Full Version: Can't get integration right
Hello all,
Would you be king enough as to point out what I am doing wrong with this very simple integration?
\[t = \int_0^{0.515}\frac{1}{0.000273\times exp\left[16306\times\left(\frac{1}{535}-\frac{1}{535+90.45x}\right)\right](1-x)} dx\]
The correct answer is \(833\) but I keep getting \(838.867\pm2.38E-7\) with FIX 9.
This is the code I am using on the 15C:
R0 = 0.000273
R1 = 16306
R2 = 535
R3 = 90.45
LBL 0
RCL 3
x
RCL 2
CHS
1/X
RCL 2
1/X
RCL 1
x
exp
RCL 0
x
x<>y
CHS
1
x
1/X
RTN
Very much appreciated.
You're not doing anything wrong, as that is the correct answer for the problem as stated.
Perhaps a digit is wrong somewhere in the constants?
Werner
That is right. Just found out 833 was a "close" approximation and 838.87 is actually the correct answer.
Thank you.
