04-30-2016, 01:38 PM
Applications in ROM Module (cont.)
HP-82481A AC Steady-State Circuit Analysis Pac
Owner Manual Introduction
The HP AC Steady-State Circuit Analysis Pac contains a general purpose Computer Network Analysis Program called CNAP. The building blocks that are available to construct circuit models are resistors, capacitors, inductors, voltage-controlled current sources (VCCS), lossless transmission line segments, open transmission line stubs, and shorted transmission line stub. The program can output the complex ac voltage at any node in the network. Optionally, group delay is calculated. CNAP provides rapid ac study-state analysis of virtually any type of electronic network.
Numerous use include:
- Active filter simulation.
- Analysis of LC filters containing transformer and coupled inductors.
- General transistor amplifier circuit analysis.
- Operational amplifier circuit analysis.
- High-frequency amplifier analysis (including transmission line segments).
Product # Title Released
HP-82481-90001 AC Steady-State Circuit Analysis Pac Owner's Manual 1983-12
- AC Steady-State Circuit Analysis Pac Owner's Manual (cover, manual)
HP-82481A_AC-CIRCUIT.ZIP distribution file
-> HP-82481A_AC-CIRCUIT_ROM.BIN Image for Emu71/DOS/Win
-> Circuit LEX 43 [VER$ CIRC:A]
-> KEYWAIT LEX 55 [VER$ n/a]
-> CNAP BASIC 9887
-> CNAPOUT BASIC 946
-> CNAPHEAD BASIC 261
-> HP-82481A_AC-CIRCUIT_ROM.LIF ILPER: LIF Mass Storage File
-> ROMCOPY LEX 1727 [VER$ RCPY:E]
-> CIRCUIT ROM 16384 ROMCOPY CIRCUIT:TAPE(#) TO :PORT(#)
HP-82482A Finance Pac
The HP-71 Finance Pac programs have been designed to easily perform the functions of a powerful financial calculator while offering the computer advantages of continuous memory, file creation and storage, and the potential use of peripherals. One program, the time value of money program (TVM), solves a wide range of problems for any person who works with financial contracts of any type: borrowers, lenders, lessors, lessees, accountants, real estate brokers, automobile dealers, and investors, to name a few.
Here are some of the things you can do with the program:
- Solve for the number of periods, the interest rate, the present value, the payment amount, or the future value of a uniform series of payments.
- Calculate an amortization schedule of a loan.
- Enter an uneven series of cash flows from the keyboard or from data files in memory. The cash flows may be grouped or ungrouped.
- Review or edit an uneven cash flow series.
- Calculate the internal rate of return (IRR) or the net present value (NPV) of an uneven cash flow series.
- Store an uneven cash flow series as a data file in memory.
The other Finance Pac program, the depreciation program (DEP), enables you to calculate, display, print, and store depreciation schedules in memory. You can choose from five different methods to calculate depreciation.
Manual
HP-82482-90001 Finance Pac Owner's Manual 1983-12
- Finance Pac Owner's Manual (cover, manual)
HP-82482A_FINANCE.ZIP distribution file
-> HP-82482A_FINANCE_ROM.BIN Image for Emu71/DOS/Win
-> Finance LEX 42 [VER$ FIN:A]
-> TVMKEYZ KEY 132
-> TVMHELP TEXT 1536
-> TVM BASIC 10378
-> DEP BASIC 3474
-> HP-82482A_FINANCE_ROM.LIF ILPER: LIF Mass Storage File
-> FINANCE ROM 16384 ROMCOPY FINANCE:TAPE(#) TO :PORT(#)
HP-82483A Surveying Pac
The Surveying Pac is a tool to aid the engineer and surveyor in solving many of the common surveying problems. Because it is one large integrated program, and not merely a collection of individual routines, the Surveying Pac exhibits power beyond what you may expect.
It simply and easily handles all the calculations involved in:
- Traversing.
- Inversing.
- Curve layout.
- Radial staking.
Its unique data entry system allows inputs to be made in a variety of ways: by using bearings, north and south azimuths, angles left ot right, and horizontal deflections left or right. You can choose your input modes regardless of the mode of output you desire. If entries are unknown, the program will ask other questions until enough is known about the situation for an answer to be computed.
Manual
HP-82483-90001 Surveying Pac Owner's Manual 1983-12
- Surveying Pac Owner's Manual (cover, manual)
HP-82483A_SURVEYING.ZIP distribution file
-> HP-82483A_SURVEYING_ROM.BIN Image for Emu71/DOS/Win
-> SURVEY BASIC 20
-> SURVEY71 BASIC 15847
-> SURV3 BASIC 56
-> SurveyV LEX 43 [VER$ SURV:A]
-> HP-82483A_SURVEYING_ROM.LIF ILPER: LIF Mass Storage File
-> SURVEY ROM 16384 ROMCOPY SURVEY:TAPE(#) TO :PORT(#)
HP-82484A Curve Fitting Pac
The HP 82484A Curve Fitting Pac is a powerful tool that enables you to perform functions that are not common to portable computing devices.
The Curve Fitting Pac permits you to:
- Fit a general model function (linear or non-linear) to a set of data using the CFIT program.
- Determine local maxima and minima of a large class of real-valued functions using the OPTIMIZE program.
The Curve Fitting Pac allows you to quickly and easily choose a model, fit a curve to your data, choose another model, and fit the curve again - all in a matter of seconds.
Features of the pac include:
- A matrix editor that makes entering and editing data easy.
- A built-in library of commonly-used fit models.
- The ability to store data and then retrieve it for later use.
- The ability to direct all intermediate and final results to a peripheral printer.
HP-82484-90001 Curve Fitting Pac Owner's Manual 1984-03
- Curve Fitting Pac Owner's Manual (cover, manual)
HP-82484A_CURVE-FITTING.ZIP distribution file
-> HP-82484A_CURVE-FITTING_ROM.BIN Image for Emu71/DOS/Win
-> CurveFit LEX 41 [VER$ FIT:A]
-> CFIT BASIC 14219
-> OPTIMIZE BASIC 5068
-> MODELS BASIC 5789
-> PCENTCHI BASIC 727
-> FITLEX LEX 415 [VER$ n/a]
-> FITLIB BIN 5545
-> CFKEYZ KEY 83
-> HP-82484A_CURVE-FITTING_ROM.LIF ILPER: LIF Mass Storage File
-> CURVEFIT ROM 32768 ROMCOPY CURVEFIT:TAPE(#) TO :PORT(#)
HP-82485A Text Editor Pac
Your HP 82485A Text Editor can be used to create, view, change, and print source program listings, text files, memos, form letters, personal letters, short reports, and other documents. In fact, the Text Editor enables you to manipulate any text file in your HP-71 memory.
Using the Text Editor, you can:
- Create new text file.
- Update text files by editing, deleting, and inserting lines of text.
- Search for and edit text.
- Copy or move sections of one file to another file.
- Print or list text files.
As you compose a text file, you can include (embed) text formatting commands in it. When you execute the format command, these embedded commands determine how your formatted, printed document will look.
Manuals
HP-82485-90001 Text Editor Pac Owner's Manual, 1st Ed 1984-03
HP-82485-90005 Text Editor Pac Owner's Manual, 1st Ed 1984-03
HP-82485-90007 Text Editor Pac Owner's Manual, 2nd Ed 1984-08
HP-82485-90002 Text Editor Pac Quick Reference Guide 1984-03
- Text Editor Pac Owner's Manual (cover, manual)
- Text Editor Pac Quick Reference Guide (cover, manual)
HP-82485A_TEXT-EDITOR.ZIP distribution file
-> HP-82485A_TEXT-EDITOR_ROM.BIN Image for Emu71/DOS/Win
-> EDTEXT BASIC 13080
-> EDLEX LEX 2799 [VER$ EDT:A]
-> EDKEYS KEY 142
-> EDRDPR BASIC 250
-> HP-82485A_TEXT-EDITOR_ROM.LIF ILPER: LIF Mass Storage File
-> TEXTEDIT ROM 16384 ROMCOPY TEXTEDIT:TAPE(#) TO :PORT(#)
HP-82488A Data Communications Pac
The Data Communications Pac provides a versatile terminal emulator software package, the DATACOMM program, for the HP-71 Portable Computer. With this program you can communicate with other computer systems over a phone line to access a variety of information. You can connect to systems such as The Source, Dow Jones News/Retrieval, and other host computer systems via a modem. It is quite easy to obtain stock quotes, send or receive electronic mail, or make airplane reservations using one of these data base services.
A few of the features provided by the system are:
- Incoming and outgoing data can be sent to the HP-71 display, a printer, and/or a video interface.
- Special code words can be created that simplify log on procedures.
- Text files that have been written off-line can be transferred to another host computer system.
- Incoming data can be saved in a text file for later review or printing.
- A 500-character input buffer is provided for reviewing information when using the HP-71 display.
- Command files allow easy implementation of repetitive operations.
- User programs can call and use DATACOMM'S features.
The DATACOMM program is entirely menu-driven. Most operations can be accessed from the menu by typing a single key.
Manual
HP-82488-90001 Data Communications Pac Owner's Manual 1984
- Data Communications Pac Owner's Manual (cover, manual)
HP-82488A_DATA-COMMUNICATIONS.ZIP distribution file
-> HP-82488A_DATA-COMMUNICATIONS_ROM.BIN Image for Emu71/DOS/Win
-> DCLEX P LEX 904 [VER$ DC:A]
-> DATACOMM P BASIC 15421
-> HP-82488A_DATA-COMMUNICATIONS_ROM.LIF ILPER: LIF Mass Storage File
-> DATACOMM ROM 16384 ROMCOPY DATACOMM:TAPE(#) TO :PORT(#)
HP-82489A AMPI Statistics Library Pac
The AMPI Statistics Library Pac provides two main capabilities:
- Statistical tools that include descriptive statistics procedures and statistical inference procedures.
- These tools allow you to make statistical inferences, not statistical conclusions.
- Descriptive statistics: Means & Moments, Histogram, Multiple Linear Regression.
- t-Statistics: Paired t-Test, Unpaired t-Test.
- F-Statistics: One-way Analysis of Variance, Two-way Analysis of Variance.
- Chi-Square: Contingency Table.
- Rank Statistics: Mann-Whitney U Test, Kruskal-Wallis test.
- Sampling Distribution: Student's t-Distribution, F-Distribution, Chi-Square Distribution.
- Probability Distribution: Normal Distribution, Weibull Distribution, Exponential Distribution, Binomial Distribution, Poisson Distribution.
HP-82489-90001 AMPI Statistics Library Pac Owner's Manual 1984-12
HP-82489A_AMPI-STATISTICS.ZIP distribution file
-> HP-82489A_AMPI-STATISTICS_ROM.BIN Image for Emu71/DOS/Win
-> AMPILEX P LEX 2620 [VER$ AMPISTAT:A]
-> STKEYZ KEY 83
-> AMPISTAT BASIC 19171
-> STP BASIC 7253
-> DIST BASIC 3032
-> HP-82489A_AMPI-STATISTICS_ROM.LIF ILPER: LIF Mass Storage File
-> AMPISTAT ROM 32768 ROMCOPY AMPISTAT:TAPE(#) TO :PORT(#)
HP-82490A HP-41 Translator Pac
The HP 82490A HP-41 Translator Pac consists of:
- The HP-41 Translator Pac module, which contains a system of programs for the HP-71 designed to allow you to convert programs written for the HP-41 for use on the HP-71. You can then run the "translated" programs on your HP-71, taking advantage of the HP-71's enhanced speed and accuracy.
- A keyboard overlay, designed to customize your HP-71 keyboard for use with the HP-41 Translator Pac.
- Use the HP-71 as an HP-41 calculator for keyboard operations and program execution. All HP-41 calculator features, including the alpha register, are available from the HP-71 keyboard.
- Write programs on the HP-71 in HP-41 user-programming language.
- Transfer programs automatically from the HP-41 to the HP-71 via HP-IL. (This requires HP-IL modules for both calculators.)
- Extend the HP-41 user language, either by adding HP-41 extension module functions not included in the HP-41 Translator Pac, or by adding new functions of your own design.
In short, the HP-41 Translator Pac allows you to retain the calculator and programming features of the HP-41, and to use your HP-41 programs, as you move into the more sophisticated and powerful world of the HP-71.
The HP-41 function set included in the HP-41 Translator Pac includes:
- All functions built into the HP-41C and HP-41CV calculators.
- Additional numeric, flag, and alpha data manipulation functions from the HP-41CX and the HP 82180A Extended Functions/Memory Module.
- All of the HP-IL printer functions from the HP 82160A HP-IL Module for the HP-41 except the special graphics functions.
Not included in the HP-41 Translator Pac are the time (TIME is included), date, stopwatch, alarm, and extended memory functions from the HP-41CX, or any other functions from HP-41 extension modules. Any HP-41 program that uses functions included in the pac can be translated and run on the HP-71.
HP-41 programs and keyboard operations that are executed on the HP-71 yield the same results as those obtained with the HP-41, except that:
- The HP-71 provides two additional mantissa digits and and one more exponent digit than the HP-41. This affects both the accuracy of numeric results and the allowed range of numbers.
- Unlike the HP-41, The HP-41 Translator Pac does not provide the ability to choose the digit separator and radix format.
- There are some differences in keyboard entry methods that arise from the different keyboards of the two computers and from the somewhat different styles of RPN arithmetic associated with HP-71 FORTH and the HP-41.
Appendix E contains a list of the HP-41 functions provided by the HP-41 Translator Pac, and description of the differences between the HP-41 and the HP-41 Translator Pac. The HP-41 Translator Pac is based on a FORTH language system built into the pac. FORTH is a computer language that shares many characteristics with the HP-41 user programming language, but is more widely recognized and applied to a greater variety of computers. You do not need to learn FORTH to use the HP-41 translator, but programmers familiar with FORTH can use the system to write HP-71 applications entirely in FORTH.
Manual
HP-82490-90001 HP-41 Translator Pac Owner's Manual 1985-01
- HP-41 Translator Pac Owner's Manual (cover, manual)
HP-82490A_HP-41-TRANSLATOR.ZIP distribution file
-> HP-82490A_HP-41-TRANSLATOR_HRD.BIN Image for Emu71/DOS/Win
-> HP-82490A_HP-41-TRANSLATOR_ROM.BIN Image for Emu71/DOS/Win
-> FTH41ROM P LEX 894 [VER$ FTH41:1A]
-> TRANS41 BASIC 3467
-> READ41 BASIC 1071
-> KEYS41 KEY 282
-> EDTEXT BASIC 6790
-> EDKEYS KEY 54
-> EDLEX LEX 2557 [VER$ EDT:A]
-> HP-82490A_HP-41-TRANSLATOR_ROM.LIF ILPER: LIF Mass Storage File for FRAM71 users
-> FTH41ROM ROM 16384 ROMCOPY FTH41ROM:TAPE(#) TO :PORT(#)
-> FTH41HRD TEXT 67840 ROM Memory (E0000-EFFFF) Dump
-> FTH41LDR BASIC 160 ROM Memory (E0000-EFFFF) Dump Loader
Super Surveyor Module by Cassera Survey
The SUPER SURVEYOR software was initially developed to fill the need for a data collector which would support the HP-3820A Electronic Total Station. It is now a field measurement system capable of supporting all Electronic Total Stations.
The process of field measurement is facilitated by the SUPER SURVEYOR in its simplicity of concept and use. The functions are kept to a minimum to avoid distracting the user.
The system represent the minimum effort required to perform a data collection or stake out survey. The user is reminded that he is free and possibly obligated to employ any additional methods or techniques which he might judge necessary in the performance if his duty as a Land Surveyor or subordinate.
The minimum hardware required by the system is:
- TOTAL STATION (may be semi-auto and used with HANDNTRY)
- HP-71B Computer
- HP-82401A HP-IL Module
- Field Interface (not necessary for HANDNTRY)
- SUPER SURVEYOR firmware
- HP-82483A Surveying Pac
- Optional: Memory Modules or Portable Disk (HP-9114)
- Optional: ThinkJet (through the use of 'PRINTFILE(0)')
SUPER SURVEYOR Super Surveyor Owner's Manual 1985
CASSERA_SUPER-SURVEYOR.ZIP distribution file
-> CASSERA_SUPER-SURVEYOR_ROM.BIN Image for Emu71/DOS/Win
-> SUPRSURV E BASIC 24064
-> CAT BASIC 179
-> AUTOSTAK E BASIC 8795
-> HANDSHAK BASIC 46
-> SITEST LEX 63 [VER$ n/a]
-> SEVENBIT LEX 133 [VER$ SEV:A]
-> VERSION LEX 43 [VER$ SUPR:E]
-> SSILEX LEX 285 [VER$ n/a]
-> SRLTC1 LEX 1396 [VER$ STC:A2]
-> AVE BASIC 65
-> FILEFIX BASIC 914
-> LIST BASIC 166
-> INST E BASIC 12324
-> CHA BASIC 203
-> KEYS KEY 613
-> MULTI BASIC 1727
-> COPYALL BASIC 182
-> LOGO DATA 498
-> CASSERA_SUPER-SURVEYOR_ROM.LIF ILPER: LIF Mass Storage File
-> CSSURVEY ROM 65536 ROMCOPY CSSURVEY:TAPE(#) TO :PORT(#)
Applications on Book & Media
HP-00071-90064 Math Users' Library Solutions
Introduction
HP-71 Solutions Books provide complete step-by-step keystroke listings to help equip you with answers to your general or specialized programs. Solutions Books are available on magnetic cards and mini data cassettes.
Solutions Book Content
Math Users' Library Solutions Book cover the following subjects:
- Vector Operations
This program provides solutions to the most common vector operations, such as addition, subtraction, dot and cross products, included angle, multiplication of a vector by a scalar, finding the length of a vector, and determining unit vectors. - Numerical Integration
This program will perform numerical integration whether a function is known explicitly or at a finite number of equally spaced points. - Solution to F(x)=0 on an Interval
This program provides two methods to find a real root of the equation f(x) = 0. They are Newton's Method and the Pegasus Method. In addition, the program allows the user to find the value of the function for an input x. - Matrix Operations
This program allows the user to calculate the determinant of a real valued matrix and find the inverse or solve a system of equations for real or complex valued systems. The method used is Gaussian elimination with partial pivoting. - Fast Fourier Transform
This program calculates a fast Fourier transform from a set of time domain points to a set of frequency domain points. The inverse fast Fourier transform, calculating the set of time domain points from a set of frequency domain points, may also be calculated. The method used is a modification of the basic FFT algorithm. - Polynomial Solutions
This program finds all solutions, both real and complex, of P(x)=0, where P is a polynomial of the form:
P(x)=a(n)x^n + a(n-)x^(n-1) + ... + a(1)x + a(0) = 0
HP-00071-90064 Math Users' Library Solutions 1984
HP-00071-90065 Games Users' Library Solutions
Introduction
Games Users' Library Solutions Book cover the following subjects:
- Code Crack
The object of this games is to guess the random sequence of colors the HP-71 has selected. Initially, the player must specify the number of elements in the sequence (4 to 9), the number of colors used to generate the sequence (4 to 9), and whether a color may appear more than once in the sequence. Once the sequence is generated, the player must enter a guess. The program accepts the guess one character at a time with no correction of errors. Once the last color is entered, the program compares the input with the stored sequence and tells you how close you were. - Craps
In this game of craps, the HP-71 is the 'house', using simplified casino rules. The game begins with the player specifying his bank limit, a value that will be rounded to the nearest dollar amount. Next the player must place his bet, which may be as much or all of his bank as he wishes (to end game enter 0). On the players first roll after a bet, the dice are automatically rolled, and the value of each, along with their total, is displayed by the HP-71. If the total of the dice equals 7 or 11 on the fist roll, the player wins and his bet is added to his bank. If the total of the dice equals 2,3 or 12 on the first roll, the amount of his bet is subtracted from his bank. Any other total on the first roll becomes the players "point". The player then continues to roll until the total of the dice equals his "point" (the player wins) or the total equals 7 or 11 (the player loses). - Hangman
Hangman is a word guessing game. This game is a version of the popular word game "hangman". The first player selects a word or phrase that is as many as 19 characters in length and keys it into the computer. The second player guesses various characters until he completes the word or gets hanged. - Blackjack
In this card game, the HP-71 is the dealer and up to eight people may play. Each player begins with $200 and may bet as much or all of it as he wishes up to $200. - Hammurabi
This game allows a player to control a country's economy through the buying and selling of land. The more efficiently he uses the land, the better a governor he is. - Space War
"Space War" sets up a two-dimensional playing area where you do battle with from 16 to 30 enemy ships. Your ship is equipped with long- and short-range sensors, shields, and 20 torpedoes. You also have 5 star bases at which you may effect repairs to your ship. The object of the game is to destroy all of the enemy ships before they destroy you.
HP-00071-90065 Games Users' Library Solutions 1984
HP-00071-90066 General Utilities Users' Library Solutions
Introduction
General Utilities Users' Library Solutions Book cover the following subjects:
- General System Utilities
The subprograms provided in this section are intended to function as enhancements to the HP-71 BASIC language. The majority of the twenty-three routines are complementary to HP-71 keywords. - Time and Date Utilities
The purpose of these thirteen routines is to allow the user to perform numeric calculations based on time and date. - Conversion Utilities
The purpose of these seven subprograms is to provide a base of generic conversions that can be used both from the keyboard and from within a program. - HP-IL Utilities
The purpose of these three routines is to provide a mechanism by which the volume label of a mini data cassette may be accessed and by which information about the device type and location of the PRINTER IS device may be obtained. - Variable Cross Reference
The purpose of this program is to provide a listing of all variables contained in a program, and their respective line numbers. Such a listing is very useful in the debugging stages of program development. - System Catalog
The purpose of this subprogram is to provide a catalog of all LEX files and their entries. Since the HP-71 system ROM's are treated as LEX files, they are included in the catalog.
HP-00071-90066 General Utilities Users' Library Solutions 1984
HP-82440A Software Development Utility
Introduction
The HP-71 Development Utility is a program that runs on the HP-71 and allows you to transfer files between the HP-71 and another computer called the "host."
An HP-71 Development Utility work station is the equipment and software that allow you to transfer files between the HP-71 and a host.
Manual
HP-82440-90001 HP-71 Development Utility Owner's Manual 1984-02
HP-82440A_DEV-UTILITY.ZIP distribution file
-> HP-82440A_DEV-UTILITY_MEDIA.LIF ILPER: LIF Mass Storage File
-> XFERNC BASIC 6459 HP-71 transfer program with comments
-> XFERN BASIC 3565 HP-71 transfer program without comments
-> XFER BASIC 3565 Same as XFERN
HP-00071-90097 Software Developers' Handbook
Introduction
This document is a 'cookbook' for applications programmers working with the HP-71. Two goals are envisioned: first to serve as a timesaver, and second to suggest a measure of consistency among programs written for the HP-7I. While there is no hope of addressing all possible applications on the HP-71, common subjects such as user interface, environment preservation, and error trapping are discussed. The specifics of each application are left to the programmer.
Manual
HP-00071-90097 Software Developers' Handbook 1984
HP-00071-90097_SOFT-DEV-HANDBOOK.ZIP distribution file
-> HP-00071-90097_SOFT-DEV-HANDBOOK_MEDIA.LIF ILPER: LIF Mass Storage File
-> STRINGLX LEX 837 [VER$ STR:A]
-> PATTERN LEX 171 [VER$ PAT]
-> CUSTUTIL LEX 1007 [VER$ CSTU:A]
-> BREAKPT LEX 365 [VER$ BRK:A]
-> KEYBOARD LEX 1277 [VER$ KBD:B] (source FORTH/ASM module)
-> KBD150 BASIC 1088
-> GEDIT BASIC 1085
-> KBD264 BASIC 932
-> FTHUTILA TEXT 7424
-> FTHUTILC FORTH 4608
-> FTHUTILF TEXT 11520
WorkBook71 by Richard Harvey
Introduction
WorkBook71 is a data-gathering, analysis-and report-generating tool for the Hewlett-Packard HP-71 Portable Computer. Modules of the system include Editor, data format converter, searching, and Report Formatter. Each module can operate separately of others in the group and, by virtue of data format conversion, other programs you may have can be used interactively. The goal has been to provide a versatile package in which data can flow between applications with minimal hassle.
This manual is in several sections. "Getting Started" should be read before investigating the programs in this package. "Using the HP-71" is as much about a philosophy of using the computer in general as it is about using it with this package. There is a section on each of the programs with a discussion of their purpose, usage, and a list of commands. Part 5 explains the structure of WorkBook files and discusses methods for using the data in your Basic programs. Part 5 need only be read if you plan on writing your own programs. The inevitable Addendum is in the last section, listing some cautions and hints. A glossary is at the back of this manual.
Manual
WorkBook71 Spreadsheet, File Manager & Report Generator for the HP-71 1986
WORKBOOK71.ZIP distribution file
-> WORKBOOK71_MEDIA.LIF ILPER: LIF Mass Storage File
-> WBLEX LEX 832 [VER$ WB:C]
-> WB BASIC 5808 Spreadsheet editor
-> PRINTWB BASIC 2176 Spreadsheet printer
-> FNS BASIC 192
-> REPORT BASIC 4907 Text formatter
-> PORTER BASIC 1835 File converter
-> UTIL BASIC 2450 Spreadsheet utilities
-> MACRO BASIC 346
-> LABEL TEXT 256
-> FINDER BASIC 2350 Search program
-> PRINTCEL BASIC 1494
-> WBFNS BASIC 5994
-> TED2 BASIC 2362 Text editor
-> MENU BASIC 789 Operating system shell
-> CHARSET BASIC 329 Create alternate character set
-> WORKBOOK71_ROM.BIN Emu71/Win: directly map as ROM to port #
-> ... Same content as WORKBOOK71_MEDIA.LIF
-> WORKBOOK71_ROM.LIF ILPER: LIF Mass Storage File
-> WORKBK71 ROM 32768 ROMCOPY WORKBK71:TAPE(#) TO :PORT(#)
