO 05
 82 GTO 14
 83 STOP
 84 END
Battleship
 01 LBL "BTLSHP"
 02 LBL 10
 03 LBL A
 04 LOG
 05 FRC
 06  E2
 07 *
 08 STO 03
 09 INT
 10 STO 01
 11 LASTX
 12 FRC
 13  E2
 14 *
 15 ABS
 16 INT
 17 STO 02
 18 RCL 01
 19 INT
 20 STO 01
 21 1111111111
 22 STO 08
 23 8
 24 *
 25 STO 06
 26 16
 27 STO 25
 28 7
 29 STO 07
 30 RCL 08
 31 7
 32 *
 33 STO 05
 34 LBL 02
 35 7DSZ -- XROM 30,23
 36 GTO 06
 37 RCL 08
 38 7PRTX -- XROM 30,34
 39 GTO 09
 40 LBL 06
 41 RCL 25
 42 PSE
 43 CLX
 44 STOP
 45 RCL 02
 46 -
 47 X^2
 48 X<>Y
 49 RCL 01
 50 -
 51 X^2
 52 +
 53 SQRT
 54 PSE
 55 5
 56 X<>Y
 57 X>Y?
 58 GTO 02
 59 1
 60 X<>Y
 61 X<=Y?
 62 GTO 01
 63 1
 64 ST+ 00
 65 4
 66 RCL 00
 67 X>Y?
 68 GTO 03
 69 ST- 07
 70 RCL 07
 71 ST- 01
 72 ST- 02
 73 RCL 01
 74 X<0?
 75 GTO 05
 76 RCL 02
 77 X<0?
 78 GTO 05
 79 GTO 02
 80 LBL 05
 81 RCL 07
 82 2
 83 *
 84 ST+ 01
 85 ST+ 02
 86 GTO 02
 87 LBL 03
 88 RCL 05
 90 GTO 09
 91 LBL 01
 92 RCL 06
 93 7PRTX -- XROM 30,34
 94 LBL 09
 95 CLX
 96 STO 00
 97 RCL 03
 98 PI
 99 *
100 GTO 10
101 RTN
102 STOP
103 END
Blackjack HP67
 01 LBL "BJCK67"
 02 LBL 10
 03 LBL A
 04 ADV
 05 ADV
 06 CF 00
 07 CF 01
 08 STO 20
 09 1
 10 STO 25
 11 XEQ 00
 12 STO 21
 13 XEQ 05
 14 XEQ 09
 15 STO 01
 16 STO 03
 17 1
 18 STO 25
 19 XEQ 00
 20 STO 22
 21 XEQ 09
 22 STO 02
 23 ST+ 03
 24 0
 25 XEQ 05
 26 ADV
 27 XEQ 19
 28 STO 05
 29 STO 07
 30 XEQ 19
 31 STO 06
 32 ST+ 07
 33 RCL 05
 34 *
 35 RCL 07
 36 +
 37 21
 38 STO 00
 39 X=Y?
 40 GTO 02
 41 RCL 07
 42 XEQ 03
 43 STOP
 44 LBL 11
 45 LBL B
 46 XEQ 19
 47 ST+ 07
 48 RCL 07
 49 RCL 00
 50 X<>Y
 51 X>Y?
 52 GTO 04
 53 X<=Y?
 54 XEQ 03
 55 STOP
 56 LBL 13
 57 LBL D
 58 SF 00
 59 10
 60 ST+ 07
 61 RCL 07
 62 XEQ 03
 63 RTN
 64 LBL 14
 65 LBL E
 66 CF 00
 67 10
 68 ST- 07
 69 RCL 07
 70 XEQ 03
 71 RTN
 72 LBL 04
 73 FS? 00
 74 GTO 14
 75 RCL 20
 76 CHS
 77 ST+ 09
 78 RCL 07
 79  E2
 80 /
 81 -
 82 GTO 06
 83 LBL 02
 84 RCL 01
 85 RCL 02
 86 *
 87 RCL 03
 88 +
 89 RCL 00
 90 X=Y?
 91 GTO 07
 92 FS? 01
 93 RTN
 94 LBL 08
 95 .21
 96 RCL 20
 97 1.5
 98 *
 99 STO 20
100 ST+ 09
101 +
102 LBL 06
103 PSE
104 PSE
105 PSE
106 PSE
107 RCL 09
108 7DSP2 -- XROM 30,14
109 FS? 01
110 STOP
111 RTN
112 LBL 07
113 FS? 01
114 GTO 04
115 0
116 7DSP9 -- XROM 30,21
117 GTO 06
118 LBL 09
119 10
120 X<>Y
121 X<=Y?
122 RTN
123 X<>Y
124 RTN
125 LBL 03
126  E2
127 /
128 RCL 20
129 +
130 RTN
131 LBL 05
132 7DSP0 -- XROM 30,12
133 7PRTX -- XROM 30,34
134 7DSP2 -- XROM 30,14
135 RTN
136 LBL 15
137 LBL a
138 0
139 STO 25
140 .5281163
141 STO 24
142 LBL 00
143 RCL 24
144 997
145 *
146 FRC
147 STO 24
148 13
149 *
150 INT
151 1
152 +
153 STO 23
154 7DSZ -- XROM 30,23
155 GTO 00
156 RTN
157 LBL 12
158 LBL C
159 CF 00
160 ADV
161 RCL 21
162 XEQ 05
163 RCL 22
164 XEQ 05
165 SF 01
166 XEQ 02
167 CF 01
168 RCL 03
169 LBL 16
170 LBL b
171 17
172 X<=Y?
173 GTO 18
174 XEQ 19
175 ST+ 03
176 RCL 03
177 22
178 X<=Y?
179 GTO 01
180 RCL 03
181 GTO 16
182 LBL 18
183 LBL d
184 RCL 07
185 RCL 03
186 -
187 X=0?
188 GTO 06
189 X<0?
190 GTO 04
191 LBL 01
192 RCL 20
193 ST+ 09
194 RCL 07
195 XEQ 03
196 GTO 06
197 LBL 19
198 LBL e
199 1
200 STO 25
201 XEQ 00
202 XEQ 05
203 XEQ 09
204 RTN
205 LBL 17
206 LBL c
207 0
208 STO 09
209 RTN
210 STOP
211 END
Artillery HP67
 01 LBL "ARTL67"
 02 LBL 15
 03 LBL a
 04 7FIX -- XROM 30,26
 05 7DSP2 -- XROM 30,14
 06 .5284163
 07 STO 00
 08 3
 09 STO 22
 10 500
 11 STO 21
 12  E2
 13 STO 23
 14 X^2
 15 STO 09
 16 RTN
 17 LBL 10
 18 LBL A
 19 ADV
 20 0
 21 STO 25
 22 RCL 09
 23 2
 24 /
 25 ENTER
 26 XEQ 00
 27 +
 28 360
 29 XEQ 00
 30 STO 08
 31 R^
 32 P-R
 33 STO 01
 34 X<>Y
 35 STO 02
 36 45
 37 ST/ 08
 38 RCL 08
 39 7DSP0 -- XROM 30,12
 40 RND
 41 *
 42 RTN
 43 LBL 12
 44 LBL C
 45 RCL 02
 46 RCL 01
 47 R-P
 48  E4
 49 /
 50 X<>Y
 51 X>0?
 52 GTO 02
 53 360
 54 +
 55 LBL 02
 56 7DSP0 -- XROM 30,12
 57 RND
 58 +
 59 7DSP4 -- XROM 30,16
 60 RTN
 61 LBL 16
 62 LBL b
 63 STO 21
 64 RTN
 65 LBL 17
 66 LBL c
 67 STO 22
 68 RTN
 69 LBL 18
 70 LBL d
 71 STO 23
 72 RTN
 73 LBL 01
 74 CF 00
 75 X<0?
 76 SF 00
 77 RCL 21
 78 XEQ 00
 79 FS? 00
 80 CHS
 81 -
 82 RTN
 83 LBL 19
 84 LBL e
 85 LBL 14
 86 LBL E
 87 7ISZ -- XROM 30,29
 88 X<>Y
 89 7DSP7 -- XROM 30,19
 90 7PRTX -- XROM 30,34
 91 X<>Y
 92 7DSP1 -- XROM 30,13
 94 ENTER
 95 +
 96 SIN
 97 RCL 09
 98 *
 99 P-R
100 STO 03
101 X<>Y
102 STO 04
103 RCL 01
104 XEQ 01
105 STO 01
106 RCL 02
107 XEQ 01
108 STO 02
109 CHS
110 RCL 04
111 +
112 RCL 03
113 RCL 01
114 -
115 R-P
116 STO 07
117 RCL 23
118 X<>Y
119 X>Y?
120 GTO 07
121 RCL 22
122 RCL 21
123 RDN
124 RDN
125 7PRSTK -- XROM 30,33
126 STOP
127 LBL 07
128 RDN
129 RDN
130 RCL 02
131 RCL 01
132 R-P
133 500
134 LBL 08
135 X>Y?
136 PSE
137 X>Y?
138 GTO 08
139 RDN
140 RDN
141 -
142 30
143 /
144 4
145 RCL 22
146 -
147 XEQ 09
148 LBL 05
149 X<0?
150 GTO 06
151 7DSP0 -- XROM 30,12
152 RND
153 STO 08
154 RCL 07
155 .2
156 ENTER
157 4
158 RCL 22
159 -
160 *
161 *
162 X=0?
163 GTO 03
164 XEQ 09
165 RCL 23
166 LBL 03
167 X<=Y?
168 X<>Y
169 RCL 09
170 /
171 7DSP3 -- XROM 30,15
172 RND
173 RCL 08
174 +
175 7DSP4 -- XROM 30,16
176 7PRSTK -- XROM 30,34
177 RTN
178 LBL 06
179 12
180 +
181 GTO 05
182 LBL 09
183 -
184 LASTX
185 ENTER
186 +
187 XEQ 00
188 +
189 RTN
190 LBL 00
191 RCL 00
192 997
193 *
194 FRC
195 STO 00
196 *
197 RTN
198 STOP
199 END
Space War 67 (Card A) - Card B which follows should really be combined with this Card A
 01 LBL "SPW67A"
 02 LBL 10
 03 LBL A
 04 XROM 30,11
 05 X=0?
 06 PI
 07 STO 09
 08 10
 09 STO 04
 10 20
 11 STO 25
 12 LBL 09
 13 XEQ 01
 14 XEQ 08
 15 FS?C 02
 16 GTO 09
 17 STO IND 25
 18 XROM 30,29
 19 RCL 25
 20 25
 21 X!=Y?
 22 GTO 09
 23  E3
 24 STO 06
 25 3
 26 STO 07
 27 STO 09
 28 18
 29 STO 08
 30 RCL 24
 31 RTN
 32 LBL 01
 33 RCL 09
 34 997
 35 *
 36 FRC
 37 STO 09
 38  E4
 39 *
 40 INT
 41 XEQ 05
 42 XEQ 05
 43 RTN
 44 LBL 08
 45 RCL 20
 46 X=Y?
 47 SF 02
 48 CLX
 49 RCL 21
 50 X=Y?
 51 SF 02
 52 CLX
 53 RCL 22
 54 X=Y?
 55 SF 02
 56 CLX
 57 RCL 23
 58 X=Y?
 59 SF 02
 60 RDN
 61 RTN
 62 LBL 12
 63 LBL C
 64 4
 65 XROM 30,26
 66 999
 67 /
 68 STO 02
 69 XROM 30,20
 70 ADV
 71 RCL 24
 72 INT
 73 STO 00
 74 RCL 04
 75 +
 76 XEQ 03
 77 RCL 00
 78 XEQ 03
 79 RCL 00
 80 RCL 04
 81 -
 82 XEQ 03
 83 RTN
 84 LBL 03
 85 RCL 02
 86 STO 01
 87 RDN
 88 STO 03
 89 ST+ 01
 90 1
 91 -
 92 XEQ 00
 93 XEQ 05
 94 XEQ 05
 95 ST+ 01
 96 RCL 03
 97 XEQ 00
 98  E5
 99 /
100 ST+ 01
101 RCL 03
102 1
103 +
104 XEQ 00
105  E8
106 /
107 ST+ 01
108 RCL 01
109 XROM 30,34
110 RTN
111 LBL 00
112 0
113 STO 05
114 RDN
115 RCL 20
116 INT
117 X=Y?
118 XEQ 01
119 CLX
120 RCL 21
121 INT
122 X=Y?
123 XEQ 01
124 CLX
125 RCL 22
126 INT
127 X=Y?
128 XEQ 01
129 CLX
130 RCL 23
131 INT
132 X=Y?
133 XEQ 02
134 RCL 05
135 RTN
136 LBL 01
137 RCL 04
138 ST+ 05
139 RTN
140 LBL 02
141 1
142 ST+ 05
143 RTN
144 LBL 14
145 LBL E
146 P-R
147 XROM 30,26
148 XROM 30,13
149 RND
150 STO 00
151 X<>Y
152 RND
153 XROM 30,14
154 RCL 24
155 XEQ 05
156 STO 03
157 INT
158 RCL 24
159 XEQ 04
160 STO 02
161 INT
162 XEQ 05
163 FRC
164 +
165 +
166 FRC
167 LASTX
168 INT
169 XEQ 04
170 +
171 RCL 02
172 FRC
173 RCL 03
174 FRC
175 XEQ 04
176 INT
177 +
178 RCL 00
179 +
180 INT
181 LASTX
182 FRC
183 XEQ 05
184 +
185 LBL 07
186 +
187 XEQ 08
188 FS?C 02
189 GTO 00
190 STO 24
191 1
192 ST- 08
193 RCL 08
194 X<0?
195 GTO 06
196 RCL 24
197 RTN
198 LBL 06
199 CLX
200 PSE
201 GTO 06
202 LBL 04
203 RCL 04
204 *
205 RTN
206 LBL 05
207 RCL 04
208 /
209 RTN
210 LBL 00
211 .1
212 GTO 07
213 LBL 15
214 LBL a
215 RCL 08
216 RTN
217 GTO 67
218 END
Space War Card B
 01 LBL "SPW67B"
 02 LBL 10
 03 LBL A
 04 XROM 30,26
 05 XROM 30,21
 06 ADV
 07 XROM 30,31
 08 9
 09 STO 25
 10 0
 11 LBL 09
 12 STO IND 25
 13 XROM 30,23
 14 GTO 09
 15 STO 00
 16 3
 17 RCL 24
 18 XEQ 00
 19 4
 20 RCL 20
 21 XEQ 00
 22 4
 23 RCL 21
 24 XEQ 00
 25 4
 26 RCL 22
 27 XEQ 00
 28 7
 29 RCL 23
 30 XEQ 00
 31 9
 32 STO 25
 33 LBL 08
 34 RCL IND 25
 35 XROM 30,34
 36 XROM 30,23
 37 GTO 08
 38 RCL 00
 39 XROM 30,34
 40 XROM 30,31
 41 RTN
 42 LBL 00
 43 ENTER
 44 INT
 45 RCL 24
 46 INT
 47 X!=Y?
 48 RTN
 49 RDN
 50 RDN
 51 FRC
 52 XEQ 05
 53 INT
 54 STO 25
 55 CLX
 56 LASTX
 57 FRC
 58 XEQ 05
 59 CHS
 60 10^X
 61 *
 62 ST+ IND 25
 63 RTN
 64 LBL 12
 65 LBL C
 66 CF 00
 67 STO 00
 68 RCL 07
 69 1
 70 X>Y?
 71 GTO 11
 72 -
 73 STO 07
 74 19
 75 STO 25
 76 XEQ 01
 77 XEQ 01
 78 XEQ 01
 79 RCL 09
 80 CF 00
 81 RTN
 82 LBL 01
 83 XROM 30,29
 84 FS? 00
 85 RTN
 86 RCL IND 25
 87 INT
 88 RCL 24
 89 INT
 90 X!=Y?
 91 RTN
 92 XEQ 07
 93 CLX
 94 RCL 00
 95 -
 96 ABS
 97 1
 98 X<=Y?
 99 RTN
100 1-
101 STO IND 25
102 SF 00
103 1
104 ST- 09
105 RTN
106 LBL 07
107 RCL IND 25
108 FRC
109 XEQ 05
110 STO 01
111 INT
112 RCL 24
113 FRC
114 XEQ 05
115 INT
116 -
117 RCL 01
118 FRC
119 RCL 24
120 XEQ 05
121 FRC
122 -
123 XEQ 05
124 R-P
125 RTN
126 LBL 13
127 LBL D
128 STO 00
129 ST- 06
130 19
131 STO 25
132 XEQ 04
133 XEQ 04
134 XEQ 04
135 RCL 09
136 RTN
137 LBL 04
138 RCL 06
139 X<0?
140 GTO 06
141 XROM 30,29
142 RCL IND 25
143 INT
144 RCL 24
145 INT
146 X!=Y?
147 RTN
148  E2
149 ST- 06
150 XEQ 07
151 X^2
152  E2
153 +
154 RCL 00
155 X<=Y?
156 RTN
157 1-
158 STO IND 25
159 1
160 ST- 09
161 RTN
162 LBL 06
163 CLX
164 PSE
165 GTO 06
166 LBL 14
167 LBL E
168 RCL 23
169 INT
170 RCL 24
171 INT
172 X!=Y?
173 GTO 15
174 RCL 23
175 FRC
176 XEQ 05
177 STO 00
178 INT
179 RCL 24
180 FRC
181 XEQ 05
182 STO 01
183 INT
184 -
185 ABS
186 2
187 X<=Y?
188 GTO 15
189 RCL 00
190 FRC
191 XEQ 05
192 RCL 01
193 FRC
194 XEQ 05
195 -
196 ABS
197 2
198 X<=Y?
199 GTO 15
200  E3
201 STO 06
202 3
203 STO 07
204 GTO 00
205 LBL 15
206 LBL a
207 RCL 06
208 RCL 07
209 LBL 00
210 10
211 /
212 X<>Y
213 INT
214 +
215 XROM 30,26
216 XROM 30,13
217 RTN
218 LBL 05
219 10
220 *
221 RTN
222 GTO 67
223 END
Lander
 01 LBL "LAND67"
 02 LBL 10
 03 LBL A
 04 500
 05 STO 06
 06 50-
 07 STO 07
 08 60
 09 STO 08
 10 LBL 09
 11 RCL 06
 12 XROM 30,16
 13  E4
 14 /
 15 RCL 07
 16 CF 02
 17 X<0?
 18 SF 02
 19 ABS
 20 +
 21 FS?C 02
 22 CHS
 23 PSE
 24 PSE
 25 XROM 30,12
 26 RCL 08
 27 PSE
 28 3
 29 PSE
 30 2
 31 PSE
 32 1
 33 PSE
 34 0
 35 PSE
 36 LBL 05
 37 RCL 08
 38 X<>Y
 39 X>Y?
 40 GTO 02
 41 ST- 08
 42 2
 43 *
 44 5
 45 -
 46 STO 09
 47 2
 48 /
 49 RCL 06
 50 +
 51 RCL 07
 52 +
 53 RCL 09
 54 ST+ 07
 55 RDN
 56 STO 06
 57 INT
 58 X>0?
 59 GTO 09
 60 LBL 03
 61 XROM 30,12
 62 RCL 07
 63 LBL 04
 64 PSE
 65 GTO 04
 66 LBL 02
 67 RCL 08
 68 2.5
 69 -
 70 ST+ 06
 71 2
 72 *
 73 ST+ 07
 74 RCL 06
 75 10
 76 *
 77 RCL 07
 78 X^2
 79 +
 80 SQRT
 81 CHS
 82 GTO 04
 83 LBL 11
 84 LBL B
 85 5
 86 ST- 08
 87 0
 88 GTO 05
 89 STOP
 90 END
Rocket 67 - another lander
 01 LBL "RCTK67"
 02 LBL 17
 03 LBL c
 04 XROM 30,11
 05 XROM 30,31
 06 XROM 30,11
 07 17
 08 STO 25
 09 LBL 09
 10 RCL 25
 11 1
 12 -
 13 4
 14 /
 15 5
 16 *
 17 55
 18 +
 19 STO IND 25
 20 RCL 25
 21 4
 22 -
 23 STO 25
 24 X>0?
 25 GTO 09
 26 RTN
 27 LBL 10
 28 LBL A
 29 1
 30 GTO 00
 31 LBL 11
 32 LBL B
 33 2
 34 GTO 00
 35 LBL 12
 36 LBL C
 37 3
 38 GTO 00
 39 LBL 13
 40 LBL D
 41 4
 42 GTO 00
 43 LBL 14
 44 LBL E
 45 5
 46 LBL 00
 47 XROM 30,34
 48 1
 49 -
 50 4
 51 *
 52 1
 53 +
 54 STO 00
 55 STO 25
 56 RDN
 57 9
 58 X<=Y?
 59 X<>Y
 60 RDN
 61 P-R
 62 XROM 30,29
 63 XROM 30,29
 64 RCL IND 25
 65 +
 66 STO IND 25
 67 XEQ 02
 68 XROM 30,23
 69 XROM 30,23
 70 RCL IND 25
 71 +
 72 STO IND 25
 73 X<>Y
 74 XROM 30,29
 75 XROM 30,29
 76 XROM 30,29
 77 RCL IND 25
 78 +
 79 STO IND 25
 80 XEQ 02
 81 XROM 30,23
 82 XROM 30,23
 83 RCL IND 25
 84 +
 85 STO IND 25
 86 RCL 00
 87 STO 25
 88 RCL IND 25
 89 STO 21
 90 XROM 30,29
 91 RCL IND 25
 92 STO 22
 93 17
 94 STO 25
 95 LBL 08
 96 RCL 00
 97 X=Y?
 98 GTO 00
 99 RCL IND 25
100 RCL 21
101 -
102 XROM 30,29
103 RCL IND 25
104 RCL 22
105 -
106 R-P
107 2
108 X<=Y?
109 XROM 30,23
110 X<=Y?
111 GTO 00
112 RCL 25
113 2
114 -
115 4
116 /
117 1
118 +
119 PSE
120 PSE
121 PSE
122 0
123 XROM 30,29
124 STO IND 25
125 XROM 30,29
126 STO IND 25
127 RCL 00
128 X<> 25
129 X<>Y
130 XROM 30,29
131 XROM 30,29
132 STO IND 25
133 XROM 30,29
134 STO IND 25
135 X<>Y
136 3
137 -
138 X<> 25
139 LBL 00
140 RCL 25
141 4
142 -
143 STO 25
144 X>0?
145 GTO 08
146 RCL 21
147 50
148 /
149 XEQ 07
150 RCL 22
151 70
152 /
153 XEQ 07
154 +
155 1
156 X>Y?
157 GTO 05
158 RCL 21
159 80
160 /
161 XEQ 07
162 RCL 22
163  E2
164 /
165 XEQ 07
166 +
167 1
168 X>Y?
169 GTO 06
170 LBL 05
171 RCL 00
172 2
173 +
174 STO 25
175 0
176 STO IND 25
177 XROM 30,29
178 STO IND 25
179 LBL 06
180 RCL 00
181 3
182 +
183 STO 25
184 RCL IND 25
185 XROM 30,23
186 RCL IND 25
187 XROM 30,23
188 R-P
189 RCL IND 25
190 XROM 30,23
191 RCL IND 25
192 XROM 30,33
193 RTN
194 LBL 02
195 LASTX
196 +
197 2
198 /
199 RTN
200 LBL 07
201 ABS
202 2.5
203 Y^X
204 RTN
205 LBL 15
206 LBL a
207 XROM 30,34
208 1
209 -
210 4
211 *
212 2
213 +
214 STO 25
215 RCL IND 25
216 XROM 30,34
217 XROM 30,23
218 RCL IND 25
219 XROM 30,34
220 RTN
221 STOP
222 END
Slot Machine (another)
 01 LBL "SLMC67"
 02 LBL 11
 03 LBL B
 04 XROM 30,14
 05 RCL 00
 06 RTN
 07 LBL 14
 08 LBL E
 09 XROM 30,11
 10 STO 24
 11 CLX
 12 XROM 30,12
 13 RTN
 14 LBL 10
 15 LBL A
 16 XROM 30,15
 17 1
 18 ST- 00
 19 RCL 24
 20  E3
 21 *
 22 COS
 23 ABS
 24 STO 24
 25  E6
 26 +
 27 LASTX
 28 -
 29 FRC
 30 STO 04
 31 10
 32 STO 05
 33 *
 34 INT
 35 STO 01
 36 CHS
 37 LASTX
 38 +
 39 RCL 05
 40 *
 41 INT
 42 STO 02
 43 CHS
 44 LASTX
 45 +
 46 RCL 05
 47 *
 48 INT
 49 STO 03
 50 1
 51 RCL 01
 52 X=Y?
 53 GTO 01
 54 RCL 02
 55 X!=Y?
 56 GTO 09
 57 RCL 03
 58 X!=0?
 59 GTO 02
 60 10
 61 ST+ 00
 62 RCL 02
 63 X!=0?
 64 GTO 09
 65 90
 66 GTO 08
 67 LBL 02
 68 RCL 02
 69 RCL 03
 70 X!=Y?
 71 GTO 09
 72 10
 73 GTO 08
 74 LBL 01
 75 2
 76 ST+ 00
 77 1
 78 RCL 02
 79 X!=Y?
 80 GTO 09
 81 3
 82 LBL 08
 83 ST+ 00
 84 LBL 09
 85 RCL 01
 86 10
 87 /
 88 XROM 30,13
 89 PSE
 90 RCL 02
 91 100
 92 /
 93 +
 94 XROM 30,14
 95 PSE
 96 RCL 03
 97  E3
 98 /
 99 +
100 XROM 30,15
101 RTN
102 STOP
103 END
Tic Tac Toe
 01 LBL "TTT67"
 02 LBL 10
 03 LBL A
 04 0
 05 STO 24
 06 -1
 07 STO 00
 08 2
 09 XEQ 16
 10 XEQ 08
 11 XEQ 13
 12 XEQ 19
 13 RCL 25
 14 RCL 24
 15 XROM 30,21
 16 STOP
 17 XEQ 16
 18 XEQ 08
 19 XEQ 18
 20 RCL IND 25
 21 INT
 22 RCL IND 25
 23 STO 21
 24 LBL 00
 25 +
 26 XEQ 11
 27 STO 25
 28 XEQ 13
 29 XEQ 19
 30 RCL 25
 31 XROM 30,21
 32 RCL 24
 33 +
 34 STOP
 35 LBL 14
 36 LBL E
 37 XEQ 16
 38 XEQ 08
 39 XEQ 18
 40 RCL 25
 41 XEQ 11
 42 X=Y?
 43 XEQ 11
 44 STO 25
 45 XEQ 13
 46 XEQ 19
 47 RCL 25
 48 XROM 30,21
 49 RCL 24
 50 +
 51 STOP
 52 GTO 14
 53 LBL 11
 54 LBL B
 55 RCL 21
 56 FRC
 57 10
 58 *
 59 STO 21
 60 INT
 61 RTN
 62 LBL 16
 63 LBL b
 64 STO 20
 65 STO 25
 66 RTN
 67 LBL 08
 68 1
 69 ST+ 00
 70 RCL 20
 71 RTN
 72 LBL 18
 73 LBL d
 74 RCL 25
 75 CHS
 76 10^X
 77 2
 78 *
 79 RCL 24
 80 +
 81 STO 24
 82 RCL 25
 83 RTN
 84 LBL 19
 85 LBL e
 86  E6
 87 XEQ 09
 88  E3
 89 XEQ 09
 90 1
 91 XEQ 09
 92 ADV
 93 RTN
 94 LBL 09
 95 XROM 30,15
 96 RCL 24
 97 *
 98 FRC
 99 RCL 00
100 +
101 XROM 30,34
102 XROM 30,12
103 RTN
104 LBL 13
105 LBL D
106 RCL 25
107 CHS
108 10^X
109 RCL 24
110 +
111 STO 24
112 RCL 25
113 RTN
114 LBL 15
115 LBL a
116 .5873649
117 STO 01
118 .5891467
119 STO 03
120 .13598
121 STO 04
122 .1374698
123 STO 05
124 .31578
125 STO 06
126 .13589
127 STO 07
128 .3175964
129 STO 08
130 .31587
131 STO 09
132 0
133 RTN
134 STOP
135 END
Wari
 01 LBL "WARI67"
 02 LBL 10
 03 LBL A
 04 CHS
 05 7
 06 +
 07 SF 01
 08 GTO 09
 09 LBL 14
 10 LBL E
 11 6
 12 +
 13 CF 01
 14 LBL 09
 15 STO 22
 16 STO 25
 17 RCL IND 25
 18 X=0?
 19 /
 20 STO 23
 21 0
 22 STO IND 25
 23 LBL 01
 24 XROM 30,23
 25 GTO 08
 26 12
 27 STO 25
 28 LBL 08
 29 RCL 25
 30 RCL 22
 31 X=Y?
 32 GTO 01
 33 1
 34 ST+ IND 25
 35 RCL 23
 36 1
 37 -
 38 STO 23
 39 X=0?
 40 GTO 05
 41 GTO 01
 42 LBL 12
 43 LBL C
 44 12
 45 STO 25
 46 4
 47 LBL 00
 48 STO IND 25
 49 XROM 30,23
 50 GTO 00
 51 0
 52 STO 20
 53 STO 21
 54 LBL 06
 55 XEQ 11
 56 FS? 00
 57 GTO 13
 58 FS? 01
 59 GTO 19
 60 GTO 13
 61 LBL 11
 62 LBL B
 63 ADV
 64 6
 65 STO 25
 66 LBL 03
 67 RCL IND 25
 68 13
 69 RCL 25
 70 -
 71 STO 25
 72 CLX
 73 +
 74 RCL IND 25
 75  E2
 76 /
 77 +
 78 XROM 30,34
 79 RCL 25
 80 13
 81 -
 82 CHS
 83 STO 25
 84 XROM 30,23
 85 GTO 03
 86 ADV
 87 RTN
 88 LBL 13
 89 LBL D
 90 RCL 20
 91 RCL 21
 92  E2
 93 /
 94 +
 95 RTN
 96 LBL 05
 97 RCL 25
 98 6.5
 99 -
100 RCL 22
101 LASTX
102 -
103 *
104 X>0?
105 GTO 06
106 LBL 07
107 2
108 RCL IND 25
109 X=Y?
110 GTO 07
111 3
112 X!=Y?
113 GTO 06
114 LBL 07
115 FS? 01
116 GTO 09
117 RCL 21
118 +
119 STO 21
120 GTO 07
121 LBL 09
122 RCL 20
123 +
124 STO 20
125 LBL 07
126 0
127 STO IND 25
128 XROM 30,29
129 7
130 RCL 25
131 X=Y?
132 GTO 06
133 13
134 X=Y?
135 GTO 06
136 GTO 07
137 LBL 19
138 LBL e
139 1
140 STO 25
141 LBL 02
142 RCL IND 25
143 X=0?
144 GTO 16
145 3
146 X>Y?
147 GTO 04
148 LBL 16
149 LBL b
150 XROM 30,29
151 RCL 25
152 7
153 X!=Y?
154 GTO 02
155 LBL 17
156 LBL c
157 RCL 24
158 PI
159 +
160 8
161 Y^X
162 FRC
163 STO 24
164 6
165 *
166 1
167 +
168 R-P
169 INT
170 STO 00
171 6
172 +
173 STO 25
174 RCL IND 25
175 X=0?
176 GTO 17
177 RCL 00
178 XROM 30,34
179 XEQ 14
180 RTN
181 LBL 04
182 RCL 25
183 STO 00
184 12
185 STO 25
186 LBL 18
187 LBL d
188 RCL IND 25
189 X=0?
190 GTO 08
191 11
192 /
193 FRC
194 11
195 *
196 RCL 25
197 RCL 00
198 -
199 X=Y?
200 GTO 09
201 LBL 08
202 XROM 30,23
203 RCL 25
204 6
205 X=Y?
206 GTO 08
207 GTO 18
208 LBL 08
209 RCL 00
210 STO 25
211 GTO 16
212 LBL 09
213 RCL 25
214 6
215 -
216 XROM 30,34
217 XEQ 14
218 RTN
219 STOP
220 END
Another Blackjack
 01 LBL "BJ"
 02 CF 00
 03 CF 01
 04 CF 02
 05 SF 27
 06 FIX 00
 07 "BLACKJACK"
 08 PROMPT
 09 LBL A
 10 RCL 08
 11 ABS
 12 STO 08
 13 9
 14 STO 25
 15 CF 00
 16 CF 01
 17 XEQ 00
 18 ISG 25
 19 ENTER
 20 STO IND 25
 21 STO 00
 22 STO 02
 23 FS?C 22
 24 SF 00
 25 XEQ 00
 26 STO 04
 27 STO 06
 28 FS?C 02
 29 SF 01
 30 XEQ 00
 31 ISG 25
 32 ENTER
 33 STO IND 25
 34 STO 01
 35 ST+ 02
 36 FS?C 02
 37 SF 00
 38 XEQ 00
 39 STO 05
 40 ST+ 06
 41 FS?C 02
 42 SF 01
 43 RCL 06
 44 FS? 01
 45 XEQ 07
 46 STO 07
 47 X=Y?
 48 SF 02
 49 FIX 00
 50 RCL 00
 51 PSE
 52 RCL 01
 53 PSE
 54 RCL 02
 55 VIEW X
 56 PSE
 57 PSE
 58 PSE
 59 CLD
 60 RCL 04
 61 CHS
 62 FS?C 02
 63 FS?C 02
 64 RTN
 65 PSE
 66 GTO C
 67 LBL 00
 68 10
 69 RCL 24
 70 PI
 71 -
 72 X^2
 73 FRC
 74 STO 24
 75 13
 76 *
 77 INT
 78 X=0?
 79 SF 02
 80 1
 81 +
 82 X>Y?
 83 RDN
 84 RTN
 85 LBL B
 86 XEQ 00
 87 ISG 25
 88 ENTER
 89 STO IND 25
 90 STO 00
 91 ST+ 02
 92 FS?C 02
 93 SF 00
 94 21
 95 RCL 02
 96 X>Y?
 97 GTO 02
 98 FIX 00
 99 RCL 00
100 PSE
101 LBL 01
102 RCL 02
103 VIEW X
104 PSE
105 PSE
106 PSE
107 CLD
108 RTN
109 LBL 02
110 CHS
111 STO 07
112 RCL 00
113 CHS
114 STO 05
115 GTO 05
116 LBL C
117 RCL 02
118 FS? 00
119 XEQ 07
120 STO 03
121 LBL 03
122 RCL 06
123 FS? 01
124 XEQ 07
125 STO 07
126 17
127 X<=Y?
128 GTO 04
129 RCL 05
130 CHS
131 PSE
132 RCL 06
133 CHS
134 VIEW X
135 PSE
136 PSE
137 PSE
138 CLD
139 XEQ 00
140 FS?C 02
141 SF 01
142 STO 05
143 RCL 06
144 +
145 STO 06
146 STO 07
147 22
148 X<=Y?
149 GTO 06
150 GTO 03
151 LBL 04
152 RCL 07
153 RCL 03
154 X=Y?
155 SF 02
156 X>Y?
157 GTO 06
158 LBL 05
159 RCL 08
160 CHS
161 STO 08
162 LBL 06
163 FIX 00
164 RCL 05
165 CHS
166 PSE
167 RCL 07
168 CHS
169 VIEW X
170 PSE
171 PSE
172 PSE
173 CLD
174 FIX 02
175 RCL 08
176 FS?C 02
177 CLX
178 ST+ 09
179 RTN
180 LBL 07
181 21
182 X<>Y
183 10
184 +
185 X<=Y?
186 RTN
187 LASTX
188 -
189 RTN
190 LBL a
191 FIX 00
192 9
193 X<> 25
194 STO 23
195 LBL 08
196 RCL 23
197 RCL 25
198 X=Y?
199 GTO 01
200 ISG 25
201 ENTER
202 RCL IND 25
203 PSE
204 GTO 08
205 LBL b
206 PI
207 +
208 STO 24
209 GTO b
210 LBL d
211 RCL 08
212 ABS
213 LBL D
214 FIX 02
215 RND
216 LASTX
217 X!=Y?
218 GTO c
219 X<0?
220 GTO c
221 X=0?
222 GTO c
223 STO 08
224 RTN
225 LBL e
226 CLX
227 STO 09
228 LBL E
229 FIX 02
230 RCL 09
231 RTN
232 END
Question: do you want to allow synthetics? Can save some bytes here and there.
Lol. Synthetics in an HP 67 program.
Sure. I just want to make sure they will run on any HP 41.
Agreed ... I meant 41 synthetics. Smile
(09-07-2016 09:56 PM)Gene Wrote: [ -> ]Lander
 01 LBL "LAND67"
 90 END
OK, here it is (was done in 10 minutes). Used HP41 SIGN function instead of a flag, moved registers 6...9 down to 1...4, replaced XROM-functions (DSP0 and DSP4) with FIX 0/4, some minor adjustments.
Dieter
[attachment=3894]
(09-07-2016 09:29 PM)Gene Wrote: [ -> ]Angel, are you ok if we save some space and go through this over the next week or so ?
Hey, I'm game for countless re-doings of the ROM image, what a lot of fun! ;-)
Sure Gene, never a problem...
(09-07-2016 08:42 PM)Dieter Wrote: [ -> ]You should post this "blueprint" here in the forum so that more users can work with it. See what we did with the one-arm-bandit program in a joint effort. ;-)
Dieter
Will love to but it seems I'm out of "allowed" space in the forum and the system won't let me to... so you guys send me your email addresses for a copy of the file.
Pages: 1 2 3 4 5
