06-30-2016, 02:03 AM
Hi all,
I finally managed to get the HP67 emulator fully working both PC and electronic versions.
Along with the Classics, it now emulates the HP21, 25, 27 and 29C models. The 29C continuous memory is working on the PC emulator and continues on where it left off after turning the power switch off, restarting the emulator or from changing calculator models. The electronic emulator doesn't have the continuous memory mode yet because the PCB will need a modification which I will do when I get home.
The 29C low power indicator in program mode is supposed to be decimal point flashing between the program step number and the program code. Does anyone know which digit it appears on?
Raining again here so still delayed getting home, but will upload when I can if anyone wants to try them out.
cheers
Tony
cheers
Tony
